BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY Vibration Damper / Harmonic Balancer
      08-22-2015, 07:35 PM   #1
xxxjecxxx
xxxjecxxx's Avatar
Drives: F30 335i M sport
2013 BMW 335i  [0.00]
2006 BMW 325i  [0.00]
This is a tutorial and some general information on how to identify and replace a damaged vibration damper (BMW language) otherwise known as a harmonic balancer.
In this "before" video, you will see the vibration damper (VB) wobble and create an unpleasant sound.
I replaced part #1 in the attached diagram. It's function is to balance all of the internal components of the engine during operation. I will warn you that this part is on the expensive side. $487 directly from BMW with a discount.
YOU DO NOT LOOSEN #3. If you do so, your engine will be out of timing.I should note that my radiator and fan are already removed so it made this a lot easier. In your case, I would recommend only removing the fan but you must be very careful not to let your tools slip as you can puncture the radiator.
Use a T60 socket to disengage the tensioner and remove the belt. Turn to the left.
Use 8mm socket to remove the 8 screws holding the pulley on.
Once all screws are off you can just pull the pulley off the motor. This is what my old one looked like.
New one
Reserve the process for installation.
Torque to 25 ft lb Again, be careful not to allow your tools to slip.
Install the belt. It's a very tight fit. Here is how I did it.
Once I got to this point, I used a socket to crank the engine manually and allow the belt to "fall into place".
This is what it should look like when it's complete. Notice that the wobble is gone and so is the noise.
There is not much information about these on the internet. Please like this post if you enjoyed the tutorial.
      08-24-2015, 12:10 AM   #2
Piggieback
Drives: 2014 Cayman S, 2015 A3
Solid DIY, is your car out of warranty?
      08-24-2015, 03:37 AM   #3
greekcs
greekcs's Avatar
Drives: 2020 M340i xDrive
you forgot to VO code the car.
2003 11/02 Steel Gray Metallic on Red M3 - SMGII - VF570 - SUPERSPRINT - KW - BBS - CSL ROOF SOLD
2015 09/14 Alpine White on Red 435i xDrive MPPK - Expensive black vinyl with special lettering. SOLD
2020 12/19 Mineral Gray Metallic on Black Vinyl interior M340i xDrive
      08-24-2015, 06:42 AM   #4
xxxjecxxx
xxxjecxxx's Avatar
Yes sir! I think i'm one of the very few running around here without a warranty. Nobody will appreciate this until a few years from now
Thank you!
You know there is never enough coding
      08-25-2015, 09:10 AM   #5
jelecroy
Drives: 2013 328i, 2014 328i
2013 BMW 328i  [0.00]
I'm pretty sure that although loosening the crank bolt (3) is a bad idea, it should not cause the valve train to loose timing. Part numbers 2 and 5 both are likely to have keys to position them, so that they will not spin on the crank. It is funny that keys are not shown on the BMW service pictures, though.
      05-09-2016, 03:13 AM   #6
Welcome to NBA Jam
Is it the shoes!?
Welcome to NBA Jam's Avatar
3884
Drives: (Sold) 2011 E92 335i ZMP 6MT
Thank you!
I've got an N55 E92, and I appreciate this now! I noticed an ever so slight wobble in mine. It doednt make any noise, but it's very great to know that BMW made the damper very easy to remove. I was expecting to have to get a massive cheater bar.
      02-05-2018, 11:34 AM   #7
Street of Rage
Street of Rage's Avatar
Drives: 2011 BMW 335i e92
Much appreciation on this post. My e92 N55 vibration damper started screaming yesterday (none today), and I checked this morning, it started to wobble, but I'm going to get that checked and fixed ASAP.
Thanks again.
      08-10-2018, 08:54 PM   #8
Solidjake
¯\_(ツ)_/¯
Solidjake's Avatar
Poland
945
Drives: '13 328i Msport 6MT
I have some slight play on my N20 engine.... I might buy the balancer and make a vid for the install. It's crazy how that pulley starts the fail. It shouldn't...
Apex SM-10/DWS06+ | 400m/X-ice Xi3 | Injen Exhaust | Stoptech SS Lines | 335 Front Brakes
Hawk HPS 5.0 | RBF600 | ER Charge Pipes | Wagner Evo Comp 2 FMIC
      08-15-2018, 03:57 PM   #9
Street of Rage
Thanks again.
Just an update, after swapping it out back in Feb., it has been running smooth and noise free. It's an expensive part but have a friend to help you. Shouldn't take that long.
      10-07-2018, 04:44 PM   #10
jc68
Drives: E92 M3 ZCP, F15 X5, 991.2 GT3
I can’t see the pics, any chance they can be reloaded? I’ve got the same issue on my F15 X5 and will like to diy. Thanks!
      10-07-2018, 08:00 PM   #11
Street of Rage
Just search for serpentine belt / belt tensioner DIY.
      05-05-2023, 04:08 PM   #12
bnitka
Amateur DIYer
Drives: BMW F30 335i
Wow this is super helpful. Thanks.
Is there any risk of accidentally moving the crank when you break loose / torque on the bolts for this part? How did you avoid moving it if so?
This is a tiny step above any DIY I've done so any advice or detailed tips are appreciated. Kinda worried I'm gonna screw up by moving the crank somehow. Love learning from my own mistakes but not if it can throw off the timing of my engine :3
      05-06-2023, 01:40 PM   #13
Revoltos
Revoltos's Avatar
53
Dont touch the main bolt (number 3). Number 2 and 5 arnt keyed and rely on a compression fit created by the torque applied to bolt 3.
Bolt 4 (6 off) are what you need to remove. You wont do any damage to the crank whilst trying to undo those bolts. The engine my rotate slightly but once a cyclinder is on compression stroke the force required to undo bolt 4 will be less than the force required to turn the engine over.
      06-21-2023, 07:28 PM   #14
ClampThurst
Drives: 2018 M4-Silverstone, 2017 X3
Wait, there is coding involved in this repair?
