BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > DIY: LCI IHKA Climate Control Display Retrofit - IHKA3 Required
      05-19-2018, 01:28 PM   #67
bill_f31
Drives: BMW F31 M Sport
I have also done the LCI A/C panel retrofit on my pre-LCI IHKA3 F31.
Totally love it.
Full transformation of the centre console,not only because of the white digits,but also due to the different font of the A/C panel.
For anyone interested,I have found that without FDL coding IHKA3>3006>Farbumschlag>AKTIV, the digits remain white at night,but if you turn down the instrument lights-ambient light slider across the middle,the digits become amber.
I prefer it this way,because if I have Sport mode on my 6WB digital cluster at night, the A/C white digits suit better the white digits of the cluster,but I can also turn the A/C digits to amber through the light slider when I am in comfort mode.
Try it!
IK6SPEED2603.50
      05-19-2018, 02:50 PM   #68
Bubu88
Bubu88's Avatar
Drives: F80 M3
crosspost from other topic:
Maybe not 100% ontopic but I have an issue with my IHKA3:
Car is from 03/14 but IHKA3 was already there. So I retrofitted LCI HVAC and everything was working properly. I tested all functions / buttons for 2 mins and then turned the panel off.
Afterwards I coded IHKA3 with „Fatbumschlag“ to get the color change from white to amber. After coding the panel turned on, everything is still working but I cant switch it off anymore. I can go to lowest ventilation setting and if I keep pressing the lower / off button further nothing happens.
Anybody has an idea what went wrong? Coding was done with e-sys, VCM readout first and the only value changed was „Farbumschlag“ before FDL coding it
      05-19-2018, 04:07 PM   #69
IK6SPEED
IK6SPEED's Avatar
Drives: BMW M3 / AH3
What happens if you code back?
Stable: F80 / AH3
Past: F80 ZCP / F22 M235i / E89 35is
      05-20-2018, 12:20 AM   #70
Tim@codemybimmer
Tim@codemybimmer's Avatar
Drives: 2018 440ix GC & 2015 X3
When you code the IHKA ECU, it’ll sometimes set the A/C compressor into a “learn” or “diagnostic” mode for a few minutes until it’ll be all okay and let you turn it off. Give it 5-10 minutes of it being on and it should revert back to normal
      05-22-2018, 12:43 PM   #71
Bubu88
Bubu88's Avatar
Drives: F80 M3
That solved the issue
      09-17-2018, 06:44 AM   #72
dr.Mabuse
Drives: BMW F30
is there a difference between
64119363546-02
and 64119363546-01
thank you
      09-18-2018, 10:31 PM   #73
IK6SPEED
IK6SPEED's Avatar
64119363546-02
and 64119363546-01
thank you
For retrofit purposes, no.
Stable: F80 / AH3
      09-19-2018, 02:03 AM   #74
dr.Mabuse
Drives: BMW F30
good to know. Thank you.
Mine arrive tomorrow. hope that will work on my 05/2014 F30. (have IHKA3) Also ordered 6WB digital cluster. The white LED would be great
      10-01-2018, 10:44 PM   #75
Jerry333
Drives: 428i coupe m sport
Just one question,
If you went to Dealer for service or maintenance, will there be major problems if they recode your vehicle ??
      10-02-2018, 09:13 PM   #76
alex75015
Drives: BMW F30 320D M 15/07/2013
Hello, I have a Bmw F30 320D 07/2013 M and I bought Commando Clim LCI, part number 64 11 9 363 546 01, can I install it in my car? I don't know if it's an IHKA3!
I installed it but it does not work well, I think I have to code it?
thanks a lot for your help
      10-03-2018, 12:24 AM   #77
IK6SPEED
IK6SPEED's Avatar
Originally Posted by Jerry333 View Post
Just one question,
Yes, major issue if they connect your car up to check for problems. I don’t even think they code recode your car if these parts were in it. Software usually balks if items in vehicle that shouldn’t be.
Reread this thread as well as one below from start to end.
https://f30.bimmerpost.com/forums/sh....php?t=1274250
Stable: F80 / AH3
      10-20-2018, 02:07 PM   #78
Drimacus
Drives: 2013 F31 320d Luxury
Originally Posted by jeffc83 View Post
I'm curious about this as well
I Succesfully made it!
jeffc83681.00
      10-20-2018, 02:08 PM   #79
Drimacus
you don't have ihka3 but it's possible to retrofit it!
      03-01-2019, 05:50 PM   #80
Crazy_1201
Drives: E90 320d
I recently upgraded my IKHA to IKHA3 following this DIY. The only thing I had trouble with was Esys recognising the IKHA3.
I changed build date to 07/14, wrote FA FP and coded all ECUS
IKHA3 still was not showing.
I realised that during Tal Calculating when you have to select a iStep Shipment (KIS/SVT) instead of choosing the vehicles actual iStep shipment choose an LCI shipment e.g. 14-07-505
Select HW-IDS from SVTactual
Then follow TAL processing but only flash IKHA3 which should now show.
