10-14-2021, 05:59 PM | #1 |
Rep 22
Loss power and DSC light
So today I got my tires rotated. They found a nail in my tire patched it up cool. Well after dinner with my brother and girlfriend I turned on the street and my car started sliding, DSC light came on and I lost power and couldn’t accelerate then it kept hesitating then finally came back on. I was in sport mode and I pulled over and smelt burning rubber and inspected tires and saw nothing. Well I saw that my wear sensor was snapped on my rear and I knew the light was on because I never replaced the sensor when I swapped new pads and forgot and couldn’t reset it. What could be the issue? I was told the wires being exposed to the elements could trick the system and think something is wrong?
10-14-2021, 10:03 PM | #2 |
Rep 16,082
The brake pad sensor is a very simple device. A wire carries current out of one contact where the sensor plugs in, it passes through the sensor that's attached to the pad, a second wire carries the current back to the other contact where the sensor plugs in. Anything that causes a break either the sensor or the wires will cause the brake wear warning to be triggered. But it wouldn't trigger the DSC light. These items will:
https://mechanicbase.com/electric/ds...C_Light_Causes |
Brxzil2.50 |
10-15-2021, 02:07 AM | #3 | |
Rep 22
12-21-2021, 06:57 PM | #4 |
Rep 4
DSC fault
I was driving last night on a straight road when the DSC light came on and the brakes were definitely being applied. The temperature was about -1o degrees C. Would the potential faults in Billfitz's response apply in this situation?
12-21-2021, 10:09 PM | #5 |
Rep 16,082
I'd say it was in some way related to the ABS, which can be triggered by a number of causes, including the ABS sensors, but not likely the pad wear sensor.
