04-23-2018, 09:19 PM | #1277 | ||
Rep 1,805
This is a critical aspect of our cars... probably the most important aspect. Can you explain in detail how your process works and your willingness to work with the customer on further revisions? I assume this is not a 1-2 map revision situation and then we're done. Thanks Pete
2014 F30 335i / 2014 F31 328d / 2014 F22 m235i
2019 G05 5.0 / 2012 E70 X5 50i / 2007 X5 3.0is 2011 e93 M3 / 2009 E60 M5 / 2004 E46 M3 2017 Alpina B6 22 Ram Trx / 22 M5 CS |
04-23-2018, 09:21 PM | #1278 | ||
Rep 1,805
But what are we going to do at this point?
04-23-2018, 10:06 PM | #1279 |
Rep 1,469
IDK. Seems a bit steep, yet I still think a custom tune is the best route for anyone. At $300 though, I may stick with the OTS map for awhile. It's more than enough power. Let me know how it goes for you. I would personally prefer an HCP tune, but if he's too busy to tune, i'm not sure how it will happen LOL.
I wonder how much back and forth is involved with custom tuning. You send a file, they send a file, rinse and repeat? That could be multiple days and runs to a specific "safe" spot to test.. LOL seems like alot of work, but again probably worth it.
FSociety3815.50 |
04-23-2018, 10:33 PM | #1280 | |
Rep 529
That being said, knowing how familiar a person is with a platform is crucial as is hearing some testimonials from people they recently tuned specifically if they are the exact same platform as my car because it doesn't really matter how power or torque they can make on an s55 with full e85 if I am a 91 octane n55 pwg guy. My ots map sucks, it just doesn't seem to play well with my car. I reached out to a tuner and he told me I have a different rom version than most, I asked him to elaborate more on the process and explain how exactly he can solve my issues but he only said things like I think I can fix it and it will be smoother and faster. At this point I will be waiting for someone else to tune the exact same car as mine and provide a detailed review on the drivability, power delivery benefits and show logs comparing ots to custom tune before I throw any more money at it. Some people in this post are questioning why the need for custom tune, in my case it's not to make more power or anything it is simply because the ots map just isn't that great in my instance and the car stumbles/shudders in the lower rpm range under wot making me have zero confidence in really getting on the throttle. I have also had issues with higher rpm knock including a super knock dme code being thrown. Also have long duration back to back throttle closures that make the power delivery car from smooth... so ya trying to get a proper tune to get the most out of my car after dropping a bunch of money on bm3 just to end up with a lot of the same issues as I had with jb4
2013 F30 335i xDrive M-Sport 6MT (FBO/BM3 custom tune by HCP, 91 oct, 550i clutch, xDelete)
the dope steez404.00 |
04-24-2018, 07:07 AM | #1281 | |
Rep 1,499
Dang man that sucks. Sorry for your troubles. Just curious are you EWG or PWG and what ROM version.
Regarding the tuning process, I signed up for bm3 way early, before they had solid OTS maps. So with the OTS map they had at the time for Stage 2, 91 octane, I spent several days with Dzenan tweaking the OTS map. Basically, I would log via the bm3 app then send in map revision request through bm3. This would notify Dzenan and he would review my log, make tweaks, upload a revised OTS map that I would flash and log again. Rinse repeat for about 4-5 iterations until boost, timing fuel, etc. all looks good. I'm assuming a custom map would be a similar process. Quote:
FSociety3815.50 |
04-24-2018, 07:30 AM | #1282 |
Rep 647
I unlocked and flashed over the weekend. After initial flash I received codes galore.. fuel pump code, climate control code, DME code, OBD code. Flashed back to stock. Reflashed with same error codes again. Did an online recode and fixed the issues. Flashed to 93 stage 2 with about an E25 mix and having rough idle on startup until the car is slightly warm. I plan to flash to E30 map next weekend. Hopefully that will solve my issues with cold start stumbling and missing. Has anyone had issues running E mixes on 93 stg 2 map.? I have run E mixes on JB4 with no issues. I assumed the DME would correct for mixture.
04-24-2018, 07:42 AM | #1283 | |
Rep 1,499
I'm currently running about 25 ethanol on stage 2, 93 octane map. Try running the stage 2, 93 octane with cold start set to OEM or flash the stage 1 map (keeps OEM cold start). That will probably help with the stumble.
