BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > Oily line/valve, anybody know what this is?
      01-13-2019, 02:23 PM   #1
328dX
David
328dX's Avatar
Drives: 2015 328dX wagon
I have this piece in the front of the engine bay, closer to the coolant overflow.
It's covered in oil, was curious as to what it was because my warranty is ending in a few months and trying to see if it needs replacement or not.
Thank you
      01-14-2019, 08:26 AM   #2
kdog_x
Drives: 14 328d
It looks like the PCV line. Might have to pop the upper cover off to confirm, but the PCV runs form a port on the intake down to the charge pipe. It vents oily air from the crankcase under boost.
Take a look at the "328d CCV Oil Catch Can" thread. That thread has pictures of that pipe removed for a catch can. Just be careful with it if you remove / inspect it, it cracks really easily. (Dont ask how I know that!)
      01-14-2019, 12:34 PM   #3
FaRKle!
Drives: '17 328d Sport Wagon
Thank you
kdog_x is correct. That's the CCV tube from the crank case port to the intake just before the turbo. Mine was really dirty like that as well. The reason is the factory does a REALLY crappy job of sealing the tube to the rubber coupler, and coupler to the heating element. They use metal bands that I was able to slide off without cutting. I suggest using worm drive clamps to make a better seal.
      01-14-2019, 07:51 PM   #4
328dX
David
328dX's Avatar
Thanks guys, i'm not sure whether to clean it and live with it, or just have the dealership do it & possibly make a tighter connection with the metal bands lol.. Either way if it's just the PCV outlet I can live with it
      01-14-2019, 10:01 PM   #5
rbreding
Drives: 328d, 335d, x5d
It also has a pathway to your intake post air filter.
      01-15-2019, 12:05 AM   #6
FaRKle!
The rest of us that have commented in this thread have put a catch cans in place of it to reduce the fouling going into the intake. You'll need to remove that though when you get your car smogged. I can swap mine in and out in 10-15 minutes though.
      01-15-2019, 12:50 AM   #7
328dX
David
328dX's Avatar
I donít care enough to install a catch can honestly. Itís a diesel and a little oil vapor canít hurt. Not as necessary as a gas engine. Plus Iím not the original owner and no idea of the carbon build up. If I ever get the carbon removed Iíll install one
