BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > N20 22psi Peak boost.... Is it too much??
European Auto Source (EAS)
      09-25-2018, 09:11 PM   #89
IssaF32
IssaF32's Avatar
Drives: 2014 428xi Coupe
Originally Posted by ilivas View Post
I’d like to point out that it’s not necessarily that torque kills the motor. Cylinder pressure, heat, and detonation kills motors. From what I’ve seen on dyno sheets of this car, torque is what the car makes more of. So in that essence, torque is killing it. The reason torque is killing it is because the heads, cam, turbo, intake manifold, or whatever simply cannot carry that torque into the higher rpms. There is a restriction in the motor somewhere. Ideally, you want to carry that torque to redline since as rpms increase up will increase if the torque curve stays flat. So on the n26, the most stress on the motor is where the torque peaks because it simply dies off in the upper rpms.
Notice my torque curve on my Vette. This is an old dyno sheet.
HP=(torque x rpms)/5252
Buddy you keep talking about your vette and its annoying, These are not vettes, torque kills this motor and shitty tunes way before any of that will do anything to our motor.
[Snow Performance Stage 2 Meth injection] [225cc Injector 50% Methanol Fuel] [Stage 2 fuel-it lpfp] [HCP Custom e60 AGG] [Bootmod3 All Ots Maps] [VRSF 4" Catless Downpipe] [Evolution Racewerks Chargepipe] [Wagner Competition EVO 1 FMIC] [Injen Cold Air intake] [NGK laser iridium .018] [Konig 18lb Race Wheels] [250lb Weight Reduction] [CF M4 style spoiler] [Gloss Black Kidney Grills]
      09-25-2018, 09:45 PM   #90
rjdnyy224
rjdnyy224's Avatar
Drives: 2013 328i xDrive
The basic physics behind engines is typically generally applicable. Whether you gain knowledge of those physics (which are more or less what we're discussing here) by tuning a Corvette or an N2x is irrelevant.
That being said, he also kind of agreed with you: "So in that essence, torque is killing it." You saying torque kills motors is like saying fatness kills fat people. No, it's the fact that a human heart can't support 250lbs of extra weight. In the same way, yah, you could say torque kills these motors, but it's really the sudden onset of a lot of cylinder pressure at low rpms that kills the motor. This pressure subsequently generates torque, but the torque itself is not what's killing the motor.
In the same vein, you saying that a bigger turbo will make more boost is sorta true, but it's not really. On a log, you'll see more boost in the upper rpms, which can fool you into thinking it's making more boost, but that's only because the bigger turbo is remaining efficient where the stock one becomes inefficient.
ilivas also didn't flat out call anyone wrong, he just said he can't understand how a rod bolt could be damaged by a lot of low rpm torque, not that it doesn't happen.
2013 328i xDrive N20 8AT | Bootmod3 Stage 2 OTS 93oct AGG | VRSF Street 5" HD Front-Mount Intercooler | VRSF Catless Downpipe | M Performance Exhaust | NGK L/I Spark Plugs | K&N Drop-in | Dinan 20" Wheels Wearing Michelin PS4S's | Dinan Springs and Bumpstops | F80 Style Decklid Spoiler | Debadged | F80 Style Grille | Various Interior Bits |
      09-25-2018, 09:48 PM   #91
IssaF32
IssaF32's Avatar
Look, don't gotta get all technical your basically saying the thing that generates torque kills engines which is torque. yes engines are the same but every time I get on the n20 forums all I see is corvette
      09-26-2018, 07:02 AM   #92
rjdnyy224
rjdnyy224's Avatar
Yes, but how far along would the medical community be if we just went along satisfied with saying that fatness kills fat people and never dug deeper to find out why? Sorry to use such a crude analogy but it works, and I think you get my point... if he just came on here to brag about his Corvette or something I'd get it, but relating his experience on that platform to this platform is often helpful, at least I think so.
      09-26-2018, 09:02 AM   #93
BunkerJ
BunkerJ's Avatar
991
Drives: 2013 328i
The overboosting likely causes a lean condition and detonation. I wonder if itís a tuning issue. Has that happened a lot? Itís hard for me to wrap my head around instant torque breaking a rod bolt. I can see a lot of factors breaking rod bolts, but itís hard for me to see a torque curve doing it. NA motors have even more instant torque.
Itís not a huge platform, so really not many people have pushed them to their limits. Youíve been around here longer than I have so you would know better, but from what Iíve seen, only a couple people have pushed them so their may not be a ton of info on the motor. In the other platforms that Iíve dealt with, there are more bad tuners than good ones. Iím not yet sold on a lot of things till I can see a lot more tuners with a solid general consensus.
Heat + oil starvation on corners/braking + instant torque @ ~350lbs = broken rod bolt
That's pretty much the recipe for a blown track motor on quite a few before they started building them. Then everyone redid the con rods/bolts and custom oil sump pickups to make up for this issue.
As for the overboosting, it's all from JB4. Piggybacks cannot react fast enough to save this engine from failure once that occurs. Events were almost always the same: boost to 25psi+ and cylinder blew due to a ring failure. Not saying that it will always boost but due to the lean conditions that JB4 runs the car in plus that overboost... yeah.
2013 F30 328i: MHI Big Turbo, GFB DV+, Mishimoto CAI, ER TIC/CP/Catless DP, AWE Touring Quad Exhaust w/ Resonated Midpipe, NGK LI Plugs, BM3 with PTF Stage 2 91 AGG Tune, Fuel-it Stage 2 LPFP, Solowerks S1 Coilovers, and DEPO/M-Sport Retrofit
      09-26-2018, 09:05 AM   #94
BunkerJ
BunkerJ's Avatar
991
Drives: 2013 328i
I'll agree in saying that his perspective is insightful at times. I'll admit, we didn't get off on the right foot but it's okay to talk about other cars.
rjdnyy2241157.00
      09-26-2018, 01:18 PM   #95
ilivas
Drives: 428
While Iím new to this platform, I try to use things that I know apply to all cars. I have been bringing up my Vette because itís something that Iíve been heavily involved in right now since Iím in the middle of a build. But the concepts should apply.
I do concede that they are not the same car though and not EVERYTHING applies which is why I ask questions as well. I do like to remain skeptical mainly because the aftermarket support of this car is so limited and not many are going past FBO.
I do have a large car community here and have learned to respect all cars and I try to get a good understanding of the popular platforms especially.
BunkerJ990.50
      09-26-2018, 01:24 PM   #96
ilivas
Drives: 428
Great. I have a JB. Lol. What a buzz kill. Haha
      09-26-2018, 03:51 PM   #97
BunkerJ
BunkerJ's Avatar
991
Drives: 2013 328i
Lol! I would configure the safety down to 24psi and cross your fingers.
320, boost, n20, peak, psi
