04-09-2014, 04:14 PM | #1 |
Rep 386
Electric folding mirrors
This might sound like a dumb question but how do i make mirror fold when car is locked and unfold when it is unlocked. It worked before.. Is it because i closed them when i was inside the car... Have i messed the setting??? How do i make them wor again? The user manual is useless Help
F32 430D M SPORT XDRIVE EBII on order
04-09-2014, 04:17 PM | #5 |
Rep 386
I have tried that... It folds but when i unlock it doesn't unfold??
04-09-2014, 04:19 PM | #6 |
Rep 386
Do i press lock first and then press lock again and hold?
04-09-2014, 04:29 PM | #7 |
Rep 2,511
Long press on the initial lock works a treat. I think a second press of lock disables the internal volumetric sensors for the alarm.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
04-09-2014, 04:32 PM | #8 |
Rep 386
I have tried long press when locking the car at same time.. Mirrors went in but it wont come out when unlocking???
04-09-2014, 04:36 PM | #9 |
Rep 1,359
Do they unfold when you press the button beside the mirror select switch on the drivers door? Mine work on the keyfob or the button. If I fold them with the button then I have ti unfold them with it. If I use the key, they unfold when unlock is pressed.
04-09-2014, 04:36 PM | #10 |
Rep 2,511
Just guessing now... Where is your adjustment selector? Shouldn't make a difference. However, my selector is on the drivers side mirror. This also enables the reversing dip of the passenger side mirror...
04-09-2014, 04:43 PM | #11 |
Rep 386
I want them to work like how it used to when i picked the car. It was operating with keyfob ie: when lock the car they fold and when unlock the car they unfold. I once pressed from inside to fold them...is that the reason it got messed up??? How do i put ir back right please??
04-09-2014, 04:46 PM | #12 |
Rep 1,359
Press the button on the door to fold them in. Press again to unfold. As said above put the mirror adjust selector to the drivers mirror which also activates the passenger mirror to look down when you reverse.
04-09-2014, 04:54 PM | #13 |
Rep 386
Ok i press from inside to fold and unfold.. Then what do i do to make it work from keyfob??
04-09-2014, 04:55 PM | #14 |
Rep 761
Drives: M235i Coupe
Well, I didn't know that. If you're right I can now lock the touring when popping into the shops as the dogs set the alarm off all the time. I'll try it out in the morning. No mention of this in the manual.
04-09-2014, 04:57 PM | #15 |
Rep 1,359
04-09-2014, 04:59 PM | #16 | |
Rep 2,511
If it works you get a flash if the red light and then I seem to remember a different flashing pattern. Coming back from France the tilt sensor self disabled...
04-09-2014, 05:24 PM | #17 |
Rep 11,292
Kind of obvious...... but the mirrors also unfold when I press the boot unlock button on the key fob as well as the normal door unlock button on the key fob.
Current: Golf R Mk8Previous: Golf R Mk7.5 Mercedes AMG C63 S Coupe F80 M3 Competition Pack |
04-09-2014, 06:43 PM | #18 |
Rep 360
If you fold the mirrors using the button inside the car, once you lock the car, they of course stay folded in. Under these circumstances the mirrors do NOT unfold on unlocking the car. This is absolutely right as it is possible that the driver may have folded the mirrors in using the button (whilst you are still in the car) to fit the car in a narrow gap, so you wouldn't want the mirrors to unfold automatically (e.g. if the passenger door is close to a wall/gatepost).
If, however, the OP is saying they folded the mirrors by pressing and holding the lock button on the key, there is no reason why the mirrors shouldn't unfold on unlocking the car, so this means a trip to the dealer. |
04-09-2014, 07:15 PM | #19 | |
Rep 386
04-10-2014, 04:31 AM | #20 | |
Rep 3,445
Drives: G22 M440D
It is handy for ferry trips. And probably for your dogs. D.
Escort Mk1 RS2000 (2.1 2x44IDFS, BVH, Kent FR32, 5spd, 180 BHP) : M440D ¦ Previously : F32 435D : F32 430D M Sport sDrive, 335D E92 2006
04-10-2014, 04:42 AM | #21 | |
Rep 20,651
Although it is fun leaving daughter in car with alarm fully set and her unable to move about without setting it off. Loads of fun. |
