BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Open recall question
      12-29-2018, 03:41 PM   #1
switchman
Drives: '15 X5 '14 328i '06 X5 '03 530
Hi to all !
I hope everybody is enjoying the Christmas holidays.
I am until I got this letter from BMW yesterday, has anybody else received similar recall notice ?
I searched in BMW recall website as well as NHSTA but none is listed. Its weird that this letter does not include TSB number;
      12-29-2018, 04:37 PM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
The failure of the bolts that connect the electric boost motor to the steering rack is well known. Search 'steering rack' and you'll find plenty of threads. The failure rate might not yet be at the point that there's an actual recall, but it's high enough that BMW is doing something about it.
      12-29-2018, 04:39 PM   #3
switchman
Thanks, Billfitz.
I'll research some more and I intend to call Customer Relations.
      12-29-2018, 05:45 PM   #4
bavarianride
Drives: bimmer
This is good info. How many owners have received this letter? To OP, what model year/month of production of your car?
      12-29-2018, 07:58 PM   #5
switchman
Received this for my 2014 328i, 10/2013 production date.
      12-29-2018, 11:48 PM   #6
n00bkiller944
Drives: '14 328d M Sport
I got one last week for my 2014 BMW 328d
      12-30-2018, 10:01 PM   #7
delvec03
Drives: 228i Sport/ DSB
I have one on my 2015 228i n20. haven't seen anything else in the 2er forums which I felt was odd.
      12-30-2018, 11:16 PM   #8
sean2648
sean2648's Avatar
Drives: 2015 335i
Interesting story about my experience around this recall/problem.
I've had my car a couple months now, and the first time I had it up on stands to do some installs, I took everything apart to just take a look and inspect everything. Everything looks awesome, except in this specific area. The recall just takes care of the bolts really, there are 3. They describe the issue as either the bolts can be eroded a bit or they are "loose" and need to be retorqued down to spec. It's literally like a 20 min visit once they get your car in there.
Well low and behold I look at the area and 1 bolt is completely missing and there is a crack in the electric motor housing. I was freaking out since the car was immaculate other than this. No previous accidents, and definitely nothing to assume this type of issue. Called my local indy since they are friends to get their opinion. Thankfully they called to get the part numbers for a potential replacement and find out there is a recall out for this exact item. Called BMW and they explain what I just said, its normally just retightening or replacing those 3 bolts, simple recall. THANKFULLY the foreman was great and said everything would be covered, but I had to get an entire steering rack replacement. They had my car for over 4 weeks, and I was in a loaner.
Very fortunate this was out there. And then funny part is I get the same letter OP posted about a week before I get my car back, good times.
      12-31-2018, 11:24 AM   #9
s11nny
Drives: 420I M Sport
My dads 2015 1 series went into bmw for another fault. They advised me that they are doing a quality enhancement on steering gear. They replaced something.
Looks like uk owners are being checked when booking into dealers
      12-31-2018, 01:18 PM   #10
Billfitz
Billfitz's Avatar
If it only took an hour or less they replaced the bolts that attach the motor to the rack. Most of that time would have been removing and reattaching the under body shield. If the bolts let go and the motor comes loose they can't replace just the motor, they have to replace the entire rack assembly, and then it has to be registered to the car. There are quite a few threads, some of them years old, about racks being replaced, usually with no explanation why it was necessary. It appears now that it was probably the bolts in most cases. Anyone who paid for it might be entitled to reimbursement.
      12-31-2018, 05:29 PM   #11
sean2648
sean2648's Avatar
Drives: 2015 335i
What Bill said is definitely the case. Normally they tell you the recall "adjustment" takes an hour or less, and all of that time is spent just getting the car up and taking off the shields (its like 25 or so bolts holding those 2 shields up). Takes 30 seconds to replace the 3 torq bolts.
But yea, anything further than that and you are getting your entire steering rack replaced. Shop foreman definitely told me my case was pretty unique and some of the worst damage he's seen having to do with the recall.
'15 335 M Sport 6MT /// FBO /// Custom Tune /// Custom Interior
Instagram /// Build Thread
      12-31-2018, 08:33 PM   #12
bavarianride
Drives: bimmer
My VIN does not show up on bmw-rp.com, and a key read did not pull up any open campaign, so it looks like my car is not (yet) included in this recall.
      01-01-2019, 01:00 PM   #13
bavarianride
Drives: bimmer
Has any steering rack issue/noise been reported to service? I do wonder if this recall(with no TSB/SIB?) is for every F30, so just those with previous records of steering complaints.
      01-02-2019, 11:01 AM   #14
switchman
Update:
I called Customer Relations and was informed of the recall as a "Service Action" thats why no recall will be found on the web. Dealers are all informed of the action.
I'll be calling my SA shortly then.
      01-02-2019, 12:08 PM   #15
Orion4
It appears from this thread and an earlier similar thread, some folks are getting letters and others not (so far). Between the 2 threads it seems that most that have posted are 228/328 and one or two 335i- across the last 5 or 6 years. Looks like the only way to identify if your car is affected is by having the dealer run your VIN.
      01-02-2019, 01:27 PM   #16
Billfitz
Billfitz's Avatar
Looking at the BMW parts list there are some 27 different steering racks that have been used in the F20 and F30 series. If only some of those racks are affected that explains why only some drivers are getting notices.
      01-03-2019, 03:11 PM   #17
pongkin
Drives: f30
got this letter today, tells me its not a notice of a recall or service action.its an extension of my limited warranty. I guess I'll have to talk to my SA see what he can pull to get it replaced
      01-03-2019, 04:01 PM   #18
Billfitz
Billfitz's Avatar
You don't need to replace the rack if it isn't broken. Replacing the bolts that could corrode and fail is all that's required. I haven't gotten a letter, nonetheless when I do my spring oil change I'll pull the shield and take a look at my rack and replace the bolts myself if there's anything suspect.
      01-03-2019, 04:46 PM   #19
bavarianride
Drives: bimmer
What is your F30 build date?
      01-03-2019, 06:00 PM   #20
pongkin
Drives: f30
i got a 2014 335i f30
      01-06-2019, 09:07 PM   #21
JKPIrving
Drives: 2014 328
Steering Rack
I sent my car to an Independent shop and they said the it needed a new steering rack. When we got home I found the letter stating there are issues with the bolts for the power steering gear.
Could this issue cause the steering rack to fail? Should I have the car towed to BMW dealer?
Any help will be appreciated.
      01-12-2019, 12:03 PM   #22
CaeBlock
Drives: 320D F30
The same here... yesterday i founded that my F30 its elegible to this recall....
