02-09-2016, 09:14 PM | #1 |
Rep 1,418
Amperage of USB Port in Center Console?
I've been using the USB port in my center console to charge my iPhone and it got me thinking of what the current/power to the port might be.
Is it .5, 1.0, or 2.1 amps? As you know, it makes a significant difference of how fast your devices might charge but I haven't really had my car that long to notice. I know I can just use a 2.1 amp adapter in the cigarette lighter port but I like that I can somewhat hide the cable a bit more in the center console. |
02-09-2016, 09:23 PM | #2 |
Rep 1,733
My gut feeling is that it's low. I haven't seen anything official on what the headunit puts out. Some say it follows USB 2.0 spec. All I know is that mine acts up when I use a device that draws a lot of current...like my iPod Classic when the battery is less than 100%.
02-09-2016, 09:35 PM | #3 | |
Rep 1,418
02-09-2016, 10:52 PM | #5 |
2JZ-GTE
3005
Rep 3,986
I would guess 500ma
02-09-2016, 11:18 PM | #6 |
Rep 1,476
Drives: 2022 G01 X3 M40i (Black/Black)
I believe you guys are incorrect. I don't know the exact amperage, but it's on the high side. It charges my phone like it's plugged into a wall outlet...extremely fast. It will also change my iPad Air, which requires high amperage (example: my wife's Volvo will NOT charge the iPad).
I've been VERY impressed with the USB charging capability.
2022 G01 X3 M40i (Black Sapphire/Black), HK, DAP, PAP, Shadow Line
2014 F30 335i (EB) 6MT, M Sport, Premium, Tech, DHP, HK, CW, M Brakes, M Exhaust 2006 E90 330i (Silver) 6MT, Sport |
02-09-2016, 11:31 PM | #7 | |
Rep 1,418
That's interesting. I believe the small cube adapter that comes with the iPhone is 1.0 amp/5 watts and the larger adapter that comes with the iPad is 2.1 amps/12 watts. Anybody have a USB power meter they can use to check? |
02-09-2016, 11:39 PM | #8 |
Member
457
Rep 1,517
It's for sure under 1 amp. Since they introduced the USB ports in cars, they are always extremely slow and struggle to keep anything charged.
Assuming BMW still uses usb 2.0 (can't see why they would use 3.0), it's capped at .5 amps. My iPhone 6s Plus charged at the same rate on my PC usb 2.0 as it does in BMW. Make sure you get a car charger that supports 2.1 amps! I believe iPhone 6 and later can charge at the full 2.1, I know for a fact the plus can.
Previous: 2013 135i Space Grey w/Coral Red | 6 Speed MT | M Pkg | JB4 | AA Downpipes | AA Exhaust |
Previous: 2015 M3, BSM[/SO/CF | DCT | Adaptive M | 19" Black | CF Roof | Previous: 2018 M2, AW | DCT | Exec Pkg Current 2020 X7 50i |
02-10-2016, 12:10 AM | #9 | |
Rep 1,418
02-10-2016, 03:06 AM | #10 |
Schmollbraten
12509
Rep 1,985
Anyone knows why the manual says explicit not to charge any cellphones on the USB outlet?
Citizen of ///M - Town, where too much is just right Some say, that my scrotum has its own small gravity field and when Im slowing down that brake lights come on at my buttox |
02-10-2016, 06:06 AM | #11 |
Rep 1,127
02-10-2016, 06:16 AM | #12 | |
Rep 3,940
If it's connected in terms of data, then yes, it's likely to be capped at 500mA. I suspect this is the real issue. |
02-10-2016, 06:49 AM | #13 | ||
Member
457
Rep 1,517
It's so slow that I had the phone lose battery even while charging.
02-10-2016, 07:26 AM | #14 |
Rep 10
I have an iphone 6 and i use waze everywhere i go. My commute is 30 minutes long and in that time my phone, plugged to the center console usb and running waze with the screen on, goes usually from 70% charge to around 95ish by the time i get home from work.
02-10-2016, 07:56 AM | #15 |
Rep 1,418
02-10-2016, 10:14 AM | #16 |
Rep 43
I experience the same thing plugged into the center console using Waze with the screen power on for about 30 minutes. It has to be more powerful than .5 amps for that to happen.
02-10-2016, 10:41 AM | #18 | |
Member
457
Rep 1,517
I still believe its closer to .5 as tested in the X5. I didn't use any meters, just how much it charged my battery on a 20 minute drive. It could also be a possibly that the percentage of battery life isn't very accurate on the phones but who knows. I still would recommend a 2.1 amp car charger and then you'll really start to see how slow the USB really is. I've done a side by side on a long road trip.
02-10-2016, 10:54 AM | #19 |
Schmollbraten
12509
Rep 1,985
Good point
02-10-2016, 12:35 PM | #20 |
Rep 121
Not sure of the exact amperage, however I've found that the center console USB is unable to charge-from-dead an iPhone 6. Every time my phone dies, I have been unable to re-charge from the center console...always have to end up busting out a usb adapter to the socket under the glovebox. That being said, I've always found the iPhone to charge relatively quickly when in normal use.
B58 parts472.50 |
02-10-2016, 02:02 PM | #21 |
Rep 1,476
B58 parts472.50 |
