BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > After how many miles/years should you get rid of a Bimmer?
VIBE Motorsports
      05-31-2018, 09:31 PM   #89
OUGrad05
Drives: 2013 FR-S, 2015 335i M Sport
Originally Posted by chiefneil View Post
Can’t say I disagree. IIRC the E46 radiator had some plastic parts, and those would break, forcing you to replace the whole thing. The heat in AZ was probably a factor - plastic and rubber just gets killed out here in summer; it might’ve contributed to my fuel and water pump failures as well.
Yup and plastic impellers on water pumps so that you sent plastic bits through your cooling system when it fails? Just dumb shit...
2015 335i M-Sport
2014 X3 XDrive 28i M-Sport
2013 FR-S
      06-01-2018, 10:17 AM   #90
whosagrubb
whosagrubb's Avatar
Drives: '15 F36 435i / '07 E90 328i
Originally Posted by GunGuy View Post
In my view, once the car gets to 130k, there is a reliability issue.
Now, if I was 20 years old again, and money was a huge issue, 230k is still in the realm of possibility.
Ha! That's exactly the logic behind my moving on from my 328. It was approaching 130k, had a random starting issue over Thanksgiving which went away when the tow truck came to take it to the shop, but otherwise is bullet proof. I do a lot of long distance driving and just figured maybe it was time to buy something newer "just incase".
I kept it though and it's going to be my daughter's first car. It's perfectly reliable for a kid who's being gifted a car.
      06-01-2018, 10:31 AM   #91
chiefneil
Drives: 2014 335i M-Sport
If the engine was hot when it failed to start, it might’ve been the fuel pump. Sometimes when they’re getting flaky they crap out when hot but then work ok once cooled off.
      06-01-2018, 10:42 AM   #92
whosagrubb
whosagrubb's Avatar
Cold start. Had been sitting for at least 24 hours. I've also been chasing an intermittent CEL which is likely related. The code was an evaporation system issue.
