11-12-2020, 04:49 AM | #1 |
Rep 155
LSD or wider/better fires
335i m sport, all stock, daily driver. Mp4s tires. About 3-4 track days/year.
Came factory with 225 front and 255 rear, but previous owner changed to 225 squared. I'm about to pull trigger on some new apex 9" wheels with 245 squared. My goal is better turn in and most importantly less interference of nanny's in sport plus mode coming out of a corner and therefore a better lap time. Im leaning towards wider rubber over a LSD because that would be much lower cost and will be very easy to sell them and recoup some cost when I sell this car in a couple years. (Money aside, I'd get both, but I just don't want to drop that type of money because I won't keep long term). What would you do? |
11-12-2020, 08:47 PM | #2 |
Rep 1,934
Lsd.
11-13-2020, 01:50 AM | #4 | |
Rep 155
Edit for extra info: Also, to my knowledge, a tire performs better when a tire has a slight stretch so there isn't as much rollover. (I could absolutely be wrong) |
11-13-2020, 10:52 PM | #5 |
Rep 943
Drives: F30 328i Msport
LSD
11-25-2020, 08:46 AM | #6 |
Rep 1,127
I would just forget about resale in the equation. I would get a second set of wheels/rubber for the track only. I would also get the front camber sorted to extend tire life.
I think LSD (assuming mperf lsd) vs Wheels tires will work out to about the same price. I ball park a set of Apex wheels with rubber in the 2k range and theMperf LSD is about the same price as well |
Aldor2787.00 |
11-26-2020, 04:32 AM | #7 |
Rep 210
Both I would start with the stickiest and widest tires you can fit (start w/200tw). Tires are our connection to the pavement and how the car communicates with you in hard cornering, always start w/tires and brakes.
Brotherhef43.00 Pinkykillaz22.50 |
12-05-2020, 11:16 AM | #8 |
Rep 891
One doesn't really replace the other. If you are going to invest $3000 in an LSD you should be ready to invest the money in a capable set of shoes to get the most out of it.
If you plan on selling the car just keep in mind that the LSD will not net you nearly the % in resale a set of wheels would. Also note that you can't really buy the MPerf LSD anymore so your only options are WaveTrac or Quaife. Both of these require you to send in your pumpkin for splitting the ring gear and installing the LSD. The turnaround time for this service is 3-4 weeks. I have gotten quotes on both applications through different partner shops, all were $3-3300.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
Brotherhef43.00 jbiswurm68.00 |
12-05-2020, 01:15 PM | #9 |
Rep 210
Post in the F3X Facebook group somebody name Tony Asam is selling one.
2014 335i M Sport: bootmod3 Stg 2 E30 Custom, AA CP, CSF FMIC, GFB DV , VRSF catless DP, aFe stage 2 intake, KW Clubsport coilovers, MP LSD, aFe sway bars, F80 LCAs, monoball thrust arms, Delrin rear subframe bushings, xHP Stage 3.
IG: German_car_connection |
Brotherhef43.00 |
12-05-2020, 01:53 PM | #10 |
Rep 1,597
LSD is nice but tires are the more important track factor.
Brotherhef43.00 |
12-09-2020, 04:14 AM | #12 |
Rep 14,107
Drives: G82 M4C X-Drive
There is no point in getting the LSD if you aren't going to get the tires. However, you can get the tires and still see significant gains without the LSD, so get the tires first. Then the LSD.
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
MacklinUSOB518.00 |
12-19-2020, 10:15 AM | #13 | |
Rep 320
you're partly right about rollover...depends on the sidewall characteristics of the tire. stretch matters alot less with a stiff sidewall (i.e. RE71R) than with a soft sidewall (i.e. Continental DW) so there are few factors to look at. |
Brotherhef43.00 |
12-21-2020, 05:41 PM | #14 |
Rep 155
01-27-2021, 12:02 AM | #15 |
Rep 1,363
Question on 245s. I have a set of OZ Ultraleggera that are 17x8 I'd like to use for occasional track days. According to the tire maker (I use Bridgestone RE-71Rs), they say a 245 can be mounted on a 17x8 but I'm a little wary of that combo. Anyone have any experience with a 245 on an 8-inch wheel.
01-27-2021, 12:10 AM | #16 | |
Rep 1,363
Without an LSD, you head into a turn, slowing at first and then as you close in on the apex you start to apply throttle . . . only to find it's a lot less enthusiastic than it was before you got to the turn. It seems to be doing little. Add on the LSD and the moment you touch the throttle in a turn, you immediately understand why anyone with an LSD can't stop praising it. Without a single engine mod, your car all of sudden finds power in a turn. |
Brotherhef43.00 |
01-28-2021, 01:39 AM | #17 | |
Rep 4,314
for a 245/45/17, tirerack has the rim width range at 7.5"9" so a 17x8 will be fine. |
johnung4525.00 |
01-31-2021, 06:15 PM | #18 |
Rep 280
Drives: 2016 EB 340i
Only the rears can clear 17s with M sport brakes, and that is some wheel manufacturers, not all.
01-31-2021, 06:37 PM | #19 | |
Rep 241
For example, the power you get to the outside wheel in a turn makes the car rotate so much more naturally and meaningfully. That said, if you really have to pick, pick tires because of the enhancement tires provide to both the front and rear of the car. |
MacklinUSOB518.00 LRaev0.00 |
02-07-2021, 02:18 PM | #20 | |
Rep 320
02-08-2021, 02:44 PM | #21 | |
Rep 1,363
Wow, 25 events on the RE-71R. You're my hero. I ran the fronts into slicks over 7 days at Mosport. It's like the front tire became one large wearbar. |
02-13-2021, 11:32 AM | #22 | |
Rep 320
I've got two sets of 18x9.5 RF03RR superspeed wheels, one set is et38 and the other is et35. they are a bit lighter than the FASTs and very robust. FAST is still a very good wheel though and you certainly will not be disappointed. FAST has the 18x10 i like which would allow for rubber so I am trying to see how i can make that work. |
