BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > Fuel Injector
      10-06-2017, 09:36 PM   #1
rocksnap
Drives: 2014 328d
Fuel Injector
Had a CHECK ENGINE light on my 14' 328d Xdrive with 48k miles while on a road trip, that went out after a few days of light driving. Before the car went in for service, the light, of course, went out. Dealer trouble shot to a bad injector. Apparently, the injectors are on a "Special Watch" list, and the dealer needs special approval from the Mother Ship to get it replaced before they can even order parts. So now I wait, with a new 330i loaner.
      10-07-2017, 12:59 PM   #2
FaRKle!
Drives: '17 328d Sport Wagon
I just had an injector replaced on my '17 328dx at 16.5k miles.
The code I got was "24BB00/Intermittent: Zero-quantity adaptation, injector, cylinder 1: permissible filtered activation duration correction too high." I used a Schwaben OBDII reader to pull the code before bringing it to the dealership.
Like you, it came on, then went off after a few days. When it came back on a second time I brought it in. My dealership had no problem replacing the injector though, and I didn't hear anything about needing special approval. I dropped the car off before work, and picked up the same day.
      10-07-2017, 10:08 PM   #3
rocksnap
Drives: 2014 328d
Strange I wonder what is different from my 14 to your 17?
      10-08-2017, 08:23 PM   #4
F32Fleet
F32Fleet's Avatar
Drives: 2015 435i
You may have older version injectors and the dealer may want to change out all 4.
"Drive more, worry less. "
435i, MPPK, MPE, M-Sport Line
      10-08-2017, 11:28 PM   #5
FaRKle!
According to realOEM there was a different injector PN from 7/1/13 to 7/16/14...
      10-09-2017, 09:41 PM   #6
rocksnap
Drives: 2014 328d
I'll find out exactly when I pick up the car tomorrow. 3 injectors were replaced.
      10-12-2017, 08:11 AM   #7
Hypermile
Hypermile's Avatar
Drives: 2017 F31 328d xDrive M-S M-P
Do you use any additives? Where do you fuel up?
      10-12-2017, 10:31 AM   #8
FaRKle!
I was using diesel kleen and Howe's every tank for the past 14k miles before the injector issue. There a bunch of different stations I fuel up at regularly, but they seem to get a decent amount of diesel traffic (good amount of box trucks and HD pickup work trucks).
      10-14-2017, 10:52 PM   #9
rocksnap
Drives: 2014 328d
No fuel additives. Just fuel from Pride and Cumberland Farms at high volume places. Kind of funny how BMW had them replace 3, not all 4.
      12-21-2018, 08:48 AM   #10
unknw_f30
Malaysia
Drives: bmw f30 328i
I own a f30 328i stage 2 recently my coolant hose leaked and didn't notice so the car got overheated and cracked the engine head after overhaul and changed the engine head the first start the engine was shaking after changing the coil and plugs the car still shake but not like the first time this time it's doesn't shake for awhile and then it shake injectors problem ? Car I guess haven't change the injector before mileage is 220k km is around 163k in miles on the meter before overhaul
      01-22-2019, 06:32 AM   #11
Hypermile
Hypermile's Avatar
^ This sun-forum is for N47 and N57 diesels. I'm surprised that your car overheated before any cluster or iDrive warning.
M Sport
M Performance
