01-23-2018, 08:22 AM | #23 |
Rep 147
Drives: 2015 435i Gran Coupe
01-23-2018, 11:04 AM | #24 |
Rep 147
I cant thank you enough!
Do you think this one would work? https://www.amazon.com/Degree-Angled.../dp/B00B1U6I54 |
01-23-2018, 11:06 AM | #25 | |
Rep 235
Current - 2018 M2 | VRSF Chargepipe | VRSF Catless Downpipe | Dinan Catback | Turner Motorsports Intake
Previous - 2016 340i M-Sport | AWE Tuning Touring Edition Exhaust w/ Non-Resonated Performance Mid Pipe | Agency Power Intake | Active Autowerke Activ-8 | VRSF Catless Downpipe |
01-23-2018, 01:00 PM | #26 | |
Rep 147
So, when testing to see if the CEL will come back, how did you go about clearing and waiting for the system to reboot? Last time, I tried (i had leak at the vclamp and thought that was the issue), i pulled the neg for 30 minutes to clear the light. The light came back after about 250 miles. Thanks again. |
01-23-2018, 01:02 PM | #27 | ||
Rep 235
01-29-2018, 08:08 PM | #28 |
Rep 1,124
Fabspeed makes a O2 spacer with a mini cat built into it. My AMG buddy has one and it keeps the CEL away and even sets emissions readiness. For what it's worth any tech can smell / hear a catless car a mile away.
03-17-2018, 08:46 PM | #29 |
Rep 1,503
why is it bad if the sensor is too far from the exhaust flow? Isn't it better the farther it is (to reduce how much O2 is being sensed)?
FBO M235i r
F80 M3 |
03-17-2018, 09:07 PM | #30 | |
Rep 958
Drives: 2016 F36 435x MSport
Throw a catless, or even some high flow catted in the mix, and it will detect a higher downstream voltage against its threshold compared to the upstream, thus throwing the cat efficiency code.
2010 Mazda RX8 - Sold (11/17)
2016 BMW 435xi GC - Current |
03-31-2018, 09:18 PM | #31 |
Rep 147
So i finally had a chance to get off the 02 sensor. What a pain. Now my issue, how did any of you put on the straight spacer and then the 02 sensor. It barely fits with just the 02 sensor. I think i have no choice but to try the 90 angle one. Is that one too long ? Any issues with that?
03-31-2018, 10:43 PM | #32 |
Rep 147
So tried angle spacer. Same error. Scanned the ecu and got
MID 02 TIB 02 Lean to rich sensor threshold : not ok MID 21 TIV 81C: Catalyst monitor bank 1: not ok Any ideas? |
03-31-2018, 11:08 PM | #33 |
Rep 147
04-01-2018, 12:34 AM | #34 |
Love to Drive
197
Rep 602
04-01-2018, 06:37 AM | #35 |
Rep 147
I know this. There is no space to use a straight spacer.
I have a N55 which maybe the reason |
04-01-2018, 08:51 PM | #36 |
Rep 147
So I was hoping someone could clear this up for me. So yesterday when i put the angled spacer, i saw that the cel was still on and the o2 sensor was not ok via the torque app. I assumed that the two errors on the scan mid 21 tid 81 & mid 02 tid 02 was still present that it did not fix the issue. I was so tired that i never tried to clear the ecu. Now with some sleep aand more reading i may have missed a step and not cleared the error. Should i go back and try again and this time clear the ecu. Sorry about the rant. I should have stopped when i felt tired and rested more before tacking this
04-01-2018, 09:07 PM | #37 |
Rep 958
question, when you installed the angled sensor, what direction did you face it ? down, or up ....
Asking because i want to make sure while you are troubleshooting, that you dont have the angle facing downwards because you will risk damaging the o2 sensor as condensation builds up in the spacer.
04-01-2018, 09:54 PM | #38 | |
Rep 147
Any ideas or suggestions? |
04-01-2018, 10:07 PM | #39 |
Love to Drive
197
Rep 602
04-02-2018, 07:59 AM | #40 | |
Rep 147
Does anyone know if the torque app clears the light right away or does it take a few drive cycles. |
04-02-2018, 08:04 AM | #41 |
Love to Drive
197
Rep 602
All should clear the light immediately unless you have a bigger problem and the lights come back just after clearing it...
04-02-2018, 03:47 PM | #42 |
Rep 1,503
The problem is that he is N55. You cannot trick those motors the same way you can with the B58. Former N55 owner here..
FBO M235i r
F80 M3 |
04-02-2018, 04:00 PM | #43 |
Rep 147
04-02-2018, 07:29 PM | #44 |
Rep 1,503
Unfortunately, you got no options besides tuning with flash or JB4.
FBO M235i r
F80 M3 |
