01-21-2019, 09:30 AM | #1 |
Rep 1,571
Chargepipe Preformed Seal
I'm preparing to finally change out the original chargepipe on my 335i at 106,000 this week in conjunction with performed the OFHG repair.
I've noticed that all/most of the aftermarket chargepipe kits either include or as an option, add the upper chargepipe o-ring and clip, but not the lower preformed seal (13718596850) between the chargepipe and inter-cooler. Is that seal prone to leak at this mileage and should replace that as well? Thanks |
01-21-2019, 01:09 PM | #2 |
No 55mph
1619
Rep 8,476
I replaced ALL the seals when I installed my new FMIC & CP on my car with a mere 5400 miles on her - simply good insurance (esp. if you manage to tear/rip one during uninstall) They are not expensive...
On a car with 106K miles = definitely
01-21-2019, 03:44 PM | #3 | |
Rep 445
At that mileage it could be brittle from heat cycles and easily damaged when swapping it over, you can buy a new one and never worry about it. |
