BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > 328d fuel filter change and fuel purge
      12-26-2018, 09:42 AM   #1
tcubed
Drives: 335d
Has anyone figured out how to purge the fuel system after changing the fuel filter on the F30 328d? On my e90 335d I was able to use my Foxwell NT510 to do this but no such luck with the 328d.
      12-26-2018, 03:50 PM   #2
kdog_x
Drives: 14 328d
Is there a procedure to prime it? When I swapped mine I just started the car afterwards. It cranked a little long and then started up
      12-27-2018, 04:26 PM   #3
CleanKM
SQUEAKY
CleanKM's Avatar
Drives: 2014 328d
Same here, I swapped mine out without any steps ahead of time. Then pressed on the accelerator 10 times before starting it (car was in in On, but not running), then it cranked over a couple times before starting up without any issues.
Followed guide here:
      12-28-2018, 08:02 AM   #4
tcubed
Drives: 335d
I followed the same guide but mine did not start right up. took several tries so I am wondering if there is a better way for next time
      01-09-2019, 05:58 AM   #5
Hypermile
Hypermile's Avatar
Drives: 2017 F31 328d xDrive M-S M-P
^ Agreed and maybe a DIY on how to put the metal retaining clip back in, without having to bend or grinding it down. Perhaps a tool of sorts?
M Sport
M Performance
      01-09-2019, 06:35 AM   #6
tcubed
Drives: 335d
For the metal retaining clip I found that the slot in the fuel filter was bent from shipping. Put a screwdriver in the slot and bent it straight and the metal clip went in easily.
      01-11-2019, 08:40 PM   #7
rbreding
Drives: 328d, 335d, x5d
Can be activated with ista or foxwell/schwaben tool.
#dontbeacranker
      01-13-2019, 01:38 PM   #8
n00bkiller944
Drives: '14 328d M Sport
#dontbeacranker
Good to know going forward
