10-11-2021, 01:37 PM | #23 |
Rep 125
Yeah I know it sounds crazy to run it on the track with these issues, but as I wrote earlier, I was ready to swap the stock tune back in, but I ran some logs and saw no timing corrections or spark knock and the fuel pressure dropped only 200 psi in the worst case.
IAT's on track were 140-150. Not sure why they were so high in those posted logs Hmm... Am I correct that as IAT's rise timing and boost are reduced? Normally I track a prepared ZO6, but the BMW had to fill in this time. |
10-11-2021, 01:49 PM | #24 | |
Rep 7,622
Anyways didn't mean to go off topic from the fuel pressure issue was just stating my recommendation for an IC, certainly if you are going to track. The DME is good at protecting the engine but tracking without a IC upgrade, especially when tuned, is crazy to me. |
10-11-2021, 02:55 PM | #26 | ||
1297
Rep 3,536
10-12-2021, 11:51 AM | #27 |
Rep 125
So when I add an upgraded IC won't that make the fuel pressure issues worse, since the colder, denser IA will require more fuel?
I'm likely going for an IC upgrade and considering my options for an upgraded HPFP, however, I don't want to add the FP and still have the same problems. Really would like to solve this problem short of throwing more parts at it. I'm not trying to chase big HP/TQ numbers, just looking to run a stage 2 map on pump CA 91 and completely happy to run the appropriate CA fuel map to do it. Surely I can't be the only N55 guy in CA having trouble with these maps on a nearly stock car. |
10-12-2021, 12:38 PM | #28 | |
1297
Rep 3,536
10-12-2021, 01:50 PM | #29 | |
Rep 7,622
2. Generally yes the approach of solving the problem first makes sense, but i wouldnt drive the car hard before the IC upgrade. 3. 100% agree with not chasing big numbers, but if you plan to drive the car on track you need supporting mods. If you are going BM3 stage 2 that would be at a minimum IC, CP, and DP. If you go upgraded HPFP you can run ethanol and the 2+ map. Actually, you the fueling issue you have is very rare. Maybe one other person had a similar issue i can recall in the past year and IIRC they needed a new HPFP. Not saying that is what you need, but your situation is an anomaly. |
10-12-2021, 07:47 PM | #30 |
Rep 125
I have a stepped IC on the way. Already have the CP and DP, and both fuel pumps, all injectors and pre cat O2 have been changed in the last 10K miles chasing this issue. I had two fuel injector failures back when I was running the JB4 so I'm considering the FI's as consumables like plugs and coils.
I'm okay with dropping $1100+ on an aftermarket FP if that will allow a stage 2 map safely on track. If I can blend in a bit of E85 that would be great as well. I'm leaning towards the Dorch Stage 1 FP. Any feedback on that choice is appreciated. I have no plans for a big turbo or anything else. Has anyone successfully used the HDP6 (Stock B58TU) on an N55? |
10-12-2021, 09:02 PM | #31 | |
Rep 7,622
Dorch is the most common option now and probably the one i would say go with if you are going to do it. There are a couple of threads on retrofitting the B58 pump. IIRC one version will bolt in, but you are not supposed to run it because it doesn't fit correctly on the lobe or something (i would have to look up exact reason). |
10-12-2021, 09:36 PM | #32 | |
Rep 125
Recall that immediately after I flash a new or previous map, the car runs great and doesn't crash the fuel pressure for 70-150 miles. I assume adaptions occur and that is the problem. With my latest BM3 map email: Halim @BM3 commented: Seems like it goes into some sort of open-loop where it just injects tons of fuel without correction. I set minimal AFR now on this dynomap, let’s see if it helps. |
10-12-2021, 09:58 PM | #33 | |
Rep 7,622
10-12-2021, 11:48 PM | #35 | |
Rep 7,622
Edit: Also i wonder if BM3 can jsut disable LTFTs in the tune? and see what happens |
10-13-2021, 12:13 PM | #36 |
Rep 125
I have the latest BM3 tune with just under 100 miles. I did a full scan of all 28 computers and found these codes. The ECU codes I assume are tuner codes and normal? However, this could account for the crazy LTFT's . I have no CEL.
I've too thought about trying another tuner just to confirm that it's not the car. I'm hesitant to drop the money on a fuel pump knowing that the car should not require that to run a stage 2 tune. |
10-13-2021, 12:19 PM | #37 |
Rep 7,622
Air mass is a "tuner code" but i don't know what ZGM one is. If you never plan to mod the car enough to run a upgraded HPFP, maybe MHD is worth testing... worst case you can resell your BM3 to recoup most the cost? Just a thought
10-13-2021, 12:26 PM | #38 |
Rep 125
I just shared those codes with BM3. We'll see if they have anything to add. I have considered what you suggest, getting the MHD tune to test, but if I end up at the same place I'll be back to looking at aftermarket HPFPs
Somehow I was expecting an easy solution...LOL |
10-13-2021, 12:34 PM | #39 | |
Rep 7,622
Two other things that come to mind are the MAF and primary O2. I believe both are used to derive LTFTs that are learned over time. So i wonder if your MAF or primary O2 are reading incorrectly contributing to such high LTFTs. Have you tried driving without the MAF plugged in to see if the problem still happens? |
10-13-2021, 12:48 PM | #40 |
Rep 125
Yeah just increasing the headroom in the fuel system is not going to address the AFR's going into the 10's , which is likely a programming issue and adding all the fuel when it's really not required will be another problem. Right now the fuel system can't deliver the requested fuel so the problem isn't what it could be if I upgrade the HPFP?
I have not tried running without the MAF. I did replace the primary O2 after replacing both pumps and all the injectors, so that is a new one. I'm going to put some more miles on this new tune and send BM3 the logs as well as post them here. Right now this tune seems to be holding fuel pressure above 2000 psi, however, the max boost I'm seeing is only 14 or 15 PSI, which is disappointing. After that, I will install the stage 2 ACN tune and try running it with the MAF disconnected. Thanks for the suggestion. |
10-14-2021, 04:29 PM | #41 |
Rep 779
I have a theory that BM3 is overdriving the HPFP regulator driver in the DME, and rather than smoking the circuit, the ECM goes into a safety mode by cutting down the command to the HPFP. Unfortunately the location of the HPFP makes it difficult to put an amp clamp on the wires to see if the actual command signal falls back, while the command in the datalog is still calling for 2400psi.
10-14-2021, 04:56 PM | #42 | |
Rep 7,622
It seems like you are saying the DME might be telling the HPFP to supply less even if the log says the target is still say 2400. But if that were true in his case, he wouldnt have the fuel trim issue and the super rich AFR that corresponds with the pressure drop. |
n55david1297.00 |
10-15-2021, 09:46 AM | #43 |
Rep 643
fuel crash after gear shifts, which is when the STFT is not actively pulling back fuel (you can see STFT=1 for a few hundred RPM after each shift).
seems to me your fuel system is supplying more fuel than anticipated and relies on STFT to pull back approximately 15% fuel (STFT=.85). maybe this can be fixed by simple adjustment to fuel scalar or recalibrate injector. has ptf offered any help? **just saw that halim did something with AFR to help... but i don't see how that can help. regardless of what the AFR target is set to, your fuel system is going to supply approx 15% more fuel than needed. the big question is why is your fuel system pushing more fuel than the normal, and the bandaid fix is to adjust fuel scalars.. my 2c
M235i rwd 6mt
10-15-2021, 11:42 AM | #44 | |
Rep 7,622
So his STFTs are basically fighting LTFTs, and car is rich when STFTs are not active. |
bootmod3, n55 fuel pressure crashing |
