BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic Maintenance: Wash, Wax, Detailing, Repairs > Dust behind plastic cover to dashboard
      01-25-2016, 10:04 AM   #1
abinder99
Drives: 435i xdrive convertible
I've had my 2015 F33 since April. I dust/clean up the interior about once every 3 to 4 weeks. I am very careful not to wipe the plastic in front of the dash or the temperature display as I can tell they will scratch easily. However, a small amount of dust has found itself on the inside of the speedometer display. I am tempted to unscrew the piece (I notice there is a screw at the top), but I'm concerned about creating a bigger issue than I have now.
I'm doing my best to ignore it, but it is prevalent in the right sunlight and driving me a bit nuts.
Has anyone had to remove the plastic to clean behind it?
      01-26-2016, 12:10 PM   #2
WHL102
Drives: '16 GTI S, DSG, 4-Door
I haven't done it yet, but I've heard you just have to take out the two torx screws at the top and pry the clear shield off. I would suggest using rubber gloves to avoid leaving any finger prints and a can of compressed air to get rid of the dust instead of a cloth. All the plastics in the cluster look very prone to scratches/smudges.
      02-01-2016, 02:00 PM   #3
DLNDGUY
Drives: '13 328i Luxury Line
If you end up removing the cover, please post how it went.
I have marks on the inside (by the trip odometer reset button). It drives me nuts. Called my dealer and they said that the cover can't be ordered as a separate part and the entire cluster would need to be order.
      02-02-2016, 09:07 AM   #4
Orion4
I have a similar dust issue with my 13 335. The F-30 Bentley manual is supposed to be released in Mar. Hopefully that will have some guidance on removing the instrument cluster and the clear lens,
      06-20-2016, 03:06 PM   #5
abinder99
I haven't done it yet. Has anyone else removed the plastic cover of the dash? How did it go?
      06-20-2016, 09:53 PM   #6
goj
goj's Avatar
Drives: 2016 EBII 340i 6-MT
I have this too. Annoying
BMW CCA Member #516012
2016 340i, Estoril Blue, Manual Transmission, MPE, APEX EC-7
Instagram: @brandonsclean3
      07-02-2016, 08:20 AM   #7
abinder99
Well I tried it and your dealer would be correct. The plastic front does not come off. When I took out the two screws and slightly pulled, the entire cluster was coming out. I looked everywhere, and there is no way to remove the plastic cover. I am a bit annoyed, but what can you do. Not going to replace the whole cluster over some dust. I'm not that nuts. Or am I...
      06-29-2017, 09:19 PM   #8
perry8912
Drives: bmw x5
I have the same issues, any solutions?????
So annoying..
      07-10-2017, 12:44 PM   #9
abinder99
Nope. $995 for new cluster.
      10-21-2018, 11:30 AM   #10
luckstr
Drives: White BMW440i Hardtop Converti
Almost same issue. Inside of lens is 'fogged up' in certain areas. Car is still under warranty (2017 440i convertible) with only 11,000 miles. When I bring in for service next month I am going to request they eliminate, and if they have to replace entire cluster under warranty then so be it. Cannot believe that a car this expensive ($65,000) has these kinds of issues. Not impressed at all with quality of BMW (exterior paint, glass, cheap looking interior, very poor gas mileage).
      12-03-2018, 12:42 AM   #11
golf_234
Drives: E46, E90, F30
Did you have any luck with this? I am wanting to request they take care of this as well.
      12-11-2018, 09:59 AM   #12
luckstr
Sorry, not yet. When I took car in for service last week it was a rainy, dark day & the Service Advisor could not see what I was complaining about. Told to bring it back on a sunny day so it would be noticeable. I will be bringing it back in a few days; but the impression I got was that it would be replaced (entire cluster, because lens alone can't be replaced. Let you know.
      04-21-2019, 12:13 AM   #13
luckstr
Dealer replacing lens/cluster assembly (under warranty). Being done now and when I bring home I need to get re-coded.
      04-23-2019, 07:47 AM   #14
luckstr
Slight hiccup here. When dealer installed new lens/cluster unit, they could not reprogram car. Tried a whole day and finally decided the unit they received was defective and had to order a new one. Let's see how long this takes. Tomorrow will be 1 week since I brought car in. True I have a loaner, a 430 GC, but I miss my 440i convertible.
      05-11-2019, 05:46 PM   #15
luckstr
Got my 440i back. New lens/cluster and re-programmed. So far all seems ok! I had to re-do memory buttons 1-8, re-pair telephones. They put same mileage on new cluster that was on old one.
