03-01-2016, 12:51 PM | #111 |
Rep 6,311
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [8.58]
2020 BMW M340i xDrive [9.00] 2018 BMW 340i M Sport [7.38] 2006 BMW 330i Sport [5.83] 2004 BMW 330i ZHP [7.13] 2000 BMW 328i [6.17] |
03-01-2016, 12:53 PM | #112 | |
Rep 2,802
03-01-2016, 12:53 PM | #113 | |
Rep 1,232
03-01-2016, 12:55 PM | #114 |
Rep 1,418
I did read the whole thread.
His added justification comments withstanding, the net net was 1) he wanted a better loaner and 2) he's going to try and see what additional reparations he can secure from the dealer. If they don't, then it ends there. I don't see what the big deal is. The value OP added to this community outweigh his personal form of consumerism. |
03-01-2016, 12:57 PM | #115 | |
Rep 2,802
03-01-2016, 12:58 PM | #116 | |
Rep 6,311
CarFax has zero right to the information it reports and for the benefit of the affected owners BMWNA ought to make sure this repair doesn't make it into records that CarFax has access to. |
03-01-2016, 01:01 PM | #118 | |
Rep 1,232
03-01-2016, 01:02 PM | #119 | |
Rep 1,418
03-01-2016, 01:03 PM | #120 |
Rep 540
Drives: 22 G05, 22 G26
I would just want to know if it is s new engine or refurbished. Let's not kid ourselves we know they have the right to replace it with 'used' as long as they cover it under warranty. Most parts I would not care about. The engine is one I would.
03-01-2016, 01:07 PM | #121 |
Rep 1,232
I highly doubt they will replace it with a new engine, I had a transmission problem when I first got my car and the transmission needed to be replaced, their intention was a remanufactured tranny. When I complained that I didn't want a brand new car with a remanufactured tranny they opted to put me in a brand new car (same exact spec) instead of replacing the faulty tranny for a new one.
03-01-2016, 01:28 PM | #123 |
Rep 2,802
03-01-2016, 01:32 PM | #125 | |
Too much is never enough
655
Rep 3,079
Also, bear in mind that during all of the QC checks that are performed along the way, there's always a chance that a motor might not pass a test and be pulled from the line for evaluation. They would correct whatever the issue was (if feasible) and place it in service inventory. Even then, they're essentially brand new. Either way, there's little to be concerned about if you know that BMW themselves were responsible for the refurbishment. They're paying quite a bit of money to have the dealership do the swap and they're going to warrant the replacement. You can be sure they're not going to be cutting any corners. |
03-01-2016, 02:26 PM | #127 | |
Rep 15,858
The pilot bearing you refer to is fitted in the dual mass flywheel, (not the crankshaft) and does not require any engine investigation to check or replace. Transmission would have to be removed to physically check the pilot bearing. |
03-01-2016, 02:28 PM | #128 | |
Rep 3,622
BMW CCA Member #516012
03-01-2016, 02:45 PM | #129 | |
655
Rep 3,079
And, it's a case of semantics. A pilot bearing IS a guide bearing. Based on the description (binding clutch, etc.), NOTHING internal to the motor would ever cause those symptoms. It's also why this apparently only affects manuals... |
03-01-2016, 02:46 PM | #130 |
Rep 843
It's sounds to me there are a couple things wrong here.
One, this is not a Carfax thread, feel free to start one. Two, there is massive speculation about what is amiss, what can happen, and why the engine is replaced. I would think that if they could get away with a flywheel or tranny replacement they would do just that. They are replacing engines. I thank the original poster for notifying us. I think he is being highly inconvenienced and can ask for whatever would ease his worries. #1, if I bought a four door and not a coupe I wouldn't feel bad asking for another sedan, 5-series or not. He is also the unlucky owner who is going to be living with the replacement motor, don't tell me if it was you you'd drive off in the new motor and never give it another thought. Funny how when people don't have to sign their names or speak face to face they don't feel bad about trashing an entire generation of people. Not really that far away from the "peculiar institution" line of thought. |
nozydog465.00 |
03-01-2016, 02:50 PM | #131 | |
Rep 5,776
Many industries such as Airline and Hospitality do offer something above and beyond just making the current problem right. And it makes a huge difference if he owned the car because then the service record shows engine replacement which is a big red flag for the next buyer.
Last car: 2011 335i Msport. JB4. Vrsf CP Last edited by jgoens; 03-01-2016 at 03:17 PM.. |
03-01-2016, 03:11 PM | #132 | |
Rep 15,858
The pilot bearing I refer to is pressed into the dual mass flywheel. It is not in the end of the crankshaft (see RealOEM). I'm not thinking anything to do with clutch release/thrust bearings. If it is the pilot (spigot) bearing then it is a transmission removal and inspection, does not require an engine sump pan drop. A worn crankshaft guide/thrust bearing can have an impact on clutch performance and action, as the crank moves axially to and fro, specifically forward in the crankcase. Also noise and vibrations can come back through the clutch assembly. |
