01-07-2019, 07:44 PM | #2 |
Rep 1,906
I think you want something that is both safe and effective. Most oil additives are questionable at best regards effectiveness. Personally I'd pass on oil additives; the only additives I use are fuel system cleaners, stuff like Techron.
01-07-2019, 08:35 PM | #4 |
Rep 403
Amazon reviews about this product seems to be quite good.
https://www.amazon.com/Liqui-Moly-20...ustomerReviews I'm just scared that it's not compatible with n55 engine lol. |
01-07-2019, 08:38 PM | #5 |
Rep 16,082
There's nothing all that special about the lubrication requirements of the N55. FWIW for my first post-BMW maintenance oil change I went with Liquimoly Molygen plus Ceratec. My gas mileage went up by 2 MPG.
01-07-2019, 08:50 PM | #6 |
Rep 403
But ceratec is different from others lubricants, it will form a glass like coating on all the engine internals, that why I'm a bit scared to pour that stuff into my engine
01-08-2019, 07:38 AM | #7 |
Rep 16,082
Then don't.
01-08-2019, 06:49 PM | #8 |
2020 Z4 M40i - 2022 M4C Convt
3129
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Best to skip it because you don't really need it. If is ain't broke don't fix it.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT |
01-08-2019, 07:16 PM | #9 |
Rep 4,877
I don't see any reason why one would do this. The stuff is expensive, and fuel savings (assuming 2MPG) wouldn't even cover the cost of the product during the recommended oil change interval.
Couple in how ludicrously expensive the engines are in these vehicles, you'd be better to waste money on better grade gasoline as that would at least help clean out carbon in the top end, vs risking any issues. |
01-08-2019, 09:06 PM | #10 |
Rep 16,082
If you grasp the concept of what it does then using it makes sense. I don't think you've done due diligence, as it's not something you add with every oil change, and it has little to do with mileage, although that is a nice side benefit, everything to do with extending engine life. BTW, 'better' gas might help keep injectors clean, but it does nothing to keep the intake valves clean on our direct injected engines.
alohasurftoad3078.00 bgalakazam94.00 |
01-09-2019, 11:04 AM | #11 |
Rep 772
Drives: 2015 435i grand coupe xdrive
Because N55 engines like to spin rod bearings I would think everyone should use it.
2015 435i grand coupe xdrvie (current)
2006 F250 powerstoke CCSB (current) 2014 M235i Black on Red (SOLD) / 08 e90 335i MT Pure Stage 2 High flow (SOLD) 08 128i 6MT (SOLD) / 08 335i 6MT Pure stage 1 (SOLD) |
01-09-2019, 07:41 PM | #13 |
Rep 4,877
I know what they "promise", and snake oil has been marketed like this for years. Perhaps this actually makes a difference, but if you spin a bearing with this crap in the crankcase, kiss your warranty good by.
You don't buy a BMW expecting hitting a million miles on the engine. You can buy a new Honda Civic for the same price as a replacement BMW short block. |
01-10-2019, 09:15 AM | #14 |
Rep 14
01-10-2019, 11:42 AM | #15 |
3129
Rep 5,264
Might have missed some N55 spun bearings threads but have been here since 2011 before the N55 came out & can't remember one.
Would be interested because my 135is with about 65,000 miles on it is an N55. There are a very small number of threads maybe 6 on N55 bearing failures at N54tech, the BMS JB4 modified forum, but not many out of the thousands of modified N55 posts there.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT Last edited by BEAR-AvHistory; 01-10-2019 at 11:57 AM.. |
01-10-2019, 11:45 AM | #16 |
Rep 2,654
I used Ceratec initially when I started doing my own oil changes. One Ceratec treatment and subsequent treatments with LiquiMoly MOS2 with each oil change. My engine seems quieter on idle and MPG has increased slightly as well. I like LiquiMoly products.
Billfitz8243.00 rangeseeker7.50 |
01-11-2019, 06:37 PM | #17 | |
Rep 403
I went to see a 2013 335 with a friend and engine broke previous day, rod bearings. They seems to break around 105-120k miles if not maintained well. |
01-11-2019, 07:27 PM | #18 |
Rep 3,680
Worth a watch I think.
01-11-2019, 07:46 PM | #19 |
Rep 4,877
Keep in mind all modern approved oils have a lot of these friction modifiers already included, with no risk. The approved oil versions are all about getting lower friction for higher mileage ratings to hit the CAFE levels.
5W30 from 1999 isn't the same as 5W30 from 2019. I had a 2013 Acura CL 6MT. My buddy swore by Redline oil as "the magic bullet for butter shifts" and he used it in his Camaro. I put it in my Acura, and it was nothing shy of brutal. Every shift was notchy, the syncro's failed to mesh smoothly. Dumped it out, put in Honda MT oil, and got butter shifts back. The engineers know what's best is most cases. It was a really slick $100 lesson of leaving crap alone. |
01-11-2019, 09:28 PM | #20 |
Rep 16,082
It's interesting, as it seems to confirm that Ceratec reduces friction in the engine. I knew that when my 0-60 times went down while mileage went up after using it. But that's not the primary reason to use it. That would be engine life. The nano particles provide a second method of lubrication over and above that of oil alone, reducing friction better than what either oil or nano particles alone are capable of. Less friction means less wear on bearings, rings, camshafts, pistons, and with any luck the oil pump and timing chain.
rangeseeker7.50 |
01-11-2019, 10:21 PM | #21 | |
Rep 3,680
I am interested in the difference in 0-60 times you noticed, because I'd bet dollars to donuts that it was not due to the Ceratec, but was caused by outstanding circumstances, i.e. temperature, altitude, wind direction, weight in the car, the way you launched it, etc. It seems like it's not out of the realm of possibility for Ceratec to give you an extra horsepower or two due to its ability to reduce friction and resistance in the cylinder, but we both know that won't make a difference in 0-60 times, unless you're measuring to the 100th decimal place.
01-12-2019, 08:38 AM | #22 |
Rep 16,082
By trade I am an engineer. I know how to conduct tests that are valid. As for how Ceratec works, it's not an oil additive per se. It doesn't alter the properties of the oil. What it alters is the properties of the parts in the engine that it bonds with. That's why you don't add it with every oil change. Once the pores and fissures in the parts are filled there's nothing to be gained by adding more Ceratec until it's been washed away, or more fissures have developed, which takes a few oil change intervals.
XxThe_RemedyXx967.00 Walker_CW28.00 |
