BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Guide to Upgrade 6.5" Screen to 8.8" Screen HU_ENTRYNAV
      07-09-2019, 04:32 PM   #397
MarkoSK
Drives: BMW G20 330eX
Originally Posted by guigui92350 View Post
Is anyone already tested the 8.8 TOUCH screen on entry_nav2 headunit ?
I just receive mine (non TOUCH) but I do not remember I read that the TOUCH one will not work.
Correct, the only confirmed 8.8" screen that works with ENTRYNAV2 is the non-touch (6550)6822626.
Touch screen comes only with professional nav (NBT_EVO head unit).
      07-12-2019, 02:36 PM   #398
guigui92350
Drives: 118i M Sport Ultimate
Hi all, I have know receive what I need : new screen, wifi antenna, trim tools, and have scheduled remote coding session with Steve, but I'm a little bit afraid with dash removal. I never used the trim tool before. How to use it properly without damage the dash ? Which one is the most suitable (there is some flat, other with round part).
Any avise will be really appreciated, I plan to do it next week.
I have F20 LCI2.
Of course I will post some pictures of the operation, before and after
      07-14-2019, 07:27 AM   #399
Clear_Blue22
Clear_Blue22's Avatar
124
Drives: 2018 230i MSport
2018 BMW 230i  [0.00]
There is a thread on it and I uploaded some pictures of the LCi to it as well. Your best bet is to watch the video from kies motorsports. He explains it. However it's pretty simple and take a little bit of strength to pull it out. The tabs are large and should not easily break. Good luck
      07-16-2019, 01:08 PM   #400
guigui92350
Hi all,
Removing the dash was the easy part. The disaster starts after.
First I try to plug the wifi antenna I bought behind the head unit and there is suitable ******ion.
Secondly, when I try to put the screen I bought (part 9387547), it does not fit too. My original screen back is symetric, and the one I bought have the right side larger than left side.
Is there a total mistake with my VIN/HU version ?
Here is the picture :
Back of the HU
Original screen back
Wifi antenna plug.
      07-16-2019, 02:37 PM   #401
guigui92350
full HU back
      07-16-2019, 06:24 PM   #402
Clear_Blue22
124
I ran into the same issue with my screen. You need a screen out of a 3/4 series. It has a symmetrical backing. It's something new they changed on the 2018 and newer. Bonus, the symmetrical screen is cheaper since the 3/4 series have had them for a while since they got the LCI refresh sooner. I believe my screen is out of a 2017 330i. I'll look for the part number I ordered when I get a chance. For the WiFi issue I'm not sure.. mine came with it installed already. My guess would be it's the blue connection that's empty on yours and you just have the wrong antenna for it
      07-17-2019, 01:26 AM   #403
guigui92350
Ok thanks, for the wifi I'm not sure, Steve will try without and see if it works.
For the screen, if you can confirm the part number please (I can see this one is symetric)
      07-17-2019, 06:12 AM   #404
guigui92350
Anyone has on idea on why the HU does not have a wifi plug on the back.
That is really strange.
Could it be built-in ?
      07-17-2019, 10:24 AM   #405
Clear_Blue22
124
65506822626 is the part number screen I ordered. Works perfectly
      07-17-2019, 01:33 PM   #406
guigui92350
Ok, here is the plan.
Tomorrow we will try to activate carplay with Steve even without the wifi antenna.
If it does not work, I will not change the screen at all and let all original because I don't need the big screen if I don't have navigation on it (through carplay).
If it works, I will order another screen (the one for F3x with symetric back).
      07-17-2019, 02:10 PM   #407
Clear_Blue22
124
So the CarPlay might still work. Mine has worked without WiFi turned off on my phone but it's very slow and laggy. For the screen you can actually use the smaller one with CarPlay. In fact the screen size for CarPlay is the same on the larger screen. The right edge of the screen it blacked out, but you can also fill it with split screen. On the smaller screen I'm pretty sure that it will fill the entire screen.
Are you sure you ordered the correct WiFi antenna for your car? The best place to check is realoem.com
      07-17-2019, 02:34 PM   #408
guigui92350
Yes, I want to use split screen with both carplay and spotify.
I can't find the reference for the wifi antenna on realoem.com.
I don't want to have slow and laggy carplay, I prefer to not have it at all, so will see.
      07-17-2019, 02:37 PM   #409
guigui92350
How can it works with Wifi off ??
      07-17-2019, 02:58 PM   #410
guigui92350
After checking your post, I'm sure we don't have the same HU.
Mine does not have CD player, yours does.
      07-21-2019, 02:45 PM   #411
guigui92350
Hello,
So here the conclusion of my coding session with Steve : no possibility to activate carplay because there is no wifi integrated and no possibility to add an antenna. He tried several things without success.
So I give up and will keep my car as it is wihtout carplay and with the small 6.5 screen (because i just use it to display album cover with spotify).
Thanks to all for your advises.
      08-03-2019, 05:04 AM   #412
guigui92350
Hi,
I finally ordered the screen part number 65506822626.
It fits perfectly with the dash...but it stay black.
I change Display_Variante to breites_display.
Display_Resolution was already set to 10.25_1280x480, I tried to change to 8.8_1280x480 but screen stay definitively black.
Then I try to modify another setting what was on Apix2, I tried all the value including auto, the screen now display "NO SIGNAL", so the screen is working but nothing display.
Is anyone have an idea of what goes wrong ?
      08-03-2019, 05:43 AM   #413
MarkoSK
Hi,
HU_ENTRYNAV2 requires a slightly different coding, double-check if you have coded these values correctly:
3005 DISPLAY_PIP_CONFIG:
  • CID_DISPLAY_SIZE = 8.8
  • CID_DISPLAY_RES = 1280x480
  • DISPLAY_VARIANTE = breites_display
EDIT: No need to change Apix2 settings, try reverting them back to the original values.
      08-03-2019, 05:52 AM   #414
guigui92350
I finally found those settings and the light came on
Thanks Marko
MarkoSK121.50
      08-03-2019, 06:17 AM   #415
MarkoSK
Thanks Marko
You've welcome, enjoy your new screen!
PS: You can now enable splitscreen (right-tap with iDrive button, it's under Options).
      08-03-2019, 09:34 AM   #416
guigui92350
It seems that the option is greyed out
      08-03-2019, 09:36 AM   #417
MarkoSK
It is grayed out if your engine isn't running. Try turning your ignition on.
      08-03-2019, 09:38 AM   #418
guigui92350
Engine is running, I also tested with engine running and car stop, still grey.
