10-16-2018, 10:27 AM | #1 |
Rep 1,055
QuickJack 5,000-LB Capacity Portable Car Lift
I've always wanted to get one of these, at this price it's almost too good to pass up! If you're one of the lucky few to have it in your local Costco you can pick it up for $999.99.
Any of you guys have one of these and love or hate them? https://www.costco.com/QuickJack-5%2...100460313.html Local Costco List |
10-16-2018, 10:37 AM | #2 |
Rep 3,540
I have the 5000lb SLX. I love it. That said, if you have larger vehicles (even something like the latest Accord) get the EXT, or the platform extension. You'll need it to reach the jack points.
I've lifted a 5300lb X5M with the 5000lb model without issue (other than having to extend the platform a bit to reach the jack points). $999 is a steal! |
damageprone580.50 MisterF80M31047.00 |
10-16-2018, 10:48 AM | #3 |
Rep 1,055
A lot of people are worried about the safety of this thing, but I'm not too worried after watching this video:
I wouldn't try to push it's capacity, but it definitely gives me confidence in its engineering. |
10-16-2018, 04:05 PM | #4 |
Rep 885
the nearest in stock store is 60 miles from me. might be worth the $101 to ship to me.
SAFE-GUARD tire/wheel/windshield/paint protection is a FRAUD! do not waste your money!
10-16-2018, 04:11 PM | #5 | |
Rep 1,055
Box 1 (84 lbs. / 46 kg) Box 2 (84 lbs. / 46 kg) Box 3 (57 lbs. / 26 kg) Save yourself the trip and your back. Well worth it IMO. Also, if you have a Discover card you can save yourself another 5% on this if you activated the category. So really, the shipping would really only be $50. |
10-17-2018, 10:52 PM | #6 |
Rep 18,733
Man up and get a real lift.
A manual transmission can be set to "comfort", "sport", and "track" modes simply by the technique and speed at which you shift it; it doesn't need "modes", modes are for manumatics that try to behave like a real 3-pedal manual transmission. If you can money-shift it, it's a manual transmission. "Yeah, but NO ONE puts an automatic trans shift knob on a manual transmission."
10-18-2018, 12:17 AM | #7 | |
Assistant TO the Regional Manager
617
Rep 728
2018 M4 Coupe. 6MT.
Der stärkste buchstabe der welt |
damageprone580.50 |
10-18-2018, 07:09 AM | #8 |
Rep 2,476
Drives: Satan's Chariot 2.0
Tempting
10-18-2018, 08:04 AM | #9 |
Rep 1,055
A 2 or a 4 post lift is always the goal, but I don't have the space for it, nor is it portable and easy to install. Not at least at the current garage. With one of those you can at least store another car underneath.
A MaxJax lift is a viable option, but still don't have the space for it. |
10-18-2018, 09:17 AM | #10 |
Rep 215
I've got the 5000SLX and I also love it. Its great to have in just a normal garage at the house. Fits the 1-series chassis perfectly, but I do agree that if you have a longer wheelbase car it would be helpful to get the extensions. But for $999 I would say do it!
10-18-2018, 10:46 AM | #11 | |
Rep 3,540
Video 2 shows that when connected to a high pressure hydraulic unit, the 5000SLX hydraulic cylinder/pressure system on the frame can survive lifting 20,500lbs. |
SYT_Shadow11482.50 |
10-18-2018, 12:02 PM | #12 |
NOOB
1601
Rep 1,356
I got a 5000 around 3 years ago and barely use it. Got it because it was my only option since I'm dealing with a low ceiling. It's decent for wheels/tires/brake jobs but nothing a jack and stands won't do at about the same time. It's really tight getting under the car with a creeper. When I do use it, it's mostly for detailing a car where I'm in a more comfortable position.
At it's current price, I think it's worth a try especially when Costco sells it. Don't like it? Return it. If I had the height, I'd go with either a Max Jack or a full on 10k+ # rated two post.
@BMWclassicdivision
damageprone580.50 |
10-18-2018, 06:45 PM | #13 | |
Rep 18,733
damageprone580.50 Nkc1600.50 |
10-18-2018, 08:40 PM | #14 | |
dances with roads
4732
Rep 4,096
TheMidnightNarwhal2657.00 |
10-18-2018, 09:14 PM | #15 | |
Rep 1,055
10-18-2018, 10:12 PM | #16 | |
Rep 3,256
10-18-2018, 11:48 PM | #17 |
Get off my lawn
932
Rep 1,159
Drives: 6MT
Garage List 2023 GR Corolla [0.00]
2022 BMW X3 M40i [10.00] 2007 BMW Z4M Coupe [0.00] 2002 BMW 325xiT [0.00] 1991 BMW 318is [0.00] |
Thanks for the tip! Have been using my friends for years without issue, great product and track/autocross portable. Time to get one of my own
10-19-2018, 08:16 AM | #18 |
Rep 18,733
No. There was no need. I built the building the lift went in with 4,000 PSI concrete. The spec for a 10,000 lb. Rotary is min 4.5" at 3,000 PSI. I tend to over-build stuff, so my floor is 12" under the lift and 9" everywhere else, with 1/2 rebar. I built the building with the intention of making an auto shop with a lift, so I spec'd 4,000 PSI. Most concrete floors are made with 3,500 to 4,000 PSI from what I researched at the time.
But if the floor is not up to those specs (4.5" @ 3,000 PSI), you can always cut the floor and pour 2'x2' 12" foundations for the columns. For the price of the Quickjack, I'd get a professional long-saddle floor jack and some ESCO stands. The Quickjack just seems that it'd get in the way for a lot of jobs one would do underneath the car. The setup for the Quickjack seems cumbersome and longer than just lifting an E9X on the center jack points and placing stands underneath the lifting blocks. My opinion of course.
10-19-2018, 10:02 AM | #19 | |
Rep 1,881
Also why does everybody comment on how you have to lug these around? Cant you just leave them in one spot and drive over them into your parking spot? Are they not meant to be driven over on a daily basis?
I am never able to post pictures on forums, all my pics are on IG @baye30 https://www.instagram.com/baye30/
Current Garage - [2011 E90 M3 ZCP] [2005 E53 X5 3.0 Sport] [1988 E30 325IS 24V] |
10-19-2018, 10:15 AM | #21 |
///M Powered for Life
11483
Rep 10,329
there is a long thread elsewhere in the forum about the Quickjack
It's friggin awesome I've had two post lifts in the past but currently have a garage that's too short for it to fit, so now I use a quickjack. They're easy to operate, pretty easy to move around and get out of the way when you aren't using them, very safe, and allow me to do all the car work I'd like to do except rod bearings. |
10-19-2018, 10:21 AM | #22 | |
11483
Rep 10,329
they give plenty of space. I've done multiple full exhaust systems with mine in multiple cars The two platforms have quick disconnects so you can easily separate the device. I've only done this once or twice, the rest of the time the quickjack sits slightly to the side of my car so I don't have run over them every day -- i don't think they're made be run over Anyone who says this is similar to jack stands and a jack has absolutely no clue what they're talking about. In AER we have 10 guys and 4 giant jacks and we still take the QuickJack. Jacking up a car to a proper height is quite dangerous and takes forever to do it right. Whichever genius thinks this is in the same planet as a jack and stands, please post a video of how you raise your car to the height the QJ raises it in 30 seconds, which is what it takes me with the QJ in complete safety. I sense a Darwin Award coming up soon In Watkins Glen, a nice big racetrack, the mechanic shop that's on site has the regular quickjack. They use theirs nonstop, for years, and it still works perfectly. |
