      01-19-2019, 10:24 AM   #14169
kitster
Drives: G31 M Sport
Hi,
Can someone please send me the links for the latest psdzdata and stable esys?
Thanks.
      01-19-2019, 10:26 AM   #14170
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by NesoX View Post
Hey whats up can i have a link for latest PsdZdata lite
PM sent.
      01-19-2019, 05:48 PM   #14171
Camptown
Drives: 2018 340i Xdrive
New Owner
Originally Posted by shawnsheridan View Post
PM sent.
Could you please send me the coding options for the 2018 F30? Thanks in advance
      01-19-2019, 06:52 PM   #14172
shawnsheridan
No. Coding is ECU / hardware specific, not chassis specific. Try coding whatever you want and see if it works.
      01-19-2019, 09:37 PM   #14173
SAMI1820
SAMI1820's Avatar
Drives: 2006 BMW 330I
2006 330i  [0.00]
How or where can I get a token number F30 web **************.com any help really appreciated.
      01-20-2019, 01:14 AM   #14174
adradi
Drives: f30
Shawn there is available a new version of esys Launcher and esys program?
The old one has worked until 31.12.2018
thank's a lot
      01-20-2019, 04:53 AM   #14175
feranox
Drives: BMW F34 335IXGT USA
Hi, can I get links to running programs to start coding my BMW
      01-20-2019, 11:26 AM   #14176
shawnsheridan
PM sent.
      01-20-2019, 11:32 AM   #14177
shawnsheridan
thank's a lot
Unfortunately, E-Sys Launcher PREMIUM 2.8.2 .EST Token expired 12/30/2018, and for now there is no updated E-Sys Launcher. There is a workaround here to rearm it:
E-Sys Launcher Premium Rearm 1.7.0:
https://mega.nz/#!Ywx1hYQA!CaVzmay4A...7w8zJMfKO5Wcqk
Https://f30.bimmerpost.com/forums/sh...62&postcount=1
      01-21-2019, 05:39 PM   #14178
flixtar_media
Drives: F21, F22 & F30
Exclamation BKOMBI2 Coding Issues
Hi guys
Got an 18 plate f21, trying to code the KOMBI (BKOMBI2) as I want to try and have the M Performance logo showing..
Whenever I read the FDL data on BKOMBI2 it displays as per the attached photo.
It doesn't read the data for some reason. Can anyone help please?
Thanks!
Vinay
      01-21-2019, 05:48 PM   #14179
shawnsheridan
Originally Posted by flixtar_media View Post
Hi guys
Thanks!
Vinay
Trimmed PSdZData means either E-Sys has Incorrect Target Connection, or you do not use E-Sys Launcher to open E-Sys, or you use E-Sys Launcher PREMIUM but select wrong car Series or this particular ECU CAFD is not mapped in E-Sys Launcher's CAFD Mapping Database, or you have insufficient Java Memory in order for E-Sys Launcher to map it.
      01-21-2019, 08:03 PM   #14180
ferbmw
Drives: BMW 330i 2016 Sportline
cannot make rearm work
I followed instructions to run rearm 1.7 for esys launcher 2.8.2. but cannot make it works. Screen asks for pin and confirmation. I moved the date first back to nov 2018, no antivirus working, run the script and the screen again ask for pin and confirmation. Any ideas?
Thanks
      01-21-2019, 08:05 PM   #14181
shawnsheridan
Thanks
No. Ask Rearm Script Developer Tony about it.
      01-23-2019, 11:59 AM   #14182
cruising6
cruising6's Avatar
Drives: E90 335d 286
Hi.
Is that ENET cable work with e90 or just F series ?
      01-23-2019, 12:15 PM   #14183
shawnsheridan
Originally Posted by cruising6 View Post
Hi.
E-Series must use a K+DCAN Cable (USB x OBD).
F / I / G Series use a ENET Cable (Ethernet X OBD).
      01-23-2019, 01:52 PM   #14184
cruising6
cruising6's Avatar
So can I only test it on the f series?
I want use this interface to reflash DDE like winkfp on E series after wrong remap. I started Ista-P loader and the IP address does not appear connected to e90 lci 2011. On F series the car give IP address to notebook LAN interface(dhcp sever) ?
Thank you
      01-23-2019, 01:55 PM   #14185
shawnsheridan
Thank you
K+DCAN is for Diagnosis and Coding only. if you want to flash E-Series ECU with WinKFP, you need an ICOM Interface.
      01-23-2019, 01:58 PM   #14186
cruising6
cruising6's Avatar
With ENET is not possible? In ISTA P expert mode.
I reflashed with K + Dcan many E series car.. Last car on monday(2009 N47 318d).
      01-23-2019, 01:59 PM   #14187
shawnsheridan
Not for E-Series.
      01-23-2019, 02:13 PM   #14188
cruising6
cruising6's Avatar
Not for E-Series.
I have solution for E series with K+ DCAN. I need solution for Series F.
I downloaded v.63.3_PSdZData_Full.
      01-23-2019, 02:15 PM   #14189
shawnsheridan
For F-Series you can use ENET Cable.
      01-23-2019, 09:34 PM   #14190
Almaretto
Almaretto's Avatar
Drives: Test Vehicles
Really risky, but to each their own. Cannot do MOST modules, though.
