BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic and Lighting Modifications (exterior & interior) > F30 Projector Angel Eye Headlights!
      12-20-2016, 12:29 PM   #859
RayonF30
Drives: Black BMW F30
Install complete. I got the GP Thunder 5800K
Take pics! I ordered the same light bulbs but waiting for them to come in.
Low beam off
Low beam on
Full front... terrible shot... sorry. Lol
Cutoff
Is it me or is the light pattern uneven in this pic
I think it's uneven. I don't know how to adjust I AND I hope I don't have to remove them to adjust it.
There's two adjustment screws on each headlight accessed with the hood open. One is for vertical and the other for horizontal.
From your photo you need to do both. Did you tape off the original headlight center positions? If not you can use the center of the low beam as a guide.
Congrats on the headlights
I am gonna have to read up on how to adjust them because I don't know how to not how to use the low beams as a guide.
      12-20-2016, 12:43 PM   #860
Hack14
Hack14's Avatar
Drives: 2014 320i Xdrive
Originally Posted by MONSTAR View Post
Looks good!! You need a long screwdriver to get the 2 adjustment points. Be careful with them as they are plastic and they move plastic gears.
Hoping that removing the front wheels won't be necessary as I don't have my jack or stands out here
If you can manage to get the torx screwdriver pass the fender liner then you won't need to take off the wheels.
Instead of using a Torx screwdriver, I bought a set of Torx sockets just for this install. Should allow me to get more leverage and require a lot less clearance behind the light.
      12-20-2016, 12:54 PM   #861
RayonF30
Low beam off
Do the signal lights stay on with just the DRL?
Looks damn good btw!!
Drl
      12-20-2016, 12:58 PM   #862
kreeess
kreeess's Avatar
Drives: 2013 328xi
Low beam off
Drl
WOW !!! Amazing
If it ain't broke don't fix it
      12-20-2016, 01:10 PM   #863
RayonF30
Low beam off
Drl
WOW !!! Amazing
There are true white and BRIGHT but my phone was acting up taking the picture.
      12-20-2016, 01:18 PM   #864
Hack14
Hack14's Avatar
They look really great!
Thanks for appeasing all of our many inquiries!
      12-20-2016, 01:45 PM   #865
ill250
Drives: 2013 f30
Looking good RayonF30, cant wait to install mine this weekend
      12-20-2016, 01:59 PM   #866
XKxRome0ox
e90noob
XKxRome0ox's Avatar
Drives: '08 E90 M3
http://www.gp-thunder.net/index.php/...sgp58k-h7.html
^ so GP thunder 5800k is the popular bulb choice?
i'm only going to replace the low beam bulb
2008 E90 M3
      12-20-2016, 02:16 PM   #867
kreeess
kreeess's Avatar
Drives: 2013 328xi
Yes sir that's what I got all around
      12-21-2016, 12:38 AM   #868
77cubes
77cubes's Avatar
Drives: 2013 328i xDrive
Finished mine today. These are great lights. Very happy.
Better visibility than the standard lights and look so nice. I kept the bulbs they came with for now.
Lights are nicely built and fit great.
Install was a pain. Didn't help I'm in the cold north and my garage floor is wet and dirty. The install videos were very helpful. Biggest issues were the two bolts under the lights. Definitely bend back the cover that holds the nut so you can hold the nut. I used a 10mm wrench, pic attached. Still took a long time to get those off.
I also had to disconnect the lights washer fluid tube and front sensors to get the bumper off. I got washer fluid all over. I duct taped the loose tube up.
Really glad it's done.
Thanks all for the insights in this thread.
      12-21-2016, 01:11 AM   #869
kreeess
kreeess's Avatar
Drives: 2013 328xi
Thanks for the image, gotta remember this trick to get those problematic bolts out
      12-21-2016, 08:59 AM   #870
RayonF30
Yea I mentioned those bolts previously... A PAIN.
Looks amazing. Congrats. How are you liking them?
They make the car look totally different.
I have yet to adjust mine tho.
      12-21-2016, 09:13 AM   #871
Hack14
Hack14's Avatar
Are those two bolts reused when installing the DEPO Headlights?
      12-21-2016, 10:38 AM   #872
RayonF30
Same bolts. The DEPO headlight comes with the adjuster and nut tho but I just used the old ones.
      12-21-2016, 11:20 AM   #873
77cubes
77cubes's Avatar
I love these lights. They make the car look so much better. They are even better in person than the pictures posted.
Really hated the stock lights like most here. It's the one thing I saw every day and hated about my car.
I'm impressed and very happy. Well spent money and install time.
      12-21-2016, 11:31 AM   #874
77cubes
77cubes's Avatar
I bent the old ones so used the new ones. Bolts went on a lot easier as well.
Another install note, when I put the new lights on I adjusted the bottom bolt bracket (it spins to hold the light housing away from the mounting surface) to align the gap between the light and the front top fender.
      12-21-2016, 11:32 AM   #875
kreeess
kreeess's Avatar
Drives: 2013 328xi
Did you adjust the bracket while the headlight is in place? Or prior to mounting?
      12-21-2016, 11:43 AM   #876
77cubes
77cubes's Avatar
I bolted the top one only just a little and held the light to make sure the side bolt hole (10mm one) was aligned.
Then I looked at the gap to the fender. If it was too far away I took the light off and increased the spacer. My spacers were showing about 4-5 threads when they were right. The outer one was more important to set before bolting. I noticed the inner one spun as I put the bolt on to fill the gap as it was set a little shorter.
When I first put the light on I had the spacer adjusted like the old ones as there was a bigger gap. So the old and new spacers were not the same for me.
      12-21-2016, 11:43 AM   #877
RayonF30
Mine seem to line up perfectly.... I didn't have to make any adjustments to the brackets BUT maybe I am so in-love with the lights, I am over-looking everything else...
      12-21-2016, 11:44 AM   #878
RayonF30
      12-21-2016, 11:45 AM   #879
77cubes
77cubes's Avatar
Mine seem to line up perfectly. I didn't have to make any adjustments BUT maybe I am so in-love with the lights that I am over-looking everything else.
You used the old spacers, right? Maybe that's the difference?
      12-21-2016, 12:05 PM   #880
RayonF30
Yea maybe that.
