04-14-2016, 02:55 AM | #1 |
Rep 504
CDA904 error ?
anyone has got CDA904 error in DME (no message, DME receiver AHM transmitter) ? I dont have or ever had AHM (trailer), theres no any trailer option in the FA, everything is coded without AHM but error appears almost immediatly after deletion. I can disable dtc via ecu reflash but its a brutal and last option, first I want to find out if its possible to do it in right way via coding or diagnostics. Why DME is looking for AHM everytime? Is it bmw software bug or something? saw some other people across the net complaining about the same thing.
10-04-2016, 06:38 AM | #4 |
Rep 504
02-27-2017, 02:40 PM | #5 |
Rep 97
Drives: F30328i x 2 (yes, 2)
Does it involve reflashing ECU?
I only have Bavarian Technic not Reingold. Would it be possible to do so?
06-29-2017, 04:54 AM | #7 |
Rep 40
Could you say in detail how to deal this problem?
02-03-2018, 07:43 AM | #8 | |
Rep 808
04-25-2019, 11:01 PM | #9 |
Rep 1
I have a 2013 BMW 328i 3-series (F30)2.0 turbo with 25K starts up blowing white smoke, after a few mins/Warms up it stops smoking, runs great, drives amazing, seen that it was white smoke so I did a new head gasket, but its still doing it? can someone help me or has had this happen to them
10-27-2021, 04:22 AM | #11 |
Rep 5
BMW says erroneous fault
I have the same fault on my 2013 F30 328i
BMW says it is an erroneous fault that can be ignored check the attachment bullitin: https://static.nhtsa.gov/odi/tsbs/20...49299-9999.pdf Hope this helps |
Sushi Eater1.50 |
08-20-2023, 08:15 PM | #12 |
Rep 1,579
In order not to resurrect this old thread, will send you a PM for advice.
