BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic Maintenance: Wash, Wax, Detailing, Repairs > F32 Rear Lights
      01-03-2019, 07:26 AM   #1
pss53
pss53's Avatar
Drives: 420D XDrive MSport
F32 Rear Lights
Anyone had an issue with replacing the bulbs ?
So break light went so thought go swap in a day or two, then indicator went too...
Swapped both bulbs even though they both looked fine on the filament, but no lights at all ? Checked cable securely connected and the connector plate is securely inserted into cluster and still no lights ?
Any ideas? a mate was saying it needs to be reset/coded in system to send power back to it ?
      01-03-2019, 07:42 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
Check the connector conductors, the ground conductor may have burnt out. It's a well known issue, more than a few threads about it.
      01-03-2019, 08:29 AM   #3
pss53
pss53's Avatar
Cheers, just order one of these then ?
https://www.ebay.co.uk/itm/Genuine-B...xbv:rk:38:pf:0
Managed to get indicators and LED's on but still no brake light even tho bulb is fine.
      01-03-2019, 08:55 AM   #4
Billfitz
Billfitz's Avatar
That's not a connector. This thread deals with bad connectors:
https://f30.bimmerpost.com/forums/sh....php?t=1405916
That may be your problem, it may not. Before trying to fix something you have to be sure of what's broken. That's your next step, not just blindly ordering something.
pss535.00
      01-03-2019, 09:50 AM   #5
pss53
pss53's Avatar
Well ordered a new one anyway - it was only $15, if that's not the issue I'll try the connector block, none of it looks burnt out and all looks fine and intact
Cars wind me up sometimes !
