BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > White stuff around my center caps
European Auto Source (EAS)
      07-20-2019, 03:53 PM   #1
lordg
Drives: 2012 328i
There's this hard white stuff forming around my bmw center caps on all 4 wheels. I tried cleaning them off but they're really hard to remove. It seems like they're stuck on really bad.
Anyone else experience the same issue and know what they are?
      07-20-2019, 03:57 PM   #2
eleven11
eleven11's Avatar
Drives: -F85 X5M-
It's hard to tell from the picture, but it almost looks like scrapes from where one has used a tool to remove the center cap. If not, it's probably some form or lime deposit or calcification. I'd take the caps off, soak the area with distilled white vinegar for 5-10 minutes, then gentle agitation with a toothbrush and/or a microfiber towel.
2017 X5M - Current
2017 F31 Wagon - Current
2014 M5 ZCP - Retired
2011 135i Coupe - Retired
2007 335i Sedan - Retired
      07-20-2019, 04:05 PM   #3
Troy27
Drives: Bmw f30
I have the same exact thing.....have no clue what it is.
      07-20-2019, 04:18 PM   #4
John in VA
Drives: 2015 228i M Sport
I believe it's a corrosion issue due to the dissimilar metals - had it on our F30. Some owners have been able to get their wheels or caps replaced under warranty - we weren't as lucky. Bought new caps.
2015 BMW 228i in EstorilBlau II Metallic / Terra Dakota Leather - 6-speed manual, M Sport Package, Cold Weather Package, Lighting Package, Premium Package, Harman Kardon premium sound, Anti-theft alarm system
      07-21-2019, 08:39 AM   #5
Solidjake
Shifting
Solidjake's Avatar
Poland
448
Drives: '13 328i Msport 6MT
Corrosion. You can clean it as stated or get new caps.
Apex SM-10/PSS | 400m/X-ice Xi3 | Injen Intake/Exhaust
Stoptech SS Lines | 335 Brakes | Hawk HPS 5.0 | RBF600
Bootmod3 Stg 1 93 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
      07-21-2019, 11:07 PM   #6
WallySlash
WallySlash's Avatar
Drives: 2014 428xi Sport Line
2014 BMW 428xi  [4.50]
Galvanic corrosion. The last time i rotated my tires (yeah I do rotate tires) I tried sanding off the corrosion but it made it worse. I rotated again today and put in new caps. My caps were original so I figure I will need new caps in another 5 years.
      07-22-2019, 12:57 AM   #7
lordg
Drives: 2012 328i
Anyone know where to buy new center caps for F30?
      07-22-2019, 08:18 AM   #8
wdeerfield
A family of bimmers
Drives: '13 f30, '11 f10
Also, that corrosion is from winter most likely. I have the same
depends on how much you want to spend. Ebay and amazon sell pretty cheap knock offs or your local dealer to spend a lot.
dealer will charge you approximately $17/ea
ECS/Turner will charge you $13 but then slam you with shipping charges to make up for their minimal markup on parts
https://www.turnermotorsport.com/p-4...iABEgLEEfD_BwE
ebay/amazon knock off full set for $17
https://www.amazon.com/Enseng-Set-Ce.../dp/B07HP9MFTQ
2013 EB/CR 335i xdrive | DHP | 19" VMR V803 | MPS4S | MPerformance | M3 Grills | BMS Tips | LED Turn Signals | CTS intake | VRSF FMIC | VRSF CP
2011 JB 535i xdrive | ZPP | ZSP | ZCW | 6FL | NAV | 331s Square | MPerformance Spoiler | M5 Grills | Painted Reflectors
      07-22-2019, 05:00 PM   #9
Solidjake
Shifting
Solidjake's Avatar
Poland
448
https://www.fcpeuro.com/products/bmw...ap-36136783536
x4 $62 shipped with lifetime warranty. If they start to corrode just send them in for new ones
wdeerfield1829.00
      07-24-2019, 09:55 AM   #10
wdeerfield
A family of bimmers
TIL about these: https://www.fcpeuro.com/products/bmw...mw-36122455269
