BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > NBT EVO retrofit problems
      08-23-2017, 03:22 AM   #1
Abi
Drives: BMW 318d
2015 BMW 318d  [0.00]
Hi guys, i have a few questions. i would be appreciated if someone could help me.
I retrofitted NBT Evo with id6(I had hu entrynav).
1. Can I code video in motion alone with esys. Or do I have to pay someone?
2. My PDC sound isn't loud as it was. I tried voluming up but it is the same.
3. I can't see my service history(not showing at all in menu) but it is activated in esys
4. Can I use wifi for something or only for screen mirroring(I have wifi antenna connected)
5. My NBT sometimes restart by him self, is that common issue?
Thanks!
      08-28-2017, 04:04 AM   #2
Abi
Drives: BMW 318d
Bump
      08-28-2017, 08:40 AM   #3
steve@codemybimmer
steve@codemybimmer's Avatar
Drives: 2016 M235i xDrive Cabriolet
Thanks!
1. You will need someone who can enable it via USB or someone who who can script it. This cannot be done through E-sys.
2. Have you tried increasing the volume while it's beeping?
3. You have BKOMBI and it needs to be coded to use KCAN instead of MOST for service history to show up properly
4. Yes but it sounds like it's not coded properly
5. Yes, it's very common on ID4 hardware that was converted to ID5. We've tested a few of these and it seems to happen more on long road trips.
Note that our full fledged ID5 kits do not have any of the issues stated above.
      08-28-2017, 03:33 PM   #4
Abi
Drives: BMW 318d
2. Yes I did. It gets louder but it is still not like it was before. I also noticed it's not increasing with song volume. So, beeps the same when my music is loud and when it's not.
3. Is this some simple coding I can do myself?
4. What exactly can I code, except screen mirror?
5. Is this ID4 hardware? It's not a big deal, happened to me only once in a long time.
View post on imgur.com
Thank you very much for your answers!
      08-29-2017, 03:55 PM   #5
Abi
Drives: BMW 318d
I have 6WA cluster, KOMBI_CIC is coded to -> kombi_mid
Still not showing history at all.
      09-12-2017, 02:17 AM   #6
Abi
Drives: BMW 318d
Still no luck :/
      10-31-2017, 08:50 AM   #7
Blueyzfr169
Drives: 2014 335d F30 XDrive M Sport
Still no luck :/
Any progress on the reboot problem as I have this?
      01-19-2019, 03:43 AM   #8
Abi
Drives: BMW 318d
Nope, still restarts when I use navi on longer trips
      01-25-2019, 02:13 PM   #9
DrifterX
DrifterX's Avatar
Drives: 2016 340i M Sport 6MT+RWD
Yup that's an ID4 unit (label reads HW 2.3)
Is the navigation actively being used when it restarts or it doesn't matter? Also, what do you consider as longer trips - longer than a half hour?
2016 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
      01-25-2019, 10:57 PM   #10
Kamz2070
Drives: E92 M Sport Alpine White
Hi, had my id4 evo flashed to id6, mostly working fine just occasional reboot when I use nav, but main problem is when I start my car sometimes the screen is blank, but music still playing through speakers all controls work just screen not turning on, have to manually reboot for it to come on again. Anyone know the reason for this, do I need to change screen to id5 or 6 screen version?
