01-23-2016, 06:47 AM | #1 |
Rep 21
F30 LCI Led Lights Flash Speed?
Hi guys, i dont know which words to use flash,blink, selector etc.Anyway i cant do fast flash with my led lights compared to pre-lci xenons.Is it normal? Or i have a problem? When i ride night time other cars with xenons does flash soo faster than me.
01-23-2016, 09:37 AM | #2 |
@obriennathaniel_f30 on Instagram
515
Rep 1,063
Drives: 582whp/596wtq '13 335i
I've never used the LED lights before but that's weird, the xenons flash instantly because it's just a piece of metal that's controlled by a solenoid that drops out of the way therefore letting out all the light the bulb puts out.
CG Precision VS-1 Exhaust\DR-1 DownPipe | PS2 Turbo\Inlet | PDU PI w/Fuel-it platinum kit & E sensor | GFB DV+ Diverter Valve | BM3 w/AIC2-V|Tune CaryTheLabelGuy | Full E85 | ATM FMIC | ER Chargepipe Inlet/Outlet | AFE Intake | BC Coilovers | PSS 255/40-275/35 Velos Designwerks S3 two piece 19x9/19x10 | Osram Xenarc | LED retro | AWRON digital AC gauge| |
01-23-2016, 01:46 PM | #4 |
Rep 517
Highway Code says you shouldn't ever flash someone or wave them on. Let them make their own decision. It also means there can be no claim of liability against you in an accident ?
01-23-2016, 02:19 PM | #5 |
Rep 6,227
Drives: 2018 340i M Sport
Garage List 2018 BMW 340i M Sport [9.38]
2020 BMW M340i xDrive [10.00] 2018 BMW 340i M Sport [8.00] 2006 BMW 330i Sport [4.50] 2004 BMW 330i ZHP [7.25] 2000 BMW 328i [6.00] |
Are you referring to the "Flash to Pass" feature that you use on the highway/autobahn type road when you are approaching from behind?
www.bmwcca.org member #388003 - Use me as a referral & you could win a one day ///M Driving School!! ___________________________________________ |
01-24-2016, 03:54 AM | #6 | |
Rep 11
In Dubai - there are generally 6 driving lanes for one way with the fastest lane allowing upto 120kph legally. And there are random folks on the fastest lane driving at 80kph. It gets really frustrating knowing that there are 5 other lanes to chose from if you want to drive slower. For these sort of people a fast high beam light helps to get them off the fastest lane. |
01-24-2016, 09:21 AM | #7 |
Rep 21
02-01-2016, 01:53 AM | #9 |
Rep 106
I just tested with my F30 LCI and I noticed the difference. They don't fade, but there's a notable lag between pulling the stalk and actually the beams illuminating. I also see that the reflectors move up a bit
02-01-2016, 03:55 AM | #10 |
Rep 21
Yes thats what i mean.So this is normal.Better lighting lower speed.It fits me
02-02-2016, 04:35 PM | #11 |
Rep 106
10-27-2021, 04:30 PM | #12 |
Rep 2
For everyone who bump into this problem you need to make some coding with both Left and Right FLEs (43,44 addresses in E-Sys)
For High Beam: LmmIdx05_TimeOn = 00 LmmIdx05_TimeOFff = 00 And if you want you can change Low Beam not only flash-to-pass speed, but also usual turning on Low Beam LmmIdx02_TimeOn = 00 (standart 03) LmmIdx02_TimeOn = 00 (standart 03) Hope it will help someone because I spend an hour to find out this codings |
10-27-2021, 04:51 PM | #13 |
Rep 16,061
If this is the case it's not an LED property. Incandescent bulbs heat to produce light, so they have a slow response time. This is what allows the use of warm checks to test if the bulb works without visibly flashing. The duration of the warm check pulses is too short for halogens to heat sufficiently to produce light. LEDs don't heat and react much faster, so the pulses will cause LEDs to flash. This is one reason why the warm checks are coded off with LED replacement bulbs.
The above mentioned stock coding to reduce the response time of LCI LED appears to be used as part of the anti-glare system. |
