01-20-2019, 09:27 PM | #23 | ||
Rep 1,369
2017 M240i/ ZF8 Pure Drivetrain Solutions Stage 1 & torque converter/xHP/ DAW Ultra Flow/ DS2/ Nostrum injectors/ E40 Doug Newton tuned/ ER DP/ Remus axle back/ BMS intake/ FTP CP/ M Perf LSD
chenry2357.50 |
01-20-2019, 10:10 PM | #24 |
Rep 1,219
01-20-2019, 10:15 PM | #25 |
Rep 557
Kern417 - one more reply and I'll help you out and start a new thread for you called: Kern417 doesn't understand MP offerings and needs help
That or you can pick up the phone and call MP or maybe even drop chenry an IM - ive bought things from him in the past and he's super responsive - and it seems he's going to MP tomorrow - we are adults here and at this point you are simply trolling or passing time by e-thuging |
01-20-2019, 10:21 PM | #26 |
Rep 2,964
01-21-2019, 12:27 AM | #27 |
Rep 676
Drives: '17 F31 340xi US Spec
Guys, I have no idea where the confusion came from but let me explain. Actually we have been getting call after call every day from people asking us as to the differences between stage 1 and stage 2, so we started a separate mFlasher official thread to clarify the differences. But even that doesn't seem to help. Here is hopefully a better explanation:
1) Stage 1: This could be described as improved MPPSK tune. It's designed for basically stock hardware and has adaptive functions to slightly increase or decrease power based on current fuel/conditions. This is a safest type of tune for those customers that don't want to push limits of the hardware, but do want a bit more "oomph" from their car. 2) Stage2: This pushes the limits of the hardware much more then Stage 1 does. It has more timing, more boost, more laid request and such. We highly recommend going with better flowing intake/exhaust for this tune since we are starting to come close to limits. This tune still will adapt to conditions, but adaptations are slower. 3) Stage 3: Also know for now as stage 2+. This is where we really start to push limits of the hardware. We start running low on fuel pressure, EGts are hotter and such. Even more boost (now boost is fully limited by stock turbo as the turbo is working at 100%), more ignition and more advanced VANOS control. You need to understand something. BMW rates this engines at the numbers they post as that being a threshold of best reliability vs power. The more power you gain, the less reliability you get. By reliability we are talking about more extreme conditions inside combustion chamber resulting on more wear. Simply put, more power, more wear. For example, I run stage 3 on my personal cars all the time now. The cars are fully stock, and I know how the cars behave and when I should back off throttle if I feel some hesitation/knock/over spin of turbo. None of my stock hardware cars ever had a failure, driven on tracks, daily drive and what ever I have put them through. Now, you give a car like this to a kid that dumps some questionable Arco 91 and goes street racing. Beat that same car hard enough on the worst conditions, don't respond to the car's behavior and guess what, you will melt valves/bend rods and such. That is why we build tunes and have specific "recommendations" for the supporting mods. It is complete up to you as to what you want to do. If you want to run 87 and stage 3, you can as it's your choose. All we can do is give you specific calibration and recommendations to get the best safety/performance. ........... off topic example...... For computer geeks out there, think about overclocking. Take a 8086k for example and start overclocking it. You get to 5ghz relatively simply with 1.28/1.3 volts and that results in a very stable and safe overclocking. After that, each 100mhz takes more and more voltage until you get to 5.3ghz and you need over 1.5volt. Now you are running a risk of burning your CPU up or frying up your voltage regulators.....this is just an example of how all of this works but this way you can relate to tuning. |
01-21-2019, 07:15 PM | #28 |
Rep 181
For anyone hesitating on flashing their car with MP, I am here to tell you to absolutely get it done! My JB4 was rough and inconsistent even with meth. Now with Alex’s stage 2+ engine flash and stage 1 trans flash the car is buttery smooth and a lot faster! My car no longer cuts power when I shift; it just keeps going. FYI I’m running a cat-less downpipe, 91, and 2 gallons of e85. I disconnected the meth for now and will add it later on but so far I really don’t miss it.
I would also like to mention that forum member “chenry”’s car has the same flash and is stock except for a drop in air filter.... his car is like a rocket ship as well. We had the tunes done at the same time today and both left with huge smiles on our faces.
