03-11-2017, 10:04 AM | #1 |
Rep 79
Water spots
I have sprinklers next to my drive way and the spray from the sprinklers is getting water on my car. The system uses reclaimed water and when the water dries it leaves the hard water spots
Unfortunately I can not adjust the sprinkler system as it is maintained by my hoa. Are there any products out there that will work to get rid of the water spots? Thanks! |
03-22-2017, 11:17 AM | #4 |
Rep 536
Drives: 2013 335xi Alpine White
A good sealant with hydrophobic qualities may help to minimize the size of the water spots.
Use a leaf blower to blow dry your car after the sprinklers shut off - just be prepared for the neighbors to give you weird looks |
03-22-2017, 07:44 PM | #5 | |
Rep 79
Thanks. I was looking around and found some sealants I am going to give a try. |
04-09-2017, 09:14 PM | #8 |
Rep 79
04-10-2017, 11:09 AM | #9 |
Rep 1,101
Happy to hear that the vinegar works but won't an acid like vinegar just take away your sealant also? I wonder if there is a product that will take away the water spots but not be strong enough to remove your wax/sealant protection layer? I don't really have hard water so I can't offer any advice here. However, having a layer of sealant on that paint is important so there hopefully is something out there that will work for you.
04-10-2017, 03:28 PM | #10 | |
Rep 79
I only tried the vinegar once and since it worked now I just make it a habit in the morning to go out and dry my car on the days when the sprinklers go off. Not the best solution but as you said I definitely want to keep my clear coat. Lol |
04-10-2017, 04:19 PM | #11 | ||
Rep 715
I might look into something like opticoat eventually for the extra peace of mind. It even mentions here that it helps to prevent water spotting: http://opticoat.com/page/opti-coat-pro-plus |
