BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > 318d - “Please refill oil” after 4k miles?
      12-19-2018, 12:11 PM   #1
Tomadam
Drives: F34
I got the message “ please top up 1 quart of oil”! Only after 4.000 miles! Is this normal?
      12-19-2018, 12:55 PM   #2
zeikei
Drives: F36
Not normal of course, as it is diesel it still has dipstick? If yes check that first to make sure that the problem is not the oil level sensor. Do you mean that the car has been driven only 4000 miles in total or after last oil change?
      12-19-2018, 01:13 PM   #3
Tomadam
Drives: F34
There’s no dipstick in F series diesel
4000 miles after the last oil change (with 90% highway usage)! Last time, i got the “top up” message after 6500 miles.
      12-19-2018, 02:07 PM   #4
zeikei
Drives: F36
What engine and year? I thought all diesels still have dipsticks, my 2015 B47 has for sure. It also has electronic measurement in iDrive.
In any case if it has been consuming oil already before then there is an issue which has become worse either mechanically of the new oil affects it. Turbo would be one place where it might get consumed.
      12-19-2018, 03:28 PM   #5
floydarogers
Curmudgeon and Pedant
floydarogers's Avatar
Drives: 2010 335d, 2014 328d
Could well be normal. All engine use oil - you'd be a fool to believe otherwise.
      12-19-2018, 03:36 PM   #6
HighlandPete
Drives: BMW F11 535i Touring
B47 still has a dipstick, at the rear of the engine.
I'd be physically checking oil levels, topping off on the dipstick to get a baseline for accurate future consumption.
I assume you are using the most suitable oil grade for your conditions.
      12-19-2018, 04:02 PM   #7
zeikei
Drives: F36
Sure but N47 or B47 definitely do not normally use this much. In the family we have both of these engines right now and they barely drop the level at all between oil changes. I have also had N46 and N52 and for those this would be normal.
      12-19-2018, 07:15 PM   #8
floydarogers
BMW defines "too much" as 1 quart per 750 miles. Anything less is "normal".
Each engine has different characteristics and usage. Without knowing the *ENTIRE* oil usage for the life of that engine, we have no idea what is normal. We also have no idea what fuel, what oil, whether it's been deleted, if there's a leak that doesn't snow on the ground, etc.
      12-20-2018, 09:21 AM   #9
JimKden
Drives: 2016 340xi
Add a quart and if in 4000 mi it needs more, then raise an eyebrow. At this point it could have been shorted when it was changed.
      12-20-2018, 05:50 PM   #10
jh_f30
jh_f30's Avatar
539
Drives: 2013 335i Sportline Auto RWD
Look around the engine bay and under the car to confirm there are no leaks.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~HR Sport Springs~CF Rear Lip Spoiler~Active Autowerke OBD Flash Tune Stage 2~
      12-21-2018, 11:25 AM   #11
Tomadam
Drives: F34
There’s no leak. I checked my garage in the past 3 days.
      12-22-2018, 10:56 AM   #12
Orion4
I'm at 105,600 and do oil changes between 5000-7500. Only occasionally get the "add a qt" alert around 6000. If that pops up, just to my normal change.
      12-28-2018, 03:44 AM   #13
japanwings
Belgium
Drives: F31 M pack
got the message two times in 1 year, about 20.000km
There is a dipstick in the 318d, and i refilled about 0,5 liter of oil and level was back at max
