07-15-2021, 03:01 AM | #1 |
Rep 110
Drives: 2014 335i 6MT
Aliexpress LCI Headlights
Hello All,
I recently bit the bullet and purchased a set of Aliexpress LCI Headlights that are plug n play. I have a 2016 LCI with Halogens and it fit perfectly and the beam cut off is way better than the DEPO project headlights. I was looking around to see if anyone bought it or had talked about the headlights on the forums but had trouble finding anything. Let me know if you have any questions or want pics. Attached is the link https://www.aliexpress.com/item/1005...755ded4cd826-0 |
07-16-2021, 12:42 AM | #2 | |
Rep 103
07-16-2021, 10:51 AM | #3 |
Rep 4,551
Drives: 2015 328d xDrive
I'm very interested in a set of these, definitely post some pics!
A few questions as well if you don't mind: How's the quality? Any concerns or issues such as the brightness at night, water leaks/condensation, error messages, etc.? What was install like? How long did it take? Any coding needed? Can the DRL's still be turned on/off in iDrive? Can brightness be adjusted in bimmercode? |
07-17-2021, 04:29 AM | #4 | |
Rep 110
So the quality is pretty good, If I am not mistaken one of the components say "HELLA" which is the OEM manufacturer of the BMW LEDS. I owned an LCI before this with the OEM LEDS and the light output is pretty similar, but the cutoff isn't as clean as OEM. As far as issues, I have run into an issue with the bar at the end of the DRLs, on the driver side the bar at the end of the DRLS don't output light. I didn't notice the first day because I was a little too excited, and it's pretty hard to tell unless you look at a reflection and you'll see the bar next to the two half circles isn't emitting light. so I assume one of the bulbs shorted or something like that, but the seller which is AKD, was very understanding and was okay with sending me a replacement to remedy the situation. I do have to put a deposit down but I feel like that does make sense. There have been no error messages or issues, and I talked to another guy that had them from aliexpress and he's had no issues whatsoever. No coding was needed and as it truly is plug n play. I had installed a set of DEPO's before myself, and it took around 7-8 hours because I am not the handiest person, and my brother did a bulk of the work. So this time I sent it to a body shop that I've gone to in the past and they finished the install in around 3 hours. So I think it will vary whether or not you want to DIY or have someone else do it. However, when he installed he told me I needed special screws that he had to order from the dealer and I can ask him which ones specifically. The DRL's can be turned off, but unfortunately the brightness can't be adjusted in bimmercode as far as I know. I tried lowering the parking light brightness but it didn't seem to do anything. I'll try to get some pictures up when I have time, but overall I've been impressed with the lights especially after having LCI's before as well as DEPO's with LED bulbs. |
07-17-2021, 07:26 AM | #5 | |
Rep 4,551
Definitely let me know about those screws if you can. I think I'll be ordering a set of these ASAP. Curious how the light output is compared to the stock halogens? I currently have LED bulbs in mine and don't really have any complaints, just looking for an aesthetic change. As long as these headlights are as good as stock I'd be happy. Thanks for the pics and the info, much appreciated.
Bmwerspeed1230.00 |
07-17-2021, 01:10 PM | #6 | |
Rep 46
Would you be able to post a video with the headlights and show the blinkers on? I wanted to ask if blinkers on headlights are in sync with the blinkers on the car mirrors |
07-17-2021, 03:31 PM | #7 | ||
Rep 110
AndrewC198910931.00 |
07-19-2021, 09:43 AM | #8 |
Rep 2,146
Drives: F80 M3
very nice! do these have "BMW LED" etched on the outside of the lamps? I've been hesitant to pull the trigger on these myself but they look great.
Also how long did it take to receive them from when you ordered?
Instagram: http://instagram.com/e90nate
07-19-2021, 05:59 PM | #9 |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
It makes sense that coding doesn't affect the brightness of the DRLs anymore, I highly doubt that whoever manufactured these created modules that can fully interface with the rest of the car. For all intents and purposes they're "dumb" lights.
How do the highbeams/lowbeams work? On OEM LEDs the flap you see in the headlights is more in the middle but on these it's practically at the very top. OEM lowbeams come out on the top half and highbeams on the bottom on both the outer and inner segments. I'm guessing on these the lowbeams are the outer lights and highbeams are inner? And does the "eyebrow" light up? Does it blink yellow for turn signals? |
07-20-2021, 05:07 AM | #10 | |
Rep 144
Are your headlights adaptative too? Enjoy your car's significantly improved front-end. |
07-20-2021, 06:42 AM | #11 | ||
Rep 46
07-21-2021, 02:54 PM | #12 |
Rep 144
07-21-2021, 02:56 PM | #13 | |
Rep 46
07-23-2021, 09:18 PM | #15 |
Rep 192
Will you be able to change bulbs on these without having to remove the whole headlight like I've seen on some aftermarket lights?
Looks pretty good I know it's hard to tell without top notch camera etc but my only concern is light output during day looks a little weak, but I know that's hard to capture a lot of times Not sure I'm sold on the yellow light on top either but they don't look bad Thanks for sharing your experience with them Also, what did your shop charge you to install them? I may have a shop do mine if I pull the trigger - not that I can't do it, but if it's reasonable enough, I may save myself the aggravation of it and go play golf while a shop does the hard part lol |
07-26-2021, 05:50 AM | #16 |
Rep 110
07-26-2021, 09:23 PM | #17 |
Rep 110
The blinkers are a little out of sync from car mirrors, I'll try to get a video up soon
Bmwerspeed1230.00 |
07-26-2021, 09:47 PM | #18 | |
Rep 110
08-21-2021, 11:57 AM | #19 |
Rep 2
08-26-2021, 09:01 AM | #20 | |
Rep 47
08-28-2021, 07:25 PM | #21 |
Rep 400
Some output photos of the cutoff/light output would be awesome, anything against a wall to see the difference from OEM.
08 E92 335XI - Space Grey/Coral Red 11.80 @ 118.95mph - 470AWHP
2013 BMW 335XI MSport Alpine White/Venetian Beige 2018 WRX STi TypeRA 2022 X5 MSport Alpine White/Tartufo Merino - Inbound |
08-31-2021, 04:00 PM | #22 | |
Rep 383
