03-27-2019, 08:15 AM | #23 | |
Cheapskate
4447
Rep 4,993
If anything he would have corrected all of those things by reinstalling it in the correct orientation. |
johnung4526.50 |
07-16-2019, 06:26 PM | #25 | |
Rep 290
Couldn't find the rear leveler for the longest time, but it's there! Just found it today. It's mounted forward of the left-rear (driver's side) camber arm, right behind the drive shaft. Getting it back into the right position required loosening the mount to the camber arm using a single 10mm. The post that helped me eventually locate it was this one: https://f30.bimmerpost.com/forums/sh....php?t=1083978 Whew! Thanks all for the info. Last edited by ali820; 07-21-2019 at 07:42 PM.. |
07-19-2019, 01:13 PM | #26 |
Rep 468
Just as HenryX said. Very common for a sensor arm to get reinstalled in the wrong direction.
I checked my car on Hella Light align machine after installing the B8's and Eibachs and the beam was 100%.. These lights are self leveling and do not require an adjustment. What If you had 5 heavy people onboard and their luggage, where the car will naturally compress and sit lower, you wouldn’t adjust the lights or would you .. |
shiftdnb376.50 |
09-10-2020, 11:49 PM | #28 | |
Rep 89
Aldor2787.00 |
09-18-2020, 07:49 AM | #29 |
Rep 4
headlights adjustement is a crucial thing in the road safety. Read the guides or leave it to professionals. But in any case I would not recomment ignoring headlights adjustement.
09-03-2021, 12:47 AM | #30 | |
Rep 27
09-03-2021, 10:15 AM | #31 |
Rep 298
I just had to do this as mine was also inverted. You'll have to remove the wheel for sure but the arm that connects directly to the sensor has to be parallel with the control arm. If not, it's rotated 90 degrees (ish) and pointed down.
The pictures on the first page show the correct orientation (dotted line). Once I inverted that middle pivot point, the headlights adjust to the proper level. |
09-11-2021, 03:43 PM | #32 |
Rep 145
Drives: 2017 F31 330xi
I just had to do this as well. I had the Eibach springs installed in April but I guess I don't drive that much at night. The last couple of times I've been getting flashed by angry cars coming at me so I figured something was up.
It was super easy. After removing the wheel and locating the sensor arm, I just gave it a light pull and it came into place. I didn't need to take anything off. The sensor is mounted on a light metal bracket that has a fair bit of flex. |
09-13-2021, 08:03 PM | #33 | |
Great Teacher
1084
Rep 1,305
Drives: 06 e91 325ix
over Terra (one of 1), Nav, Sport, L7 A few OEM+ mods: MTech front bumper, MSport wheel & handbrake, 4AD trim, full rear shades, more to come… |
10-12-2021, 01:18 AM | #34 |
Rep 54
Drives: BMW 435i
Strange mine feel like they're pointing lower after lowering.
04-03-2023, 03:12 PM | #35 |
Rep 10
After fitting my Eibachs, I found the headlights to be aiming downwards. Had fitted them myself but didn’t disconnect the headlight mechanisms and may have caused a bit of damage/ misalignment. Following this post, I took a look at the sensors (passenger side on RHD car). At the front, my wheel lining had come away a little bit and looked to be fouling the sensor mechanism. At the rear, the sensor looked to be a little twisted and the bracket itself looked to be a bit twisted. Straightened the bracket although not sure if I’ve straightened enough. Headlights now are better positioned. Now that I’m focusing on them, not sure if they are still a fraction lower than before lowering. Will see how it goes.
