BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Mechanical Maintenance and TSBs: Break-in / Oil & Fluids / Servicing / TSBs and Service Bulletin > F30 driver power window aqueaks when closing
European Auto Source (EAS)
      01-20-2019, 11:02 PM   #1
bavarianride
Drives: bimmer
My driver window squeaks when the power window is being closed. The noise starts when the window is about 3-4 inches from reaching the top of the door frame, and it sounds like something is skidding.
Would spraying silicone lubricant along the bottom window trims help?
      01-20-2019, 11:25 PM   #2
328dX
David
328dX's Avatar
Drives: 2015 328dX wagon
Not the window trim, roll the window down all the way and shove the straw into the channel the windows ride up and down in.
      01-20-2019, 11:25 PM   #3
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
You should be using preservative treatment on all the rubber gaskets and seals on the doors, windows and trunk at least once a year.
      01-21-2019, 05:52 PM   #4
bavarianride
Drives: bimmer
My rubber door seals and window trims(and any plastic surface) are cleaned occasionally with vinylex. Will try spraying silicone down the window side and report back.
EDIT: Yes spraying with straw reaching into the channel works.
      01-21-2019, 10:18 PM   #5
IraHayes
Drives: 635csi
I use silicone spray. It will also increase the life of your silicone wipers.
      01-21-2019, 11:33 PM   #6
bavarianride
Drives: bimmer
Interestingly none of our other cars need this done(including previous bimmer and other german makes). The other 3 windows are still quiet as new, but if silicone spray can prolong window regulators then I will do it!
      01-22-2019, 01:16 AM   #7
328dX
David
328dX's Avatar
glad it worked
      01-23-2019, 12:19 PM   #8
bavarianride
Drives: bimmer
The noise returns this morning, it is not squeaking of window glass rubbing against the track and rubber trim, it sounds like mechanical "tick tick tick" sound of regulator mechanism or something from inside the door panel.
Next step probably is to figure out how to open up the door panel.
      01-23-2019, 07:52 PM   #9
328dX
David
328dX's Avatar
Check out this video, it's for a speaker install but demonstrates the panel removal.
remove the panel, insulation, and re-plug the window switch back in, operate the window while the panel is off and try to pin-point where the sound is coming from. Usually if the motor is still fine it probably just needs lubrication on the regulator/cable assembly.
      01-25-2019, 12:54 PM   #10
bavarianride
Drives: bimmer
Originally Posted by 328dX View Post
Check out this video, it's for a speaker install but demonstrates the panel removal. ...
Great video, thanks! The vapor barrier is glued on though and needs to be removed to access regulator. I don't have a heat gun to reattach the barrier so I will procrastinate for now.
      01-26-2019, 06:25 PM   #11
Dri5/it/lik/U/stol/eet
Drives: 2015 bmw 335i sport
That was funny, going to try but a little more precise with the spray.....lol
      01-26-2019, 10:30 PM   #12
328dX
David
328dX's Avatar
yeah scotty doesn't give a fuck he's function>form haha
      01-27-2019, 04:26 AM   #13
bavarianride
Drives: bimmer
To try something new, the window was lowered to 1/4, 1/2, 3/4, all the way down, then raised to 1/2, 1/4, 3/4 and all the way up, and silicone spray was applied liberally in each of those positions.
My reasoning is that this increases the odds of lubricant moving to the sticky part(s) in various extended/folded positions of the regulator.
So far this seems to work OK(no squeaks so far).
      01-27-2019, 02:51 PM   #14
328dX
David
328dX's Avatar
yeah you usually have to saturate it as the linings absorb some and also you want it to flow down to everything (and remove some debris) and not just stuck in the channel..
