BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > Big Boost Turbo - B58 Stage 3 turbo. 500+ WHP on stock fuel.
proTUNING Freaks
      04-29-2017, 10:17 AM   #1
Thus
Drives: 340i xDrive m perf & track pkg
http://www.***********.com/showthrea...732#post756732
We believe we have set a new world record for the B58!
534WHP and 501 FT-LB of torque! Stage 3.2 (5959mm turbo), no PI nor Meth.
Thanks @Terry@BMS and all team at BMS for all the support!
      04-29-2017, 01:28 PM   #2
Montego92
Drives: 2016 M3
Bogus link man...
      04-29-2017, 02:26 PM   #3
Beek
Beek's Avatar
Drives: Most folks crazy.
Bogus claim too I'm thinking, 500+ WHP without a DME Flash?
'16 340xi Mineral Grey/Black Leather, MPSS on 18" 398 Orbit Grey wheels, ZF 8HP50, MPPSK+CF Tips, ZTR, ZMP, ZTP, ZCW, ZDA, ZDB, Black Kidney Grilles.
'09 Outback for a beater and grocery getter.
      04-29-2017, 07:12 PM   #4
kern417
Cheapskate
4447
Drives: 2018 440i |2016 340i | 2010 X5
http://www.n54tech.com/forums/showth...922#post534922
can't comment on it's validity. i just google the quoted post.
edit: i guess xxxxxx is blocked on here or something?
edit2: ok i removed the other link. idk what the hell is going on. i guess this forum doesn't like the other one. sheesh.
Youtube/Instagram/TikTok: @kern417
      04-29-2017, 07:20 PM   #5
iMinLuv
iMinLuv's Avatar
Drives: BMW 340i M-Sport track pkg
It's port injection. It's likely legit
340i M Sport Track Package | JB4 | Dinan Exhaust | BMS intake | CG catted 5" DP | HR sport springs | WMI | Zito Zf01 |
      04-29-2017, 07:46 PM   #6
kern417
Cheapskate
4447
also looked at the logs, their running 14afr through the entire rev range. i could see it being possible but not suitable for daily driving.
      04-29-2017, 07:53 PM   #7
Beek
Beek's Avatar
Thread title said "on stock fuel" then in quote it says "no PI nor Meth."
Oh well .... nice numbers for sure.
      04-29-2017, 08:48 PM   #8
kern417
Cheapskate
4447
from what they said it's stock fueling, just race gas. no port injection or meth.
      04-30-2017, 09:27 AM   #9
jpsimon
Team Zissou
jpsimon's Avatar
Drives: 2022 AWD M3 Comp - SMB
Race gas, running very lean. It's super early in the development, but great to see the progress. Once we can flash these cars it's going to be amazing. Either way once the port injection is in it's going to kick some ass.
      05-01-2017, 07:03 PM   #10
PeterA90
Drives: 340xi
The turbo makes power. This because it's manifold has 25% bigger runners than the stock one, also the turbine housing has a much bigger A/R. Terry has gotten the stock turbo up to 440ish with e30... just because it has those high numbers doesn't mean the car is gonna run right or safetly. I suspect with properly fueling it will do 520whp or more safely. And if they want a dyno glory run I'm sure it can be in the 600whp territory.
      05-01-2017, 07:31 PM   #11
kern417
Cheapskate
4447
500whp and full boost at 4-4.5k would be really good.
      05-02-2017, 08:40 AM   #12
jpsimon
Team Zissou
jpsimon's Avatar
more updates coming through:
We made some changes in fuel. Last time we used pump gas mixed with Sunoco 260GT Plus, and today we made some dyno runs using un-mixed Sunoco 260 GT Plus, this made significant improvements in power and torque.
      05-02-2017, 09:26 AM   #13
insanecoder
Drives: 340isDrive
So whats going on here.. they running with a larger turbo, running lean, compensating by running 100 octane? What kind of psi is experienced?
      05-02-2017, 09:49 AM   #14
kern417
Cheapskate
4447
if you read the thread on n54tech you'll see all of the answers to your questions. it's an aftermarket turbo and manifold. they're running Sunoco 260GT Plus (104 octane) running 14.5+afr to redline. 20+psi on some of the runs.
http://www.n54tech.com/forums/showth...388#post535388
      05-02-2017, 12:12 PM   #15
SingleturboVert
Drives: E93 335i
What site is it? You linking to porn or something? haha
      05-02-2017, 12:44 PM   #16
jpsimon
Team Zissou
jpsimon's Avatar
bimmerpost blocks links from n54tech
      05-02-2017, 02:33 PM   #17
iMinLuv
iMinLuv's Avatar
Worked for me
      05-02-2017, 04:04 PM   #18
jpsimon
Team Zissou
jpsimon's Avatar
Originally Posted by iMinLuv View Post
Worked for me
Maybe they just changed it for n54tech, but for instance if you go to bimmeboost and try to post a url here it shows up like this:
http://www.***********.com/showthrea...-turbo-upgrade
      05-02-2017, 06:59 PM   #19
kern417
Cheapskate
4447
no they blocked the bimmeboost link i posted (you just made a typo but showed me a way to get past their censorship). even when i typed BIMMER and then BOOST the wording gets replaced with "admin notified," hence my 2nd edit to just delete it altogether. i have no ball in the game so i could care less about the forums beef with eachother, i'm just glad all of the info is cross-posted on n54tech.
Roki187126.00
      05-02-2017, 08:38 PM   #20
Mr Carrots
Drives: Bmw
While great from an academic perspective they seem to be saying the car likely wouldn't even make it through a 1/4 mile to get real world numbers?
I'm hoping a flash to fix the fuel limit isn't 5 years away because I'd love to see what my car is capable of with the limits removed
      05-02-2017, 10:02 PM   #21
Roki187
Roki187's Avatar
126
Drives: Rocket :-)
Hoping for the same thing. How come everyone is so quiet about flash tune progress (if any has been made)
500 all wheel beemski would be a blast to daily
      05-03-2017, 11:38 AM   #22
Juan@BigBoost_Turbo
Tuner
Drives: F22 M235i Mineral White
Hello Guys,
I am Juan from BigBoost, LLC (BigBoost Turbo)
Our current M240i setup is:
BigBoost stage 3.2 turbo
BigBoost Stainless steel Race DP
BMS JB4 Map 7
BMS Billet aluminum intake
We say this AFR and Trim numbers are safe for some dyno runs and some few races, but not for running it hard constantly. This should be fixed with WMI.
We will have our PI kit ready in 1 month.
We are now taking pre-orders for the Turbo Upgrade, 650 USD off retail price
http://http://bigboostusa.com/produc...e-3-turbo-b58/
For people who are local in South Florida or want to send their car in we offer installation service, with a discount.
Our contact info is:
info@bigboostusa.com
sales@bigboostusa.com
(786)375-5321
FSociety3812.50
