10-31-2018, 10:58 AM | #353 | |
Not stock
474
Rep 617
So after panic ensued, I laid in bed and realized I could try my wifes phone. Installed Bimmercode on her Samsung S9. Went out. It reads the module. Great! Reported that to the developer. He said he needs to fix this issue but that I should uninstall and reinstall the app after copying my backups. So I did - all good now!
2015 BSM 328i Sport Line - BSM
2015 BSM X1 M Sport - BSM 1992 525i 1987 325e |
11-01-2018, 12:01 PM | #354 |
Rep 17
Veepeak BLE adapter
I bought veepeak BLE adapter but for some reason haven't been able to connect to bimmercode app on my iphone . I keep getting connection error. I reached out to the seller and he sent me another adapter but still cannot connect. Help please!
11-01-2018, 01:05 PM | #355 |
Rep 1,237
Drives: M2 Competition
100% sure you selected Veepeak in Bilmercode settings and have bluetooth on and connected?
11-01-2018, 01:25 PM | #356 |
Rep 17
11-02-2018, 02:53 PM | #357 |
Rep 1
Success!
Bought the Vgate Wifi iCar2 on Amazon for iOS for $19.99
Downloaded Bimmercode App and paid the $26.99 unlock fee in the app. Followed the Quick Start Guide in the App Settings menu. Practiced in Demo mode. Then connected for real and completed these code changes within a few minutes: Turned off initial warning after startup Changed startup graphic to "M" Changed warning sounds to "i" Auto unlock on ignition off Changed idrive to display tire pressure AND temperature No error codes stayed on and after I disconnected through the app and unplugged the Vgate I shut off the car completely, started the car and drove around the block to test a couple things. Success!!!! Thanks Bimmerpost and Bimmercode!! Next I will be doing the brightness on Angel Eyes, ASD off, open/close mirrors on unlock/lock, and shut off radio/nav on open door. |
11-13-2018, 12:06 AM | #358 |
Rep 14,115
Drives: G82 M4C X-Drive
Anyone know if you can code the default adaptive cruise following distance? It's in the SAS controller supposedly.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
11-15-2018, 04:21 PM | #359 |
Rep 6
jmg,
Their home page lists the various models and what can be coded for each. http://bimmercodeapp.com/index.php just scroll down For your F80 - yes For the i3 no adaptive CC listed |
11-15-2018, 06:36 PM | #360 | |
Rep 14,115
11-15-2018, 06:43 PM | #361 | |
Rep 2,036
In Expert Mode ......I have to really hunt and search.
11-21-2018, 12:41 AM | #362 |
Rep 61
I used Bimmercode on my 2014 F30 335.
Got rid of side markers, however it wiped out my Active Sound. from the app i don’t even have Active Sound, i can barely hear any exhaust note now even with my MPE. how can i code Active Sound back into the 2014 F30 335? |
11-21-2018, 10:09 AM | #363 |
Rep 169
Why is nobody talking about the fact that the ios version of bimmercode is able to code sport+ functionality while the Android version cannot??? Am I missing something?
11-21-2018, 06:04 PM | #365 |
Rep 18
Love the app! (combined with Veepeak BLE adapter). Coded the following in part thanks to the very awesome coding contributions to Bimmerpost:
1. rear fog lamps with easy switch plate mod 2. outer tail lamps on with daytime driving 3. media off with driver's door opening 4. close windows/sunroof + fold mirrors with key fob lock hold 5. door handle LEDs on with reverse 6. rear cam zoom 7. side cam speed limit change I'm still trying to get: 1. sports wagon tailgate close with fob or either switch 2. easy access driver's seat function 3. speech to text with Enhanced Bluetooth 4. weatherband channels (might be discontinued for head unit in 2019 models). App developer is responsive and helpful. Worth every penny in terms of ease of use and turning on/off great features that are hidden in some models. Wishlist for the developer: 1. Global Backup and Restore for when our ECUs are flashed at the service center 2. Park Distance Control adjustments to sensitive to distance (sometimes the PDC is too sensitive and I find plenty of extra room to park after it goes off. |
11-21-2018, 08:23 PM | #366 |
Rep 2,808
Drives: F33 430 and F39 M35i
My Veepeak tool came in so I bought the Bimmercode (iOS) app and coded the following:
Turned off seat belt reminders and alerts Auto Start Stop to remember last setting Open doors at ignition off Stop window lifter when opening door Fog lights disabled with high beam Door handle LEDs while in reverse Brake Force display to flashing Shut off radio/nav when driver door open Angel eyes to 100% Volume at startup to 60% Video in motion, codecs, usb Tire pressure to display temperature and pressure Legal disclaimers off This thing is awesome! That's it for now, I'll keep looking through the menus and try more stuff later. I totally forget to turn off active sound. I'll do it in the morning. I'll do the rear fog switch thing too. I did it in my E90 and loved it. I'll search for the code to do fog lights without having headlights on too. |
11-22-2018, 11:07 AM | #367 |
Rep 439
Is exhaust flap control possible with this app or must BimmerLink be purchased?
2022 BRG G80 xDrive
2005 SGM M3 |
11-26-2018, 01:35 AM | #369 |
Rep 6
Hi guys,
I would need some help, does anybody know if it is possible to code LED fog lights on my non fog LED lights F31 in bimmercode app IOS? And if so what do I need to code? Many thanks in advance. Last edited by Cebela; 11-26-2018 at 01:49 AM.. |
11-27-2018, 05:39 AM | #370 | |
Rep 308
2017 F31 328d xDrive
M Sport M Performance Last edited by Hypermile; 12-10-2018 at 11:11 AM.. |
11-27-2018, 03:39 PM | #371 |
Rep 14,115
On a side note, why don't more car brands have coding options? I've been looking for Subaru options and all I can find are code readers and hardware defeats, but no coding.
11-28-2018, 06:21 AM | #372 |
Rep 308
from my experience, Ford, VW Audi and BMW can all be coded. VW/Audi's ross-tech VCDS long coding helper is a very similar UI as bimmercode. You pretty much click or uncheck boxes of the options you want to code.
M Sport M Performance |
11-28-2018, 11:38 PM | #374 |
Rep 385
got office to show with messages and emails now. but i can't have it read it out loud or reply. Also when using voice command it says "this function isnt supported by the bluetooth device" android s7 if that matters. HELP
