BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > 10.25" Android 9.0 HU discussion
      01-19-2020, 10:44 AM   #2201
Kostisuk
Drives: Bmw e64
Originally Posted by seaman5705 View Post
Just try - for many has a good result , me included . BMW Aux uses a filtering which worsens the sound quality in our scenario . It does not match the sound output of Android HU. Disconnecting this will make sound more clear .
Thank you. I will try it. Any idea how to do it in a bmw e63 or should i go to the proffesional installer. My car doesnt have the combox bit it is worth a try if it will improve sound quality which is my main dislike about unit.
Originally Posted by mattmanslim View Post
Change the aux input volume level on the BMW OEM side and make sure that the audio level on the Android side is set to around 24.
The sound quality is poor when the aux input is overloaded. Reduce input sensitivity and android output level. Simple as that.
I will definetely try it. Edit: i tried it beacuse i had output at 40 but sadly I didnt see much difference.
Originally Posted by Mirjam View Post
If you have combox, expect huge improvements in sound quality. Read discussion here: https://f30.bimmerpost.com/forums/sh...6#post25311576
I dont have combox that is why i thought it wouldnt make difference
      01-19-2020, 11:06 AM   #2202
koutsouk
Greece
31
Drives: BMW E60
Originally Posted by RedErik View Post
I did try to trace these lines but just can't see where they're going, sorry. As for harness itself... it is all tucked away and wrapped in cloth tape. I'm sorry but this is major pain in the backside for me to check now. I will be wiring up a reverse camera in the near future so maybe then I will be able to check. For now, I just spent to much time trying to neatly put this all together.
PA_MONITOR_ACTIVE is not an option in CAS2.C05 at all so I couldn't try it out. Maybe someone with newer version of CAS can check that. Also pressing volume/power knob on CCC when key is not present, doesn't do anything in my case - no screen, no sound, nothing.
Probably because you do not have MPM module !
      01-19-2020, 11:24 AM   #2203
elnino72
Drives: Bmw E92 320I
I experience tremendous boosted bass and some treble after this 3.8.3 upgrade, had to turn bass down to half to to get the same as before. Anyone else have this?
What version were you from? yours and a snapdragon? I have had a sound improvement from 3.3 to 3.8
      01-19-2020, 11:32 AM   #2204
RedErik
RedErik's Avatar
Scotland
1024
Drives: E63 645Ci
2004 E63 645Ci  [0.00]
And what exactly this micro power module dose? It's in the boot right?
Edit: ok, I quickly checked with TIS so now I know. But I think I do have it... anyway how does this help in this case?
      01-19-2020, 11:52 AM   #2205
gsnake
Drives: X5 2012
or better yet just remove the two little capacitors from the little board that is inside AUX as I did.
      01-19-2020, 02:09 PM   #2206
koutsouk
Greece
31
Drives: BMW E60
CCC or M-ASK has always power upon unlock that for the CID and CCC powers up without ignition on.
The question is why our screen does not power on.
I am sure it is MCU and CAN related.
      01-19-2020, 02:48 PM   #2207
RedErik
RedErik's Avatar
Scotland
1024
Drives: E63 645Ci
Yes, we can try to pressure Chinese to implement change of behaviour for power up and down procedure, but I doubt we will see this any time soon.
      01-19-2020, 03:38 PM   #2208
Cskelton
Drives: F30 320i
Hi guys first post. Got a Snapdragon screen at the start of the week. initially I was a bit disappointed but then flashed the newest firm and that made a significant difference. (Thanks kri). However today while on my first drive longer than an hour I noticed my screen starts to flicker. Has anyone experienced this before?
      01-20-2020, 02:13 AM   #2209
DarkIrata
DarkIrata's Avatar
Drives: BMW 320i (F31), 2015
Doesn't sound right. Check the connetions. If it still happens, contact the vendor.
Sup everyone. Long ago since my last post. Went throug a few pages but it is to much to be up2date.
Could someone link me the newest working combination of Main, MCU and Factory_XML [Snapdragon - CIC HIGH]? I am still on Version 2.something
And are there some "must haves" or "must dones"?
