10-25-2021, 02:07 AM | #1 |
Rep 26
Tow Bar Westfalia
Hello,
I need help, I buy Westphalia tow bar to My F31 from 2013. I'll buy tow bar and dedicated wiring ( 303 460 300 113) for BMW Did someone, what i need to code for this wiring. When i mount it works, but PDC not disassembly when i attach the trailer. I don't have button on dash to disable PDC I find on forum to add FA 3AC and code FEM, ICMQL, REM, DSC, HU and Kombi. I'll make it. PDC now working correctly. When i attach the trailer PDC deactivates i have see tow icon on screen. Now there is a mistake as in the photos, regardless of whether the trailer is attached or not When I read faults codes ISTA show error with AHM module. I don't have AHM module i only have module from westfalia. HELP what I need to code. |
10-25-2021, 02:44 AM | #2 |
Rep 2,302
10-25-2021, 03:08 AM | #3 | |
Rep 26
They write about coding the original hooks. I'll buy Westfalia after market hook it's not OEM BMW hook, and module is from westfaliia not from BMW. I call to Westfalia They said their module only sends information on the CAN to car aobut light but nothing else. Original BMW when trailer is attached changes parameters of engine, transmission and DCS system. |
10-25-2021, 03:45 AM | #4 | |
Rep 2,302
10-25-2021, 03:56 AM | #5 |
Rep 26
10-25-2021, 04:01 AM | #6 | |
Rep 2,302
So you could try the K235 instead of 3AC. The K235 has some other codings. Maybe this will deactivate the error message. |
10-25-2021, 04:17 AM | #8 |
Rep 2,302
10-31-2021, 07:34 AM | #9 | |
Rep 26
I decided to delete K235 ,code all modules in car like as a factory To deactivate PDC sensor all that I have to do , I must use Bimeercode and code PDC deactivation during trailer operation PDC now deactivate And when I take out the bulb in trailer, there is information that it does not work on kombi Unfortunately, there was a bigger problem , 1. I got a permanent CF2501 error against the EGS for 'no message' from 'transmitter AHM', and this even persisted and still couldn't be cleared after I had removed the Westfalia module and wiring 2. When westfalia module is connected the automatic transmission not working well. When I stop after about 10 seconds, I feel a jerk, as if the gearbox was changing gear. When I disconnect the westaflia trailer module nothing happens, transmision works fine Help me ..... When I |
