BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > J&R Auto Performance Inc./ AARodriguez Corp- N47 tunes
      03-07-2018, 04:47 PM   #45
FaRKle!
Drives: '17 328d Sport Wagon
Originally Posted by Andrew@FixMyVW View Post
Hi Guys, just wanted to let you know that OBD tuning is working well now for the E and F series. This week we have OBD tuned:
328D
335D
F15 X5 35D
I wonder who that was ?
Were you guys able to confirm an issue with Magic Pro on other 5GHz WiFi networks?
      03-08-2018, 12:00 PM   #46
Andrew@FixMyVW
Drives: 2010 335D
Yes sir, 2.4GHZ works like a charm
      03-14-2018, 12:29 PM   #47
Johnny250
Drives: 328d Wagon
here are my dyno numbers with the AARodriguez stage 2 tune.
AWD dyno, max numbers.
I wish i got a baseline without the tune..
Mods:
-AFE Magnum FLOW Pro DRY S Filter
      03-14-2018, 04:05 PM   #48
Johnny250
Drives: 328d Wagon
baseline dyno for 328d from farkle!
Nice! Glad you could post the data!
If you use my stock dyno runs as a reference you got the advertised 40hp and 60lb-ft gains.
143hp, 217lb-ft on Mustang dyno
148hp on Dynojet
      06-21-2018, 09:08 PM   #49
Donnf08
Drives: BMW 328d f30
So has anyone drained their def tank since the DPF SCR delete??
I have a stage one tune from mission and I was wondering has anyone drained there adblue tank. Plus has anyone experience white smoke from there exhaust after getting on there 328d on the highway? Again I have a stage one tune with the down pipe with mission tuning
I think the white smoke is the def fluid... I haven’t lost any coolant or oil...
      07-13-2018, 05:50 AM   #50
Hypermile
Hypermile's Avatar
Drives: 2017 F31 328d xDrive M-S M-P
Originally Posted by rbreding View Post
Normal driving no difference in sound inside the cabin. Get on it and the exhaust gets more angry but not obnoxiously so like a riced out Honda. Has some turbo whistle but nothing like my X5. Has some diesel smell until the CAT is heated up. Faint diesel smell afterwards. We can call that Prius repellant.
Will do some videos and followup later. Changing bumpers out for some M bumpers now so she's being worked on.
Did you remove your DEF tank? If so, are you able to do a dual exhaust setup now? I believe the DEF tank is what's preventing N/A F30d/31d from installing dual exhaust...I love how my $80K CAD BMW has a single exhaust while $20-40K cars have dual
M Sport
M Performance
      07-14-2018, 10:15 AM   #51
rbreding
Drives: 328d, 335d, x5d
I haven't pulled the tank yet. That is on the list. But based on when I had the rear bumper replaced with the msport one I would likely concur with your conclusion. My exhaust was replaced from Turbo back and has a small resonator so adding a second exhaust tip wouldn't be that difficult. Would just need a different lower valance on the rear bumper and done.
      07-16-2018, 06:05 AM   #52
Hypermile
Hypermile's Avatar
^ Thank you!
I ask any N/A 328d owners that have done a dual exhaust setup to please post here.
If alphabet delete is the only way to retro a dual exhaust, I'm even more convinced to do a tune.
M Sport
M Performance
      07-16-2018, 04:28 PM   #53
n00bkiller944
Drives: '14 328d M Sport
^ Thank you!
I feel the same way. I want duals bad. Also a tune and delete doesn't sound like the worst
      08-24-2018, 03:55 PM   #54
StealthnShadow
Wagon Owner
StealthnShadow's Avatar
Drives: F31 Diesel Wagon
Curious, what exactly is needed to do an OBD Tune where we would not have to send our DDEs to GA?
BMW F31 Estoril Blue II 328D Wagon l Project_F31 l Group IG: BMWPlusOnes l Build Thread: Coming Soon....
      08-24-2018, 07:35 PM   #55
FaRKle!
They send you a laptop/tablet (can use your own too) and flashing tool to interface to the car. First you pull your existing car files/data and send it to them, then they'll send you a file with the tune to flash.
      09-10-2018, 12:26 PM   #56
tcubed
Drives: 335d
Any long term feedback on the JRstage 1 and 2 tunes for the 328d?
- MPG?
- Urea Usage?
- 0-60 time improvements or other benchmarks
Just got one and was wondering if I should stay conservative with stage 1 or get the stage 2
      01-06-2019, 08:11 PM   #57
hybridp
Drives: 2010 x5 35d
Has anyone with a stage 3 done intercooler and meth yet? I’d be interested to see Dyno numbers I gotta imagine with those two you’d be pushing over 250 to the wheels no problem and closer to 450tq
      01-06-2019, 09:59 PM   #58
Enabled
Drives: 328xd Wagon
The fueling system is the limiting factor here. Intercooler is the same one used on euro 3 liter 330d.
-2014 328d Wagon, self-tuned, 245hp/400ft-lbs.
Others
-E36 328is ~210-220whp: Lots of Mods. 2000 Z3 Roady. 2003 VW Jetta TDI Manual 47-50mpg Modded. S52 Estoril Z3M Coupe.
      01-13-2019, 02:35 PM   #59
328dX
David
328dX's Avatar
Drives: 2015 328dX wagon
I'd just like to make a few comments regarding limitations on the power-train. The transfer case is already a weak-link if you own an x-drive vehicle, they go out anywhere from 30-50k miles with normal power output and is roughly a $6,000 repair out of warranty.
Secondly, ZF 8HP45 Transmission is rated at 450nm torque from a gas engine, or 500nm torque in diesel applications, that is roughly 370 ft/lbs.
In summary there is a lot of strain that will be taking place on your vehicle and unless it's a lease or something I'd advise not modding it more than their stage one, or any companies "stage 1" power output.
