11-20-2020, 11:52 AM | #1 |
Rep 56
2016 320i b48 broken piston - stage 1 bootmod3
Hi, while coming to a stop suddenly the car started shaking and an error came up on idrive "drivetrain malfunction".
Shaking while stationary Vehicle idles rough and hard acceleration. Any thoughts on what it could be? Last edited by Moaus; 12-02-2020 at 09:37 AM.. |
11-20-2020, 01:00 PM | #2 |
Rep 237
Drives: e90 335i, f30 330i
Could be lots of things, injectors, coils, spark plugs, ect. Sounds like there are misfires somewhere, but you'll need to connect a code reader and use an app to pull codes to get an idea of what it could be.
Or take it to an indy/dealership and have them diagnose it. |
11-26-2020, 05:38 AM | #6 |
Rep 56
So i went to 2 indy shops, both of them ran a compression test and cylinder 1 gives 130, other gives 175. Next step is to open the engine to see what's causing it. Btw, both of them told me it's because of the tune i have (bm3 stage 1). I'm starting to believe it's true... Any thoughts/similar issue to anyone?
11-30-2020, 02:18 PM | #7 | |
Rep 7,597
12-01-2020, 10:29 PM | #8 |
Rep 1
I have the same issue. Although it happens only at particular times
2016 BMW 328i
I also get the drivetrain malfunction, Although I only get it if I’m driving 70-80 mph for extended periods of time The car functions perfectly if I drive it between 60-70. I’ve had it diagnosed, bmw wanted to check the entire drivetrain and charge me 185 for it. Then someone else was telling me the fuel pump is going bad. Total bullshit. That happened more than a year ago, and it still purrs like a bmw kitten (when driving slow). I can speed up but. it becomes a problem when the drive is more than 45min-1hr |
12-02-2020, 10:24 AM | #13 |
Rep 183
These pictures look a lot like examples of Low speed pre ignition. What engine oil was your car running? Any datalogs of the car before the incident happened? I'm currently running the same tune and this accident has me thinking about moving to stock
12-02-2020, 10:33 AM | #14 |
Rep 183
Here's a link to a similar thread talking about how it happens
https://f30.bimmerpost.com/forums/sh...1682594&page=3 |
12-02-2020, 11:11 AM | #18 |
Rep 183
From what i could find on the internet, the B48 engine requires 5W-30 or 0W-20 oil. Oil could be one of the causes but it might be the low/mid end torque of the bootmod3 tune. Did you ever lug the engine when travelling in the city? Also, what is your current plan with this engine/car?
12-02-2020, 11:35 AM | #19 |
Rep 16,065
The internet is full of misinformation. 5W-40 is perfectly OK, especially in hot climates. The source for this information: BMW. The engine damage is probably the result of the BM3. You can only get so much out of any engine.
12-02-2020, 11:51 AM | #20 |
Rep 183
Yeah that may be true but isn't stage 1 ots quite a conservative tune. I get that stage 2 greatly enhances the risk of such failures but stage 1 shouldn't ideally
12-02-2020, 12:31 PM | #21 |
Rep 5,457
Drives: F30
Something no one has asked... what octane tune were you running? Most likely this happened because you were running a high octane tune (93) on garbage fuel. I've seen it before... if you look hard enough you will find examples on this forum of the exact same thing across different engines.
Bootmod3 OTS flash tunes are perfectly safe so long as you "follow the rules" and maintain the vehicle properly. Literally hundreds (more like thousands) of users of these tunes with a very very small issue/failure rate. Again, across different engines. Not specific to four or six cylinder motors. |
12-02-2020, 12:47 PM | #22 |
Rep 56