      01-20-2020, 03:40 AM   #2210
jcompton9
Drives: BMW 320D SPORT (F30)
I'm looking to get a 10.25 Android 9 unit in the near future - I have a 2012 F30, which is CIC. It has NAV and the combox (not sure if that makes a difference). I recently watched a video on YouTube of somebody replacing the CIC screen with an Android one, and it had a horrible stretched regular CIC screen. I know there's retrofits to update CIC to NBT, is there any way I can do this alongside the Android HU upgrade? The fact that it may be stretched/still be low res is putting me off the upgrade a little, as it'll completely ruin the OEM aspect of the upgrade. Cheers.
      01-20-2020, 04:13 AM   #2211
RedErik
RedErik's Avatar
Scotland
1024
Drives: E63 645Ci
You need to code CIC to use bigger screen. Basically you have to tell CIC that it is using an 8.8" screen instead of 6.5".
      01-20-2020, 04:21 AM   #2212
novoiperkele
Drives: BMW E46, F30
Originally Posted by lehtee View Post
Feel free to ask anything!
What is wrong with LTE? Mine seems to work fine in Finland.
Have you found any proper launcher since your review? Also, how do you select the Cars computer in these?
      01-20-2020, 05:16 AM   #2213
Victor8490
Drives: F21
I have the same problem, what is that code?
      01-20-2020, 05:42 AM   #2214
rewesun
Drives: E70 X5
Change Bootanimation
Hello,
I want to change the boot animation Android 9.0 10,25 Zoll Snapdragon, how does that work?
Thanks
      01-20-2020, 05:54 AM   #2215
RedErik
RedErik's Avatar
Scotland
1024
Drives: E63 645Ci
It's not a code. You have to code/program in different setting for CIC via OBD diagnostic/coding tool. That means you need a laptop, OBD cable, software package and knowledge on how to use it. If you've never done that before find some locally to you how can do it... or start reading bmw coding . com
There is also Carly for BMW (app and OBD bluetooth adapter) that allows you to code you car. But I don't have any experience with it.
      01-20-2020, 06:27 AM   #2216
Cskelton
Drives: F30 320i
I managed to get a short video of the issue.
      01-20-2020, 06:31 AM   #2217
husskad
husskad's Avatar
Drives: bmw x5 M50D
https://mega.nz/#F!kbYFBS5C!gE-QFJoU...PxiJA!kKgH2Q4Z
      01-20-2020, 07:20 AM   #2218
DarkIrata
DarkIrata's Avatar
Originally Posted by husskad View Post
Thank you!
Two things.
• Which MCU files i would need to use? GS_20191027\snapdragon_CIC_mcu.rar?
• Do i have to make a factory reset as by the included pdf?
      01-20-2020, 07:52 AM   #2219
Kri
Austria
1084
Drives: E87
Thank you!
Two things.
welcome back
When you do come from from 2.x version, probably the best is to do a recovery factory/reset installation (1st page link), as alot changes/updates have come out since then.
Latest Software is 3.8.3
latest MCU is the November MCU GS_20191127, but folder is named GS_20191129 so don`t wonder about that mistake.
You can either use the V3.66 factory config, or the translated one from 1st Page link with some more gui`s activated.
Originally Posted by rewesun View Post
Hello,
Thanks
Just put your bootanimation.zip (made like for every other Android system) into your thumbdrives OEM folder and wait some time, it will be imported automatically.
Kri
      01-20-2020, 08:54 AM   #2220
Victor8490
Drives: F21
If I do it by bimmercode but I have not found what code I have to activate.
In display_variant I have activated breites but I do not have display_size_resolution in my cic to put 10.25_1280x480.
Do you know how I could put it?
      01-20-2020, 09:31 AM   #2221
Kri
Austria
1084
Drives: E87
I just noticed another new feature (probably) of 3.8.3 by coincidence
AUX does "Stay" at AUX when switching to OEM GUI (except pressing Radio Button) when Manual AUX Switching is selected at Settings !
They did the trick when AUX is selected and you switch to OEM GUI then they do an additional "switch back to AUX" , this is noticed because sound is off for a very short time and does come back from the Android unit.
Kri
      01-20-2020, 10:02 AM   #2222
RedErik
RedErik's Avatar
Scotland
1024
Drives: E63 645Ci
What is your setup? CIC with nav or without? You need to have HU_ENTRYNAV in your car in order to "upgrade" to 8.8" screen. If you have HU_CHAMP2 it will not accept coding for 8.8".