‘18 340i M Sport AW/Coral Red
KWv3/VM DP/SSR SP3/Dinan Midpipe/BMS Meth Kit/MP Stage 2+ & Stg 1 TCU 456whp/470wtq '15 335 M-Sport MGM (Totaled ) KWv3/JB4/IC/DP/CP 410whp/463wtq '06 Lexus IS350 BC/Work/AFE/Invidia/FSport/Wald Last edited by grassy_91; 01-21-2019 at 07:22 PM.. |
01-21-2019, 08:00 PM | #29 | |
Rep 1,219
01-21-2019, 10:40 PM | #30 | |
Rep 181
Edit: I believe you would have to purchase a separate meth controller that doesn’t rely on the JB4. As soon as we disconnected the JB4 everything was perfect.
KWv3/VM DP/SSR SP3/Dinan Midpipe/BMS Meth Kit/MP Stage 2+ & Stg 1 TCU 456whp/470wtq '15 335 M-Sport MGM (Totaled ) KWv3/JB4/IC/DP/CP 410whp/463wtq '06 Lexus IS350 BC/Work/AFE/Invidia/FSport/Wald |
01-22-2019, 07:21 AM | #31 | ||
Cheapskate
4447
Rep 4,993
01-22-2019, 09:09 AM | #32 | |||
Rep 676
The reason we offer tunes capable of providing stage 2+ power on fully stock platform is because unspeakable amount of reverse engineering and RND went into our product, and unlike product offered in the past by completion, everything we offer is adaptive and "smart". Software we developed can adjust to specific conditions and that is part of the reason we have so many options. It seems that there is actually only one person who just doesn't understand it in general, so here is a breakdown: -Want good power gains with stock hardware but don't want to stress the motor? Go with stage 1. -Want even more power with your stock hardware and don't mind stressing your motor a bit, then go with stage 2. -like stage 2 power and want to take away some of the stress on the motor, then add supporting hardware mods. - want to have the power that pushes limits of the stock hardware, then take stage 2+ It's really simple. |
David0ff1059.00 |
01-22-2019, 09:20 AM | #33 | |
Rep 2,964
And thanks again to Alex for stopping everything he was doing to spend 2+ hours with us (tunes take mins) talking cars and generally just hanging out at his new shop. All around a great experience for me |
01-22-2019, 10:13 AM | #34 | |
Cheapskate
4447
Rep 4,993
01-22-2019, 01:35 PM | #35 |
Rep 245
Kern,
I think you/we just need to be patient. There are so many variables that all the questions can't be answered definitively. Some customers are bleeding edge and just do it. Most of us want to see more comprehensive data and specs to make sure we are making the right tune choice. MP has the expertise in developing tunes and probably has limited time and resources to test and communicate everything to all their customers in clear statements. I also noticed the seeming contradiction in needing bolt on mods, but the tests being done on stock setups. It just means the limiting factors on performance and long term reliability are not fully understood yet. I appreaciate that approach, since it starts at one end of the mod spectrum (the end I happen to be on). If they came out and said their stage 2 did 4xx HP with full bolt on, those who didn't have all the mods would have no idea if the tune would work for them. MP is just saying if you want to be safe, here are the guidelines. As more people do the flashes we will start to see a more complete picture. Jump in and take some possible risk, or wait until more users have provided feedback. |
01-22-2019, 01:39 PM | #36 | |
Rep 888
01-22-2019, 02:20 PM | #37 |
Rep 703
I'm with the crowd. MP is providing a great product and but some don't get it but I dont see why. Two options really for stage 2 and beyond...either you run the tunes on a stock motor and risk the extra wear and tear or you get the necessary bolt-ons. I dont see what's so hard to understand.
2018 M3 ZCP "Edition Velocity"
2018 X3 30i (wife’s) 2017 340i w/ MPPSK & Many M Performance Parts (sold) 2016 328i (sold) |
01-22-2019, 03:13 PM | #38 |
Rep 1,369
01-22-2019, 05:36 PM | #39 | |
Rep 181
01-22-2019, 08:10 PM | #40 |
Rep 2,601
Drives: G81 M3 Touring, GR Supra GTS
I am a bit confused, I initially had the Stage 2 and I think I have 2+ now.
Has anyone else with a tune done any logging? Curious to compare boost, timing and AFR values. |
01-23-2019, 12:02 PM | #41 | |
Cheapskate
4447
Rep 4,993
01-23-2019, 06:05 PM | #43 |
Rep 474
mFlasher on windows
Looking for 335/n54
01-23-2019, 07:57 PM | #44 |
Rep 1,457
Sorry meant to say what cable do you guys purchase to connect to the mFlasher
2024 X3 M40i
2014 BMW M5 |
