11-24-2018, 09:00 PM | #23 |
Rep 10
Info on EGR / Cooler failures
My 2014 has 106K miles and I started smelling diesel exhaust in the passenger compartment. Tear-down revealed that the exhaust flex pipe that connects the two ends of the EGR cooler had burned through - not replaceable separately. Coolers are back-ordered two months from European suppliers, none available in the US.
I talked to BMW North America - they are unwilling to give any info except to say that previous (including third party) repairs may be reimbursed upon dealer inspection. The official EGR cooler recall starts 17 Dec 2018. The local BMW dealer was unhelpful and unfriendly, routing me to their Subaru service department presumably to get rid of me. The US recall is for 40,000 cars, but globally the recall has expanded to 1.6 million vehicles. Based on parts supply, I'm betting my F30 could be undriveable for many months. I bought a diesel Passat yesterday to fill those months. https://static.nhtsa.gov/odi/rcl/201...8V755-4565.pdf https://www.bmwblog.com/2018/10/23/b...lion-vehicles/ Last edited by Alcuin49; 12-03-2018 at 11:26 AM.. |
11-26-2018, 12:15 AM | #24 |
David
786
Rep 2,010
I just purchased a 2015 328d wagon, The car was removed off CPO and sold to me without a warranty, none of the people at the dealership could tell me why, this recall explains that reason, they cannot sell a CPO vehicle with a recall..
I feel like I was taken advantage of now. |
11-26-2018, 08:07 AM | #25 |
Rep 368
Hmm... I have been getting the occasional exhaust smell in the cabin as well, did you have any other issues? If it was actually a failure of the flex pipe and not the EGR valve itself, it sounds like the intake melt down might still be a possibility even for people with the EGR removed via tune or unplugged.
11-29-2018, 10:13 PM | #27 | |
Rep 424
12-03-2018, 11:08 AM | #29 |
Rep 10
My nearest BMW dealership (BMW Southpoint) wouldn't make an appointment for the EGR cooler repair over the phone "because the recall won't be officially announced until December 17." So, I rolled down two windows so I could breathe and drove there. In person they made an appointment for the recall work for Dec. 17. No offer of a loaner, no advice on not driving to avoid intake fire, no indication that they will actually have parts on the 17th.
I had thought when I bought this car that it could last a long time - I work 60 miles from home, so I run up the miles quickly. I have been meticulous about maintenance including things "not required", such as trans fluid change. I will sell the car as soon as it is repaired because of the ridiculously bad handling of this by both BMW USA and the local dealership. Last edited by Alcuin49; 12-03-2018 at 11:15 AM.. |
12-03-2018, 11:46 AM | #30 | |
Rep 10
Last edited by Alcuin49; 12-03-2018 at 11:48 AM.. Reason: added additional observations |
12-06-2018, 04:36 PM | #31 |
Rep 66
Hi,
I bought my 420xd at only 22000km (14000miles). At 30000km got the first revision and the BMW boys checked all the parts of the car, no problems reported. At 33000km the car started to shake, the boys found out that the EGR valve is faulty and that there is a recall so I got a new EGR valve and the coolant changed. at 37000km the car smoked on the highway at around 70mph. Result, EGR radiator got faulty and the intake manifold melted. The car was 1 month out of the warranty but luckily BMW covered all the parts and labor. Ever since i'm disappointed and I feel that the engine does not have the same shape anymore. This is how the pain looks: |
12-07-2018, 05:23 PM | #33 |
Rep 1,799
Hah, moi aussi.
12-13-2018, 09:06 AM | #34 |
Rep 368
Turns out the occasional fumes I was smelling were coming from a failed EGR cooler. You can see the soot around the cracked part.
And here's the crack all cleaned up |
12-13-2018, 09:58 AM | #35 |
Rep 1,799
What's ironic is that South Korea had the biggest political issue with this egr cooler, and melted intake manifolds and all....
Want to know where the EGR cooler was made?
12-13-2018, 01:16 PM | #36 |
Rep 10
BMW is promising to reimburse for recent EGR cooler-related failures. US dealers have no parts and a technical service bulletin on the recall says "no repair is possible at this time" due to parts availability. My local dealer (BMW Southpoint) cancelled my repair appointment without telling me, so the car is parked. I just bought a used cooler from the UK on ebay.
12-13-2018, 09:54 PM | #37 | |
Rep 424
12-13-2018, 09:55 PM | #38 |
Rep 424
12-14-2018, 01:10 AM | #40 |
Rep 424
12-14-2018, 11:11 AM | #42 |
Rep 1,799
This crack is not the dangerous one. Looking at it, it could have been prevented by anchoring the tube to the wall of the unit, so it doesn't vibrate. Hoping the fixed version has it anchored.
The dangerous failure happens internally, and leaks coolant inside.
12-14-2018, 02:56 PM | #43 |
Rep 27
06-11-2021, 09:33 AM | #44 |
Rep 73
Hey Everyone. Reading through this thread, it would seem that the EGR valve, cooler, and related components tend to be failure prone. I am currently working on my cousins 2014 F31 328d xDrive, and it has been throwing the drivetrain malfunction warning on occasion.
He dropped his car off so I could do a full fluid flush on his car. Transmission, transfer case, and the front and rear diffs. So i figured I would also try to troubleshoot the engine codes that I found. I used an advanced code scanner that identifies and shows advanced trouble codes, (not the P codes) but the BMW specific codes when certain values are out of their range/tolerances. My assumption is that the EGR is allowing more exhaust gas to pass into the intake than normal. I am worried that this could lead to the symptoms everyone is mentioning above, which would equate to costly repairs. My intent is to remove and inspect the EGR valve, then clean it, to ensure it is not getting stuck slightly open due to the carbon build on the solenoid/valve assembly. Does anyone have any other recommendations and/or concerns if the EGR valve is found to be in good health following cleaning? Thanks in advanced. Sorry to hear so many of you have experienced melted intake manifolds. In my opinion, this is really not a good look for BMW to manufacture cars that could fail in a way that could put peoples lives at risk. Not to mention getting exhaust gases in the cabin.
2017 BMW 330ix MSport Estoril Blue - B46, ER Catless DP, ER Chargepipe, FTP Intake Charge Pipe, BMS Cone Intake, BMS OilCC, Bm3 Stage 2. FI Exhaust, xHP Stage 3 OTS Transmission tune. CSFRace heat exchanger. Performance M Brake kit. AFE Carbon Fiber D.A.S.
https://www.instagram.com/bfourtysick/ |
diesel engine, egr malfunction, intake manifold, loss of power |
