BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > Who here torques the oil drain plug and filter housing?
      01-20-2019, 08:58 PM   #1
NoobCola
NoobCola's Avatar
Drives: F30 N20
I've done many oil changes on my previous vehicle and my girlfriends car as well so an oil change isn't new territory for me. Been seeing the DIY on oil changes for BMW and they all say to torque down. Just curious if the filter housing and drain pan are that sensitive and just doing the "tight but not too tight method" should be avoided.
      01-20-2019, 09:01 PM   #2
jgoens
jgoens's Avatar
3788
Drives: 2013 335i msport
I don't torque either..just tighten fairly tight. You do have to tighten the filter all the way until it stops turning or it will leak.
Last car: 2011 335i Msport. JB4. Vrsf CP
      01-20-2019, 09:22 PM   #3
the dope steez
Drives: F30 335i M-Sport
True, found this one out pretty recently. The dealer many moons ago put a green mark on the cap and housing so that when they line up the cap is fully tightened.
As for the drain bolt I just go with 'pretty tight'. Not the force of all of my weight behind but good n tight.
jgoens3787.50
      01-20-2019, 09:28 PM   #4
NoobCola
NoobCola's Avatar
Drives: F30 N20
That's what I usually do too good to know though.
      01-20-2019, 09:31 PM   #5
NoobCola
NoobCola's Avatar
Drives: F30 N20
Like how the the expansion tank has the yellow marks that line up letting you know it's on all the way? I didn't notice a green mark on the housing I'll have to take a look next time I pop my hood.
      01-20-2019, 10:16 PM   #6
FaRKle!
The oil filter cover and drain plug should be tightened to 25Nm/18.5ft-lbs.
      01-20-2019, 10:23 PM   #7
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
The O-ring on the filter cap makes for a very snug fit, so your usual 'feels about right' is good there. But the non xDrive N20 has a plastic oil pan and plastic plug that might be touchy about torque. Make sure you get the right filter, which includes a new plug, because that plug is a one use only.
      01-20-2019, 10:36 PM   #8
NoobCola
NoobCola's Avatar
Drives: F30 N20
Yea I was seeing how the xdrive/rwd models are different Im wondering why. I have an xdrive model and plan on ordering a kit soon that has it all.
      01-20-2019, 10:48 PM   #9
Billfitz
Billfitz's Avatar
XDrive models have a metal pan and use a metal plug. I have no idea why.
      01-20-2019, 10:58 PM   #10
NoobCola
NoobCola's Avatar
Drives: F30 N20
Maybe to justify the cost of the added price? When I was comparing xdrive to rwd price when I was shopping around price difference was around 3k which to me seemed a little steep
      01-21-2019, 08:28 PM   #11
BMWinAZ
BMWinAZ's Avatar
104
Drives: 2013 335i, ‘08 328i, ‘03 316ti
I am the King of Torque If there is a torque spec for a screw I will torque it to that spec. It must be part of being German
cngo56.00
cfm56d7b5886.00
jsouth112.00
      01-21-2019, 09:09 PM   #12
IraHayes
Drives: 328i
I torque the drain plug because, well, plastic. I don’t want to over do it. The filter housing cap until it’s just snug.
      01-22-2019, 10:47 AM   #13
NoobCola
NoobCola's Avatar
Drives: F30 N20
Originally Posted by IraHayes View Post
I torque the drain plug because, well, plastic. I don't want to over do it. The filter housing cap until it's just snug.
I have an xdrive so I have a met pan apparently (I haven't actually taken a look for myself yet)
      01-22-2019, 01:03 PM   #14
n00bkiller944
Drives: '14 328d M Sport
I just do it by feel. Maybe i shouldn't but it feels right
      01-22-2019, 05:09 PM   #15
Buckleyy
Drives: F30 328i
Not me, usually just tighten it until feel
      01-25-2019, 09:35 PM   #16
flyguy27
flyguy27's Avatar
Drives: 2013 328I Sportline
2013 BMW 328i  [0.00]
I torque the oil filter cap but not the plastic drain plug. I do that one by feel.
jsouth112.00
      01-25-2019, 09:47 PM   #17
Billfitz
Billfitz's Avatar
I'd say that's backwards. The oil filter cap seems like it would be very difficult to over tighten, while I can see the plastic drain plug being pretty easy to over tighten.
      01-27-2019, 04:01 PM   #18
Rebound
Rebound's Avatar
153
Drives: F33: The 435i Convertible
Why could tightening the drain plug bolt possibly be important?
      01-27-2019, 07:08 PM   #19
cfm56d7b
If a torque specification exists I don't see any reason not to follow it. Proper torque wrench is a small investment and an insurance policy.
BMWinAZ104.00
      01-28-2019, 08:27 AM   #20
ram.matthew
Drives: 2013 BMW 328i
Agreed with this point. A torque wench on Amazon is $20. There's no sense in risking an issue with over or under tightening for such a small amount. The drain plug is plastic, far too easy to over tighten.
      01-29-2019, 10:08 PM   #21
SteveInfante
NewFinishColumbia/detailer
SteveInfante's Avatar
Drives: 2015 F31 xDrive
The torque spec for the plastic 10mm hex oil pan plug is 8 nm . a new plug should be included in the filter if it's OEM. Use a new one every time and it won't leak. I learned this lesson the hard way. After the BMWCCA discount the OEM filter kit is cheaper than the best car parts store filter that doesn't come with a new oil pan plug.
328 F31 xDrive/OSM/Venetian Luxury Line/Cold Weather/Premium/Driving Assist/Nav/Tech "Golden Goose"
78' Honda CB400A project
http://www.instagram.com/steve_inf31
      10-19-2019, 10:50 AM   #22
E_J_Fudd
Elmer Fudd
Drives: 325, X3, 335, 550, 328
Dumb question. All the references say 25nm, but the pug says 8nm max?
