BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N47 and N57 Turbodiesel Engine / Drivetrain / Exhaust Modifications > N47 w/o emissions oil needs
      01-15-2019, 02:15 PM   #1
mpm01
Drives: '15 328D grocery-getter
It's well documented that these N47 diesels need "emission components friendly" oil, LL04 as recommended by BMW. But what if all the emissions components have been removed or disabled? My non-BMW heritage leads me to believe that I could use any type of oil as long as it was the needed (although highly subjective) viscosity.
Any one out there running regular old synthetic/blend/dino on their emissions-free 328D?
      01-15-2019, 09:31 PM   #2
Enabled
Drives: 328xd Wagon
I'd be very weary of experimenting with cheap oils.
The European N47 timing chain issues were numerous.
-2014 328d Wagon, self-tuned, 245hp/400ft-lbs.
Others
-E36 328is ~210-220whp: Lots of Mods. 2000 Z3 Roady. 2003 VW Jetta TDI Manual 47-50mpg Modded. S52 Estoril Z3M Coupe.
      01-16-2019, 02:14 AM   #3
328dX
David
328dX's Avatar
Drives: 2015 328dX wagon
Werent the timing chain issues corrected on 2014+?
I don't see why you couldn't use any full synthetic. Even running liqui-moly is fine.
If you're going for other synthetics than liqui-moly i'd suggest a diesel synthetic such as Shell rotella, mobil delvac, or chevron delo. I don't think any of those even come in 5w-30 honestly as well..
      01-16-2019, 09:45 AM   #4
mpm01
For sake of discussion, let's say that I'm not suggesting a drop in oil quality. I'm more questioning the need for the oil additives that "protect" the emissions components that are no longer on the car.
      01-16-2019, 12:11 PM   #5
328dX
David
328dX's Avatar
No idea, probably less zinc. You'll need to find the SDS for bmw oil vs. another brand
      01-16-2019, 12:18 PM   #6
mpm01
Zinc is not the additive put into LL04 oil to protect the precious hippie filters in the exhaust. I can get zinc in Rotella oil, which is still a very popular oil brand across diesel trucks of various makes, models, and years.
I was afraid this was an unexplored topic, so I guess I'll be digging in the Bob The Oil Guy forums to see what's really going on with the "emissions-friendly" oils that come with a massive up-charge.
Obviously, we don't have to stop our discussion here...
      01-16-2019, 01:21 PM   #7
328dX
David
328dX's Avatar
That's what I was saying, the bmw oil or any oil used in systems with a DPF probably has little to no zinc and that's what the difference is
      01-16-2019, 01:47 PM   #8
mpm01
Now that's a swift kick in the face via oil marketing departments; zinc is an additive, not naturally present in the oil, yet oil companies are charging extra to NOT add it. Wow........
I'm over in the Bob forums now attempting to decipher the data that is being dumped from all directions. I'm seeing that most of those guys are looking for protection in 'heavy duty' truck motors that see full-time towing use. And I've yet to find someone specifically address if they would use different oil on a late model truck diesel with emissions removed.
