04-02-2021, 11:57 PM | #1 | ||
Rep 3,539
Camber Plates Design Comparison
For a while I've thought, "All the monoball camber plates are pretty much the same." Having the recent luxury of having three different makes of monball camber plates (Ground Control, Vorshlag, and Millway) and inspecting them further I've found that my perception was really wrong. There are clear design differences with each, translating into strengths and weaknesses.
As a follow up, if you're wondering how to replace the monoballs in your Millway camber plates I made the video below on the process. Quote:
-My YouTube Channel for some of the best DIYs and in depth information Please don't PM me for suspension recommendations unless interested in paid private consultations. Last edited by FaRKle!; 04-14-2021 at 10:07 AM.. |
04-03-2021, 06:42 PM | #2 |
Rep 69
Great info as always! Thank you very much for posting. How did you know I spent the last 2 days reading through old posts on these camber plates, but came away still wishing for a direct comparison? (Ha!)
I've been trying to decide on which to buy as I have a B16 PSS10 kit waiting for install. Going to have plates done at the same time. I think I am going Vorshlag. I like the articulation and hardware. One thing I have to consider is my aftermarket strut tower brace; I just looked at the Vorshlag on their website and it looks like they use bolts from the bottom up with nuts on top, is that right? Thanks again for the side-by-side comparison!
2013 335i M-Sport || MPPK || M-LSD || M-BBK || VRSF CP - DP - FMIC || Bilstein B16 PSS10 || Vorshlag CPs
Last edited by Foxtrot3Zero; 04-03-2021 at 07:01 PM.. Reason: Hardware for Vorshlag? |
04-03-2021, 11:15 PM | #3 | |
Rep 3,539
The Vorshlag has bolts that screw in from the top down, the same as the OE top mount.
Foxtrot3Zero148.50 johnung4528.00 |
04-04-2021, 08:30 AM | #4 |
Rep 891
Great video, Farkle. I have a few thousand trouble free miles on my Millway monoballs, but once they expire I will be replacing the slider assembly with the Street version. Thankfully it looks like a very simple conversion, much easier to deal with than the keyed lock ring you point out.
04-04-2021, 10:22 AM | #5 | |
Rep 785
Because Mr farkle is the all knowing lord of f3x land lol. Thanks for another great breakdown of some aftermarket kit
335i rwd auto, 2015 with m performance LSD and Dinan stage 2. Cts charge pipe, mad 5" stepped intercooler.
Foxtrot3Zero148.50 Polo088161610.00 |
04-04-2021, 07:35 PM | #6 | |
Rep 3,947
So my current front negative camber spec is -2.25. This is with the wheel hub correction for an additional -.5 and the M Performance Suspension kit which gives it an additional -.5 to -.75 of camber. The concern is the inside edge wear on my winter tires. I'd like to get back to maybe -1.5 to -1.75 so there's less tire noise in the winter season and not have the tires ride that much on the inner edge. However, at the track, I'd like about -2.75 to -3.0 to keep the front outer edges from getting chewed up too bad. |
04-04-2021, 09:09 PM | #7 | ||
Rep 891
This needs verification but I am almost certain the F3X Millway plates can accept either the Monoball or Street bearing/slider assembly. The Street Rebuild Kit is available on Millway's site.
04-05-2021, 09:01 AM | #8 | ||
Rep 1,934
04-05-2021, 04:28 PM | #9 | |
Rep 3,947
Also, I'm running the Michelin X-Ice tires which are considered studless winter tires. Performance winter tires should be slight better with negative camber and inside edge wear. |
04-05-2021, 05:50 PM | #10 | |
Rep 3,539
04-05-2021, 06:42 PM | #11 | ||
Rep 1,934
04-14-2021, 10:07 AM | #12 | |
Rep 3,539
04-15-2021, 07:06 AM | #13 |
Rep 8,493
FaRKle! - that's a very informative video, as always.
It's interesting what we each look for in various products. Having run (briefly) Vorshlag camber plates on my car, having them removed due to NVH, and subsequently understanding their construction personally there's no way I'd choose to direct the entire front vehicle load through a monoball. It's just asking for premature wear, irrespective of the larger diameter bearing compared to the GC and Millway units. Vorshlag may have updated the design of its camber plates, and the components, but at the time my suspension shop removed the bearings and identified them as from the cheaper end of the market. Millway kindly made a custom housing for my Millway camber plates and installed my choice of bearing. These larger bearings are used in F1, WRX, DTM and other motorsport applications and have a significantly higher rating for axial and radial loads. It was an experiment on my part, however, they have lasted <10K miles before they have started to knock/rattle when the car encounters short amplitude / high frequency irregularities in the road surface (crappy road surfaces), which just goes to show that monoballs really aren't suitable for axial loading. Of the three units that you've reviewed I'd still opt for the Millway camber plates if I was making the choice again. The minimalist design works well and inherently has fewer points of failure. Unless/until someone develops a better solution, monoballs are a 'necessary evil'. I'm not convinced that the design of the Millway poly/steel 'sandwich' is fully resolved, but it should provide good NVH isolation and for many people this design will provide a good compromise between isolation, range of adjustment, and damper response. Keep up the great work with the videos - they are very useful.
MacklinUSOB518.00 |
