BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > B58 Turbo Engine / Drivetrain / Exhaust Modifications > DMS remap 440i
Studio RSR
      08-14-2018, 02:50 AM   #1
Southern Jay
Southern Jay's Avatar
Drives: F36 440i MSport GC
I travelled down to DMS with a friend at the weekend to get our cars mapped, having seen some of the figures quoted I was optimistic for the results, I'd taken the Powerizer off the day before in preparation, I'd also filled up with Tesco memento fuel.
The run before the map showed 348 bhp, baring in mind the only mods that could effect this is the Remus cat back system and a Pipercross air filter. This was a higher figure than I'd expected. Once the map was applied the car was dyno'd a second time, the results were 415bhp and about 440 torque. What is interesting is my friends 340 dyno'd 444bhp.
The guys at DMS had expected the car to come in around the 430 mark and thought the lower number could be for a number of reasons
1, the air flow sensor might have oil on it from the Pipercross air filter, causing it to drop in power, I've now put the oem filter back on.
2, the fuel I'd filled up with the day before is full of additives, causing a drop in power, all the previous cars with higher numbers had apparently used shell v power.
3, the car has less than 8k miles on it, so is still loosening up
I'm no mechanic so have no idea if any of the above could be causing it, or is it simply that no 2 cars will produce the same figures and mine is at the lower end.
415 is still a respectable number so I'm happy, I'm planning a retest once I've ran some shell v power for a while. Just to see if fuel really makes any difference
Current mods: Mperformance rear spoiler, diffuser, side vinyls and front grille, non OEM carbon mirror caps, Remus cat back exhaust, Eibach springs, TPI spacers 15mm rear and 12mm front, Maxton side blades and v2 front splitter, Pipercross direct replacement air filter, Remus Powerizer.
Current:
F36 440i M Sport GC STORMTROOPER
Previous:
F30 320d M Sport Xdrive STORMTROOPER
chris-c900.50
RustyBitz1573.50
Beek707.00
      08-15-2018, 06:08 AM   #2
Southern Jay
Added pics
Current:
Previous:
      08-15-2018, 06:27 AM   #3
chris-c
Drives: F31 340i RWD
We need to check that sensor!
      08-18-2018, 01:30 PM   #4
YasM3
Drives: A BMW
So many things can affect dyno #s. I would not worry about it. Your car could have been pulling timing, the way the car is strapped on the dyno, tire pressure, type of tires, conditions when both cars were dynoed etc etc etc all will affect #s.
Next, @ 8k miles, the motor is not "loosening" up. It would have made the same power at 1k miles and it will make the same power at 20k miles.
      11-03-2018, 05:30 AM   #5
kriszty
kriszty's Avatar
329
Drives: B58 M240ix pureturbo800 dorch1
nice gains,
i read at the German BMW forums, that the Pipercross filter ws not that good, there was a worse air flow than the standaard air filter, anyone has more info about this ??
      11-04-2018, 09:23 PM   #6
Nugget
Nugget's Avatar
650
Drives: G81 M3 Touring, GR Supra GTS
2011 BMW 135i  [10.00]
Originally Posted by kriszty View Post
nice gains,
They sag and crumble as well.