Drpoomanchu307.50 |
04-24-2018, 08:20 AM | #1284 | |
Rep 92
My previous car, FBO Evo X, my tuner went from a base map to done in about 5-6 total days of going back and forth maybe 1-2 times per day with logs as time permitted. After seeing the variance in ROM version and the PWG/EWG differences I'm going to predict that a good custom tune will really be game changing for most users. |
FSociety3815.50 |
04-24-2018, 08:39 AM | #1285 | |
Rep 105
I have been seeing a lot of knock in my BM3 Stage 2 93 tune. 23 detected knocks in 15 minutes of driving, both low RPM while driving around and high RPM during WOT pulls. The scariest part is I would have had no clue until I logged yesterday, because I don't feel anything otherwise, things feel smooth overall and the power is great. I wonder how many other people are also getting knock and just not logging to see it. 1. Changing spark plugs soon and seeing if that changes things 2. If I still have issues, I may add a touch of E85 to see if its my fuel (BP 93) causing issues due to not meeting rating 3. If all else fails, I will flash the stock tune and see if I still have knock. It sucks because I love the Stage 2 power and overall fun this tune provides, but it's also very unsettling to see quite a few others reporting the same issues. |
04-24-2018, 09:04 AM | #1286 | |
Rep 279
i want to get tuned on a dyno and get it done over with one shot.
04-24-2018, 09:09 AM | #1287 | ||
Rep 529
Ya dzenan tried a couple tweaks to v7 for me seem d like it was heading in the right direction as far as the stumbling goes until the last tweak he made which brought it back and since then I haven't heard back from him in a week. That's where knowing a custom tuner has availability to work with someone making revisions to a custom tune until it is working properly is very important. I don't doubt ptf could fix this for me I just don't think they have the time and aren't motivated to fix it for me. Also, car doesn't have the shudder/stumble issue on stock flash and yes I have already upgraded plugs to ngk gapped to 0.02
04-24-2018, 11:36 AM | #1288 |
Rep 808
I'm reposting this on this thread from the log repository as I think it would be interesting to compare times with some of you guys.
I logged some 60-100 mph runs, and I found that if you import the logs into data zap you can plot time against vehicle speed and get pretty accurate numbers. Now because I didn't know this I wasn't actively trying to to 60-100 as quickly as possible, so some shifts are quicker than others. I did hit 60 mph between 3900 and 4000 rpm on all runs and shifted at between 5800 and 6000 rpm so results should be comparable. PTF revised map V2 for 93 w/94 oct fuel: 6.58 sec PTF revised map V2 for 93 w/94 oct fuel (2): 6.51 sec OTS V7 93 oct. map w/94 oct fuel: 6.50 sec OTS V7 91 oct. map w/94 oct fuel: 6.44 sec OTS V6 91 oct. map w/91 oct fuel: 5.96 sec (v-power ftw???) Interesting to me that I was able to get there almost half a second quicker on the 91 map w/ 91 oct Shell v-power.. |
04-24-2018, 12:38 PM | #1289 | |
Rep 1,206
Learn anything about your fuel pump dip?
04-24-2018, 01:40 PM | #1290 |
Rep 116,006
04-24-2018, 07:44 PM | #1292 | |||
IG @bmwF9xG80
3816
Rep 7,593
No issues starting up on V5 or V6 93 Stg2 either with E25 blend in the tank the last month. if u dont feel it cutting off throttle then you're ok
60-130 6.5s X4M
60-130 5.04s G80 M3 Stock Turbo 60-130 4.82s | 9.4@148mph 1/4 Hybrids IG: @bmwF9XG80 |
04-24-2018, 10:44 PM | #1293 |
Rep 647
04-25-2018, 10:19 AM | #1294 |
IG @bmwF9xG80
3816
Rep 7,593
Both actually, the adjuster just came out last week and I just put everything to OEM. I've only tried the E30 map since V5 when they new Cat-Heating was introduced which is 100x better than previous cold-start delete that would definitely make the car shake sometimes even on pump but not all the times.
60-130 6.5s X4M
Drpoomanchu307.50 |
04-25-2018, 10:32 AM | #1295 | |
Rep 647
FSociety3815.50 |
04-25-2018, 12:44 PM | #1296 |
Rep 969
Default for stage 2 is cold start cat heating delete (so OEM cold start is off) and burbles. You can change these now to your liking on the editor on the OTS maps.
Drpoomanchu307.50 FSociety3815.50 |
04-25-2018, 12:59 PM | #1297 |
Rep 1,469
I miss my cold start. I think I am going to add cold start back and keep burbles as is. Not sure why anyone would need any more burbles...
FSociety3815.50 |
04-25-2018, 01:15 PM | #1298 |
Rep 2,649
I turned off my burbles completely, and cold start delete is good so you don't piss off neighbors and it's better for the engine if you don't have a catted DP. Cold starts wears the engine faster.
