07-03-2019, 07:46 AM | #1 |
Rep 197
N55 DIY Oil Cooler Upgrade Free
Has anyone done the oil cooler bypass on our n55? Can someone chime in on the mechanics behind the opening of the oil cooler to allow fluid to get to the cooler?
I am looking for the DIY version in which we invert the location of the piston already in place. Lodging the piston inside the chambe in putting the spring on top, versus the spring going in first and the piston on top. Is it safe to do such a conversion. The oil will now always run through the cooler. Will the piston every get stuck in the chamber? What are some cons? Some insight would be great as to what benefits have been noticed. I am hitting as high as 247F oil temps in this summer heat and need to solve this quick. |
07-03-2019, 08:09 AM | #2 | |
Rep 3,947
zinner559.00 |
07-03-2019, 08:19 AM | #3 |
Rep 197
Well i used 0w40 on an oil change last week. Burnt through half a qt with add oil warnings. Topped it off for work. Then drained and refilled with 5w40 from walmart last night. Band-aid until the Liqui Moly Molygen 5w40 comes in for the final cleanse lol.
Now i am noticing Oil temps reaching 245F+... too much for comfort.. I drive hard and Miami is now 100F in the day..... This video DIY looks legit for bypassing the oil cooler so it is always routed to the cooler, but i need some experience to back it up. |
07-03-2019, 08:36 AM | #5 |
Rep 197
I peaked 247F. I dont think there is any catastrophic issue. I lost <0.5qt after 600 miles, insanely hot ambient temps, thinner oil (accident), and doing logs for a new tune. My fan & coolant brought it down to 220F quick. Just i would proactively like to avoid reaching 245F. Productive comments from the community would be appreciated |
07-03-2019, 09:25 AM | #7 |
Yoda of mods
1673
Rep 3,004
Drives: X5 RWD
The original poster of that video had it done for more than a year with no issues and reversed it in the winter. You will be fine.
jondagger90.00 |
07-03-2019, 09:32 AM | #8 |
Rep 197
07-03-2019, 10:25 AM | #9 |
Rep 211
I have almost the opposite issue. In Phoenix area with temps in the 105+ range my oil temps are running in the low 200's. When pushed I see maybe 210-220. I don't recall seeing such low temps in past summers.
Mineral Gray - Active Autowerke Stage 2 - MPerformance Suspension - VRSF CP - CTS Turbo IC - Catted Fabspeed - Akrapovic - HRE FF15
07-03-2019, 03:35 PM | #10 |
Rep 470
Oil temps near 250 should not be alarming. 280-290 is warning/limp mode zone.
FWIW, when I switched to Rotella T6 on my N55, I noticed oil temps rise by about 10 degrees on average. Was on OEM 5W-30 before that.
Current mods
Rockford Fosgate P3 // JBL MS-A5001 // MiniDSP Ultra Racing Strut Brace // AFe Pro Dry S // PS2 // Custom Inlet // DV+ // FTP Boost Pipes // VRSF Race IC // VRSF Downpipe // ECUTek Protune @ 5280' |
07-03-2019, 09:04 PM | #11 |
Rep 3,947
Yeah, that happened this past weekend at Summit Point - Jefferson when my car was shared in back to back sessions. The car was run hard at a HPDE for 4 hours straight. HPFP threw a code.
07-03-2019, 09:18 PM | #12 |
Rep 2,357
All that mod will do is make it take a little longer for you oil to heat up. It will not improve the efficiency of your oil cooling system.
Another thing you could try is the flash the Performance cooling with MHD if you have that. Lowering water temp to 95°C will also help on your oil temps.
(A Dane in China) |
07-03-2019, 10:03 PM | #13 | |
Rep 5,393
jondagger90.00 |
07-03-2019, 10:53 PM | #14 | |
Rep 3,947
07-03-2019, 11:23 PM | #15 | |
Rep 2,499
The car is MEANT to run oil at 240-250. Any decent synthetic oil can EASILY last all day at 250F. If you're losing oil, just try a different oil or there might be some other issue (oil leak, perhaps). Notice how the oil temp gauge is centered at 250degF? That's not a coincidence.
If you run your oil too cold, you will advance engine wear. It'll take forever for your oil to get up to temperature (minimum you want to run is 210degF) and until your car is up to that temp, it is not running optimally. BMW has thousands of automotive engineers working there. They've made oil thermostats precisely to work at specific temperatures. Why would they NOT use an oil cooler that is installed on your car? Makes no sense. If it was better to run the oil cooler at lower temperatures, they would have tuned it that way. Unless you are tracking the car or going over 260degF, there is zero reason to modify the oil cooler at all. Some good points from this page: Quote:
jondagger90.00 |
07-05-2019, 10:37 AM | #16 |
Rep 211
If your temps are running too high you might check with your tuner. As I said earlier, my temps are running lower in the high summer heat. I contacted AA to see if it was tune related. Nic replied that the Stage 2 tune has lower coolant temp targets and a lower ambient temp threshold to enable active cooling.
07-05-2019, 02:32 PM | #17 | |
Rep 1,105
Check out the thread for more info. I live in Florida and definitely notice a reduction in oil temps
07-06-2019, 04:41 PM | #18 |
Resident Pedant
503
Rep 792
Fresh Molygen 5W40 in my car is hitting about 255F-260F with ambient Alabama temperatures in the high 90s. That temperature is at the middle of the gauge for a reason...
'15 F30 335i 8AT Estoril II/Black (12.218 @ 114.94mph)
MHD Stage 2+ 93 / XHP Stage 3 / M-Goodies / K&N Filter / ER CP / CSF IC / NGK 97506 / ER DP / Michelin A/S 3+ |
07-08-2019, 09:34 AM | #19 |
Rep 1,127
240-250 is fine. You want it to warm up fast and stay at the design temps. Otherwise the motor will not run at peak performance. The car will run differently when the temps are low in order to warm it up. It might not run the emissions test, different fueling and spark maps, etc if it never warms up, just asking for problems messing with that thermostat.
07-08-2019, 11:13 AM | #20 |
Rep 949
Free mod does help but it's not as good as the bypass plate because the free version has small holes in it which allow some oil to bypass cooler all together.
07-11-2019, 08:20 AM | #21 |
Rep 1,499
Why not just put your car in sport mode and it will open the thermostat and target 225
07-11-2019, 09:51 AM | #22 | |
Rep 197
Comes to find out, my oil level sensor could be a little wacko. I drained it and got nearly the full oil amount originally put in. Ive been through 4 oils this month, cleansing over and over. Old BMW 5w30 oil. Then 0w40 Mobil1 "burning issue", wasnt actually burning. Then cheap Castrol 5w40 from walmart for a few days. Now running 5w40 Liqui Molygen, good stuff IMO. With my latest oil i got low oil notification AGAIN. I put in 6.8 qt (MAX level). I added 0.15qt, level checked and (MAX level). After work, cold start the car and AGAIN, low oil. I drove home. Checked the level once hot and MAX level. I am not going to freak out if I get a notification anymore lol. |
