07-06-2019, 09:24 PM | #45 | |
Rep 10,473
I have swapped F80 to F30 and it's perfect. Wondering if you attempted to swap F82/M4 Mirrors to your F30. Those do not have same mounts. |
07-07-2019, 01:14 AM | #46 |
Rep 128
hmmmm i didn't consider this but it might be possible.. i will get with the seller to confirm. The auction i won said it was an F80 m3 but you know sometimes these guys don't even know what they're selling.
07-07-2019, 01:16 AM | #47 | |
Rep 10,473
They don't. |
07-07-2019, 01:20 AM | #49 | |
Rep 10,473
There entire run of F30 use the same side mirror structure which is attached differently than the F32. https://www.realoem.com/bmw/enUS/par...;q=51167245291 |
07-07-2019, 01:52 AM | #50 |
Rep 128
yea man i dont know.. it was super annoying when it wasn't bolting up right. i mean it's on pretty tight with just 2 bolts but not exactly what i expected when i tackled this project.
the top pic is the f30 and the bottom is the f80 mirror. it might be a little hard to tell but the f80 bottom mounting points are wider than the f30. Maybe they made a change later down in the years? i don't know.. i'm waiting for an answer from the seller to see what year these mirrors were from. |
07-07-2019, 12:01 PM | #51 | |
Rep 10,473
https://www.realoem.com/bmw/enUS/par...;q=51168059413 I don't know how many times I can repeat it. There is clearly a difference in the 2 pics as to the bolt position. What are the last 7 of the VIN of your car and the same from the donor vehicle? The only other possibility I can think of is that the replacement is a Shadowline S760A and yours is not a Shadowline, though I would be surprised if they were not bolt compatible. Both my car and the donor were Shadowline and they both bolted up perfectly. Again, the replacement mirror IS a Shadowline. |
07-07-2019, 04:11 PM | #52 |
Rep 128
i'm thinking these are probably f82 mirrrors even though it clearly says f80 inside the mirrors. It's all good.. they fit snug but only down fall is 2 bolts vs 3.
07-07-2019, 09:02 PM | #53 | |
Rep 10,473
You have potential leak issues as well as the possibility as the mirror being ripped loose or off easier. |
02-20-2020, 11:56 AM | #54 |
Rep 309
I actually bought used mirrors and planned to do this. What seal did you use on the f30? the stock or the f80 mirror seal?
02-20-2020, 12:02 PM | #55 | |
Rep 10,473
Have a friend who is shop foreman at BMW Dealer. We examined the F80 seals and looked at the F30 seals in place. Decided they really were 99% the same and didn't think it would be an issue. So left F30 in place knowing I might have to change. Thus far, have not seen any sign of leaking or why the F30 Seal would not work. Usually I always state BMW tries to keep as small of number of parts as possible so they usually want parts like this that fit multiple models. Also see comment above about bolts. So I assume they must have a reason for the differences. I just haven't figured out what it was. |
02-20-2020, 12:20 PM | #56 | |
Rep 309
02-20-2020, 01:31 PM | #57 |
Rep 39
https://emnotek.com/collections/3-se...f30-f32-f87-m2
I have these on my F32. They look and fit great! They also have painted. |
02-20-2020, 03:59 PM | #58 | ||
Rep 10,473
