BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Cosmetic Maintenance: Wash, Wax, Detailing, Repairs > Scratches on black paint
      01-18-2019, 08:27 AM   #1
florincmf
Drives: 3 Series F31 2016
Good afternoon,
Someone scratched my car the other week on the driver's door. (see picture attached). Is there any way I can fix this at home by following this guy's tutorial. I would love a bit of DIY work to do over the weekend.
(guy's tutorial)
View post on imgur.com
(scratches) If you put your hand over them you don't feel them at all which I believe it means that they're not deep.
Any advice is much appreciated in how I can get this fixed
Regards,
Florin
      01-18-2019, 08:43 AM   #2
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
That's the right method if the scratch is very shallow. Try it, but it should only take a dozen or so swipes with the 3000g to erase the scratch. If it takes more than that the scratch will need filling.
      01-18-2019, 08:50 AM   #3
2015F31
Drives: Black 2015 328i Sport Wagon
2015 BMW F31  [0.00]
You may be able to use a compound polish and a random orbital polisher. Work from more 'course' to less with the polishes and pads. If you can't feel them, you may be able to get most out with a good polishing.
      01-18-2019, 09:52 AM   #4
Billfitz
Billfitz's Avatar
If you have a RO polisher you can use it instead of rubbing out by hand, but the wet sanding with 3000g is still required with a scratch, otherwise you'll be there for an hour trying to get rid of it with just compound, and still may not succeed. I don't bother using 5000g, as I keep four grades of compound and polish on hand, the most aggressive rendering no need to wet sand with 5000g. I also don't bother to break out my RO for a small scratch, as I can rub it out by hand in just a couple of minutes.
I also start wet sanding with 2000g, following up with 3000g, but I wouldn't recommend 2000g to a newbie, as it can rub right through the clear coat if you overdo it.
      01-18-2019, 03:58 PM   #5
florincmf
So what's the best approach to try this from a newbie perspective? I have a RO polisher, found one on eBay actually.
      01-18-2019, 05:23 PM   #6
Billfitz
Billfitz's Avatar
The only thing different from the video is that you apply and rub out compound and polish with the RO instead of by hand. I use Menzerna products, which are conveniently labeled Step 1, 2 and 3. Step 1 for initial rub out, step 2 for initial polish, step 3 for final polish. Some places sell all three together, for instance:
https://www.amazon.com/Menzerna-400-...85758601&psc=1
      01-23-2019, 08:37 AM   #7
florincmf
Unfortunately, some of the scratches do not disappear when I spray soapy water over them so probably I won't have any luck in following the tutorial. I might have to go to a specialist despite of being excited to do some DIY on my car.
