09-16-2020, 04:39 PM | #46 | |
Rep 22
What did you look for to make sure it would swap in? I got a line on a 2019 M240i that I think will work and was going to pull the trigger. Everything I can find points to it still being a B58B30A so I’m thinking it should be a drop in but this is my first go with BMW’s. |
09-16-2020, 06:55 PM | #47 | ||
Rep 201
09-16-2020, 08:18 PM | #48 | |
Rep 22
I was sitting at a stop light when we got a stutter and then a misfire code. We went to pull away and it was in limp mode and smoking like Cheech and Chong. By the time I got it home and tested the compression it was pulling good numbers across the board with the exception of cyl5 (25psi)...I use the old “put some 20W50 in the cyl” trick to see if maybe it was just a washed out cyl... no dice, only got 50psi on the gauge. The plugs that came out didnt look that bad, normal ware, with the exception of #5 that had some extra carbon build up but nothing alarming. Also, had a chance to scope the inside of the cyl and piston looks good (no cracks/hot spots/etc..) It was actually unusually clean compared to the other ones. It did have some rusty red spots on it but I assume that was from the fuel additives. So, here we sit with the car on jacks and looking for a transplant to bring her back to life. |
les anderson145.50 |
09-16-2020, 09:43 PM | #49 | |
Rep 1,369
09-17-2020, 12:21 AM | #50 | |
Rep 22
My long winded theory on fuel..... Even if the pump said that it was 93 like they do on the east coast (DAMN CA!!) it would have to be an average of 93 or 93 peak, either way you would likely actually have something lower in the tank frequently... That being said not sure if I mentioned it but I would bet dollars to donuts that the difference between a 93 and 91 Tune is negligible ( I ran 91 in my A5 on a 93 eurodyne tune for years..yes years with no issue). Anyway....here she is motor ready to yank... Anyone know if the trans has to come out too or can you get to all the bell housing bolts with tiny hands? |
09-17-2020, 03:44 PM | #51 | |
Rep 91
You got me worried now. |
09-17-2020, 07:22 PM | #52 | |
Rep 1,452
2022 CT4-V Blackwing 6-speed
eluded3029.00 |
09-17-2020, 08:09 PM | #53 |
Rep 180
Same. I got basically the same mods, bm3 stage 2 91 octane. I am very confused because it's just an OTS map.
AFE Filter | BMS Intake Pipe
CTS DP | CTS CP | CTS Heat Exchanger PTP Turbo Blanket | AEM WMI Kit | Custom Exhaust PJ ACN91 + Meth tune| XHP Stage 3 |
09-17-2020, 08:10 PM | #54 | |
Rep 1,288
I'm amazed how fast he replaced that engine... then I looked at his location and saw SC... They know how to do it right down there... Thumbs Up! |
09-17-2020, 08:13 PM | #55 | |
Rep 180
09-18-2020, 08:39 AM | #58 |
Cheapskate
4447
Rep 4,993
Really, you guys are worried about a tune after a freak accident? How does a tune cause an engine to blow while waiting at a stop light?
He hasn't really diagnosed the failure yet. For all you know it could be a head gasket, valve seal, anything. Good luck with your repairs. |
09-18-2020, 09:19 AM | #59 |
Noob
70
Rep 254
When I saw the title I was like damn thats not good, I was planning on getting another f32 with the b58 as my next car.... and then I saw his mod list and was like oh no wonder why it blew lol, glad it all worked out for him in the end. 600+whp for a daily is too much for a daily IMO but to each his own.
FBO, MHD Stage 2+ E20, Xhp Stage 3
09-18-2020, 12:21 PM | #60 | |
Rep 82
09-18-2020, 04:34 PM | #61 |
Rep 281
This is true and no disrespect to the stage 2 guy but running on 91 and relying on octane booster on an agressive 93 map would need a lot of logging. People running boostane are often requiring double plus what the bottle says to get the required octane.
Personally I run a 93 map with 94 octane fuel and 3-4 litres on e85 just to ensure the octane in there. On straight 94 I pull timing although generally within the 3 degree limit. Hope you guys sort the engines soon |
eluded3029.00 |
09-18-2020, 09:40 PM | #62 | |
Rep 931
if anything thousands are running around OTS tuned. Freak accidents happen even stock. I’ve seen a head split due to poor casting, never been tuned ever but this is super rare. Shit happens its life and its not just cars either, shit can and does happen anywhere sometimes generally speaking |
09-19-2020, 01:34 AM | #63 | |
Rep 22
To another posters point, it sounds like its a fairly common enough issue among stock and modified b58’s alike. And,...lots of people are running around with the OTS tune no issues. It’s anyone’s guess at this point... Started tearing into it to see if we can figure out what the deal was....pics coming soon |
kern4174446.50 les anderson145.50 |
09-19-2020, 01:42 AM | #64 |
Rep 1,239
Yeh although as said above we dont actually know whats failed, running the 93 map on 91 and hoping octaine booster will fill the gaps is not the best
did you pull any fault codes? |
09-21-2020, 12:52 PM | #66 |
Rep 684
Drives: Your mom crazy
Garage List 2020 BMW X3M CURRENT [0.00]
2016 BMW 340i BEAST [0.00] 2011 BMW 335i RIP [0.00] 2003 BMW 330i SOLD [0.00] |
Thoughts and prayers man. Good luck with your teardown.
2020 X3M
MG Flasher; Wedge Performance E50 tune MSS Urban; Rohana RFX11 |
