02-09-2024, 04:01 PM | #4005 |
Rep 27
https://datazap.me/u/slippybackside/...?log=0&data=10
Can someone please tell me what looks wrong here? Car overboosts midrpm Any leaks Also pulls good chunk of timing My iat fly about 20 during the pull as I've got open intake Daw ultraflow Tu pump 93 octane Mppsk exhaust Kyostar with proram air filter Thank you Last edited by foreignplayer; 02-09-2024 at 04:10 PM.. |
02-12-2024, 04:35 AM | #4006 | |
Rep 3,886
02-12-2024, 06:10 AM | #4007 | |
Rep 3
bump
Bumping this in case it gets missed
02-12-2024, 08:29 AM | #4008 | |
Rep 4
02-12-2024, 08:59 PM | #4009 |
Rep 966
Looks amazing. No complaints.
Dustin Braun @ Braun Performance Tuning
02-12-2024, 09:13 PM | #4010 |
Rep 44
Whatup fam! Switched from BM3 Stage2 93 Oct to BM3 Stage 1 93 Oct today at 147k miles. Seems a lot smoother when driving. Can anyone give me some insight on this: https://www.bootmod3.net/log?id=65ca...040d6609f5c826
Current mods: MST Intake, Burger Turbo Inlet, Evolution Racewerks HF DP & xHP Stage 3. Thanks in advance! |
02-12-2024, 09:26 PM | #4011 | |
Rep 966
milanski10.00 |
02-12-2024, 10:39 PM | #4013 |
Rep 44
Thanks so much! I normally fill up at Costco, so probably the culprit. Also, I changed from OEM to NGK sparks around 127k miles and am at 147k now; do you think it’s about time? I thought it was typically a 40k-60k interval? I know there’s probably a thread on gapping, but if you know off the top, what gap should I be running on NGKs? Thanks!
2016 340i | F30 B58B30M0
02-12-2024, 10:44 PM | #4014 | |
Rep 966
As for the gap I do not recommend gaping them. 0.030'' is what I recommend which is oem factory.
02-12-2024, 11:12 PM | #4015 | |
Rep 44
Hate to ask for too much but would you mind weighing in on a post I started on oil? (https://f30.bimmerpost.com/forums/sh....php?t=2082140) Trying to get a better understanding of what to run. Thanks again! |
02-12-2024, 11:17 PM | #4016 | |
Rep 966
Motul xcess gen 2 5w40 is the way I go.
milanski10.00 |
02-14-2024, 03:37 PM | #4017 |
Rep 1
dipping in and out of power while on it in sport+
Power delivery doesn't feel smooth while accelerating hard. Im new to the forum and can't figure out how to link an image so ill just type it out
Log of ignition timing Ignition timing 1: 14.8 Ignition timing 2: 6.8 Ignition timing 3: 27.6 Ignition timing 4: 14.8 Ignition timing 5: 27.6 Ignition timing 6: 27.6 This data was logged at roughly the time where I felt the the most lack of power On the fence about buying and replacing plugs as someone said it could be a vans actuator. Worth being said I'm using bm3 stage 2 93oct tune. Any input helps |
02-14-2024, 03:47 PM | #4018 | |
Rep 218
unfortunately there is little to nothing we can do with the data you provided. There is no way you are getting 27 degrees of advance timing on WOT. You need a pull in (preferably) 4th gear from around 2 to 6.5k rpm on WOT. Tick every log parameter. Then upload the log file on bootmod3 site if you know how. Worst case upload the log file here and someone else will upload it on bootmod3 site or datazap |
02-14-2024, 04:37 PM | #4019 |
Rep 3,886
As DieselDuck said - you need to understand logs don’t work as snapshots - you need the full picture, the progression, the various parameters in combination. Do a proper log (see post 1 of this thread) and post it here, it is pretty simple once you have the log.
02-14-2024, 10:37 PM | #4020 | |
1297
Rep 3,539
2017 m240i xDrive 10.67@132.32mph w/bm3
02-15-2024, 12:58 PM | #4021 |
Rep 218
I'm on MHD so I didn't know it auto-uploads on BM3, fair enough. What I do know is I prefer reading logs on datazap (that's just preference) by a mile and uploading it on datazap takes about a few seconds.
02-15-2024, 01:12 PM | #4022 | |
1297
Rep 3,539
See I much prefer the bootmod3 interface for logs but it's just preference I guess. Datazap is easy to use for sure!
DieselDuck93.50 |
02-15-2024, 03:07 PM | #4023 | |
Rep 27
02-17-2024, 05:34 PM | #4024 |
Rep 966
You're not logging throttle angle. Does it feel like its hesitating when it overboosts? Wondering how much the throttle closes. But the overboost doesn't seem extreme to me.
02-21-2024, 05:24 AM | #4025 |
Rep 80
I apologize for the cross post. I had a other thread where I posted my logs for a bit of insight but didn't get any traffic on them so I thought posting here would get a bit more exposure... My logs with my comments below.
———————————— (Bootmod3 OTS maps used) Here are some pulls from today. Stage 2 91 oct (3rd gear) https://www.bootmod3.net/log?id=65d2...f7375a14155528 Stage 2 91 oct (4th gear) https://www.bootmod3.net/log?id=65d2...f2c967f9aa527f Boost falls off 8psi over the rpm band, and when looking at the "Boost target" actual boost is following the target pretty well... Is this normal for this map? BM3 tuners bled off boost as rpm increased or am I misinterpreting this info? Also seems like there is a 2-4deg timing retard to correct ...something? There is no knock, and AFRs look sweet (even for me! ). This tank is almost empty so I'm going to put some E30 back in, and try that map again... Stay tuned! ———- OK... I'm back with E30 logs. Keep in mind that my stock clutch can't hold the E30 tune well but this is way better than what I had before. AFRs more in-line with what I'm used to seeing here too... I still am feeling sketch about the part throttle (the conversation was about stoich AFRs under boost), but you guys have given me a little more confidence about it. Stage 2+ E30 (3rd Gear) https://www.bootmod3.net/log?id=65d2...f7fd189d7dd550 Stage 2+ E30 (4th Gear, little clutch slip at 3300rpm, and 3700rpm) https://www.bootmod3.net/log?id=65d2...f7375a14156014 3rd gear E30 pull is the cleanest.. Looking at boost it fades about 2psi or so as RPMs build, but the difference here is that it deviates from the target boost line by that 2psi. So I am losing boost up top. With that, I see the big timing correction. There is a 7-8 deg timing retard over the rpm band!!! Thinking poor gas quality, plugs or coils... any thoughts? |
02-22-2024, 02:57 PM | #4026 | |
Rep 966
Your E30 mix must be off because those E30 logs look terrible and you're probably getting some knock with those kinds of corrections. Your 91 logs don't look bad which is what makes me think the E mix was off. Finally, for our stock turbos yes, we taper off the load target as you progress through the RPM range because they just aren't capable enough to hold load to redline. Hope this helped. Edit: I'm not sure how low your fuel was but the car reduces power once your fuel levels cause the fuel light to go off.
sigterm2.030.00 |
